runs great cold but when warm it runs bad. - JeepForum.com
post #1 of 5 Old 06-23-2011, 08:38 PM Thread Starter
flaneryjunior99
my jeep runs great when cold but when up to operating temp it runs like crap, i checked the fuel pressure its good, no vaccum leaks, i can hook it up on a OTC Genysis it will show a ingnition coil #1 and #2 but i cleared it didn't come back on . I can watch it with the genysis when idling or driving no misfires on any cylinders. Could it be the ingnition coil bar?
flaneryjunior99 is offline
post #2 of 5 Old 06-23-2011, 09:08 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
It could be that it is suffering from heat soak which is common for a failing electrical component. Once it gets to a certain temp it doesn't work correctly but functions fine when cool.
xjfever is offline
post #3 of 5 Old 06-24-2011, 01:21 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Also possible bad o2 sensor. Fuel trims running stupid rich or lean?
ratmonkey is offline
post #4 of 5 Old 07-06-2011, 03:43 PM Thread Starter
flaneryjunior99
the 99 only has one oxygen sensor i cut the catalatic converter off no change. replaced the camshaft position sensor no change, I replaced the ingnition coil bar no change.
It is showing p0351 and p0352 ingnition coil A and B circuit malfunction.
I broke into the harness traced the wires to the pcm nothing broken.
Ive had ppl tell me it is the pcm.
What do u all think?
post #5 of 5 Old 07-09-2011, 05:29 PM Thread Starter
flaneryjunior99
i put a pcm in it no change..
Runs great cold, but idles crappy if it goes a hair above 210. keepishop XJ Cherokee Technical Forum 4 01-08-2011 04:35 PM
New member can use a little help. XJ runs warm? mula XJ Cherokee Technical Forum 19 12-12-2010 07:27 AM
Runs great, then dies ssebastian XJ Cherokee Technical Forum 1 09-07-2008 10:12 PM
Runs rough when warm, help Hendo_10 XJ Cherokee Technical Forum 4 01-03-2006 02:50 PM
Runs choppy at warm startup drwambo XJ Cherokee Technical Forum 3 06-03-2005 04:43 PM
