runs rough after a hard launch - JeepForum.com
post #1 of 11 Old 12-12-2006, 03:34 PM Thread Starter
StreetJeep
I haven't read anywhere about this but here goes. Has had a tune up within 1500 miles using Champion truck plugs, copper connector cap and rotor. Wires are good. Checked codes and nothing. Checked the TPS and it works smoothly with no dead spots. But after I launch over half pedal from a light it will idle rough for about a week. Then it slowly idles better after that. I'm sort of at a loss. Could it be the injectors? Possibly the fuel filter? If anyone has experienced this let me know what you did to fix it. Thanks in advance.
StreetJeep is offline
post #2 of 11 Old 12-13-2006, 06:39 PM Thread Starter
StreetJeep
Anyone????
post #3 of 11 Old 12-13-2006, 07:59 PM
georgesxj
It may be that the fuel filter is clogged up so when you hit the gas it pushes trash into the line and you have to wait till it dislodges itself. The filter should be changed every year or two anyway so it wouldn't hurt to put a new one in and try it out. There only like 10 bucks if you have a pre 97'. If you have a newer jeep it's inside the tanke and a little more tricky to change.
92 Sport
RE 3.5" super flex
31 x 10.5 Dunlop Mudrovers
Custom rack and rails
Hella 4000's on top
and lots of problems to still work out
georgesxj is offline
post #4 of 11 Old 12-13-2006, 08:05 PM
Rock Kustoms
Rock Kustoms's Avatar
how about a year, motor, tranny, tcase etc
Rock Kustoms is offline
post #5 of 11 Old 12-13-2006, 09:23 PM
Haleyes
Don't launch hard?
96' XJ, 33's and 4.88's
Haleyes is offline
post #6 of 11 Old 12-14-2006, 02:39 PM Thread Starter
StreetJeep
Its a 92 Limited, aw4, np242. The fuel filter is a possibility. Thats going to get changed next.
Haleyes,
I'm not an old man. Unless you ask my wife. Then I am an old man. But I'm still a kid at heart. So the floorings will continue.
post #7 of 11 Old 12-15-2006, 05:36 PM Thread Starter
StreetJeep
Okay, changed the fuel filter. Still idles rough. The filter that was in there looked to be no more than a couple years old. Could bad injectors cause this? Or possibly a faulty MAP sensor or O2 sensor not throwing a code? Did this year have a CPS?
post #8 of 11 Old 12-15-2006, 07:55 PM
SlimGoaty
SlimGoaty's Avatar
1997 XJ Cherokee
give her a good seafoam and clean the TB and IAC just to make sure everyone is happy.
97 XJ 4.0, AW4, 231, RE 5.5, Tom Woods DS, AA SYE, 35x12.50 KM2,
Upgraded Harness, PIAA bulbs, Rustys Tie-Rod, L&L Fab bumper,
Quadratec 9500i Winch, Aussie locker, 4.88's
SlimGoaty is offline
post #9 of 11 Old 12-16-2006, 10:30 AM Thread Starter
StreetJeep
I did both of those. Sorry forgot to write that. I cleaned the throttle body and IAC then ran a bottle of sea foam through it. Half in the tank and the other half in the throttle body. My neighbor saw the smoke and came running up the hill.
post #10 of 11 Old 12-16-2006, 10:41 AM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Check your cat.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #11 of 11 Old 12-17-2006, 06:21 PM Thread Starter
StreetJeep
No I dont think the cats a problem.
New to Jeepin: Bought 89 Cherokee, it starts and runs but runs rough and stalls in D stockli XJ Cherokee Technical Forum 7 04-29-2013 08:48 PM
HELP! 4.o hard to start runs rough back fires NEW DIST nanasjeep XJ Cherokee Technical Forum 12 11-21-2009 08:59 AM
4.0 runs rough and gets 7 MPG Chip682 XJ Cherokee Technical Forum 9 03-23-2009 10:39 AM
runs rough lrzmsr XJ Cherokee Technical Forum 5 05-04-2008 08:59 AM
Runs rough when warm, help Hendo_10 XJ Cherokee Technical Forum 4 01-03-2006 02:50 PM
