#16 | |
I do stuff
Even on new ones I silicone them on just for the added protection when in the water. But yes defenitly get a new one first.
Got any plumbing questions? Are you a plumber? Need another general discussion to hang out in? Check out plumbingforums.com Need another Wrangler forum? Check out wranglerboard.com |
#17 |
To clarify it was a puddle not a lake I drove in. I would say six inches deep and twenty feet long. I think I will start with a new cap and rotor.
91 XJ 4.0 mostly stock |
#18 | |
100% great info
AEKDB Leaky sunroofed XJ member #1 The United States of America July 4, 1776 - November 4, 2008 RIP
#19 |
Little Red Menace
May also be a bad TPS, but that problem usually doesn't go away, it just gets worse.
93 Sport Beer is proof that God loves us and wants us to be happy............Ben Franklin Specs in Profile. http://www.cardomain.com/ride/325707/1 http://www.cardomain.com/ride/2406854/1 |
#20 |
Alternator clutch? C'mon, this is the classic symptom of wet wires/wet distributor. Water gets near the secondary (high-voltage) wiring and shorts some/all of the spark plug electricity to ground. Result: rough running and misfiring.
Change the wires with quality replacement parts, and use silicone grease on all of the boots. Using a small amount of silicone grease (not caulk or gasket maker!) on the base of the cap isn't the worst idea I've ever heard, but don't overdo it; don't let the grease ooze into the distributor itself. |
#21 |
could be a bad alt. if the voltage is low enough from it getting wet, it will idle poorly. mine has done it more than once. sometimes it goes away after a minute, sometimes it toasts to alternator. when you do notice the rough idle, check your voltage gauge in your XJ. that will at least rule it out
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
