Quantcast runs rough - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > runs rough
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 05-02-2008, 05:37 AM   #1
lrzmsr
runs rough
Hello. I'm new to this forum. It seems like one of the better ones. I have a 97' cherokee with 138K on it. I recently installed a Dynomax cat back sytem with a new magnaflow catalytic converter. After installing everything, my jeep started running really crappy. It starts fine, and will run fine for a few minutes. I took it for a test ride and it ran great for the first five minutes, then it wouldn't run right. It loses power and bucks around almost like its missing or something. It will also make popping sounds through all of this. I replaced the O2 sensor after the cat, cleand the throttle body really well, and also disconnected the battery for a few minutes(maybe thinking the computer needed to reset itself). None of this seemed to work. Anyone have any other suggestions?
lrzmsr is offline   Reply With Quote
Old 05-03-2008, 09:52 AM   #2
tjwalker
It's the crank sensor!
tjwalker's Avatar
Probably no relationship to the exhaust work you performed. Have you seen a check engine light recently or scanned your computer for any stored codes? Driveability problems always are a good time to review basic tuneup status. When is the last time your plugs, distributor cap, rotor and plug wires were changed? If questionable, swap in new parts. Simple things first. You may also want to consider a fuel pressure test by installing a pressure gauge on the schrader valve of the fuel rail.
Good luck and let us know what you find out.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is online now   Reply With Quote
Old 05-03-2008, 12:06 PM   #3
Dannyboy18
You could have clogged a sensor when cleaning the TB. I'm blanking out since I forget what it was, but I am guessing this could be your problem. When mine was running rough, it was my TPS going out; no CEL or anything. Still, I cleaned the TB and it ran 'better,' but still messed up.
You can't rule out BAD LUCK. Honestly, about a month ago I was in STL and my XJ's radiator hoses decided to start leaking RIIIGHT before my 2-hour commute back to college... When I go to pick it UP from Dobb's on Sunday (yes I know, don't start, it was the only place open on Saturdays...), it started rough, threw a CEL and had a bad misfire...
OF COURSE I blame Dobb's initially, but then I thought about it and it couldn't have been them judging by the work that was done. Long store short, something in one of the fuel injectors (I think cylinder #1) had to be rewired and that's what was causing the CEL.
I'm placing my bets on a sensor of some sort.
1999 Cherokee Sport - Black; 4.0L AW4, NP231 w/ D30 and 8.25C.
RE 3.5" Super Ride w/ full packs (4* shims) + OME shocks + RE SYE w/ Tom Woods CV
Yukon 4.10s
AR Baja Alloy Wheels - 15x8 + Bridgestone Dueler Revo A/Ts - 31x10.50x15
TeraFlex Adj. Trackbar + TeraFlex Quick Disconnects & WARN T-case skid
Dannyboy18 is offline   Reply With Quote
Old 05-03-2008, 12:23 PM   #4
Crystalship1
1997 XJ Cherokee
IMHO, You need to do an ECM reset after all of those changes. Disconnect a battery cable, turn on the headlights, wait 10-15 min., turn lights off, re-connect battery and then DRIVE for 20-30 min. (Just idling won't allow the ECM to re-learn). That's where I would start.
Good Luck!!
"Seems like common sense isn't that common anymore"
And by the way.... "alot" is NOT a word!!!!
1997 Gunmetal Blue XJ Sport - 4.0 L. I6 - 4 Dr. - 4x4 - 1.75" BB
Crystalship1 is offline   Reply With Quote
Old 05-03-2008, 03:00 PM   #5
lrzmsr
thanks for the responses. i installed a new CPS and that didn't help anything. Before installing it, the check engine light was not on. I installed the CPS, it acted the same way, and now the check engine light is on. Is there anyway to find the code for whats wrong, or do i need to take it somewhere to get it read?
Old 05-04-2008, 09:59 AM   #6
tjwalker
tjwalker's Avatar
Take it in and let them scan for codes. Some of the big box shops like Auto Zone and Advance will do this for free in the hopes that you will buy any needed parts from them. Otherwise, this is something any shop can do for a minimal charge. Post back what code(s) come up....
Glock Forum
