Running second sound bar. Help with wiring? - JeepForum.com
post #1 of 9 Old 03-26-2012, 11:37 AM Thread Starter
Wolfie
Ok. I have a 4 speakers 95 XJ. I have a second sound bar. Already put it in. But... Not sure how to wire up/what to do. When it comes to wiring... Not the best to be honest.
So. Do i just splice it into the rear or front speakers to run them? or what do i do? Id love to have these speakers in.
Originally Posted by SunDevilJeeper
the hell is that? I shall consult google.
Wolfie is offline
post #2 of 9 Old 03-26-2012, 11:52 AM
N8N
depends on the head unit, and exact location of sound bar. need more info. what head unit are you running, and do you have an amp driving your existing speakers?
N8N is offline
post #3 of 9 Old 03-26-2012, 11:58 AM Thread Starter
Wolfie
its a pioneer head unit. The second sound bar is located right behind the front seats. No I do not have an amp (that i know of)
Wolfie is offline
post #4 of 9 Old 03-26-2012, 01:20 PM
cherokeecrawler
1992 XJ Cherokee
Hey wolfie how did you mount your second sound bar? and did you do anything to keep it from sagging in the middle?
cherokeecrawler is offline
post #5 of 9 Old 03-26-2012, 01:33 PM Thread Starter
Wolfie
Do you know how the rear is mounted? The sound bar gets held up by the side trim (or atleast held in place) and then where that light is mounted in the center. 2 put in some screws which connect to the mount in the roof. Make sense? If you need pics i can take some.
Wolfie is offline
post #6 of 9 Old 03-27-2012, 01:33 PM
cherokeecrawler
1992 XJ Cherokee
Yeah thats what i thought. The only problem in mine is that its a limited and it had the full over head dash with all the garage opener compartments and also has the keyless entry glass and two lights on the dash attached to the head liner and falls below the head line 2-3 inches, directly where i want to put the sound bar. If you catch what im saying?
I just dont know if i should cut the back section of it off, the part containging the two cabin lights, and some how attach the lights in the new sound bar to where the old lights were.
Im sorry its kind of a hard thing to explain. I can put pics up if needed
post #7 of 9 Old 03-27-2012, 01:35 PM
cherokeecrawler
1992 XJ Cherokee
And if it wouldnt bother you to completly do away with the front door speaker you coult just run the wire for the front speakers up to the speakers in the new sound bar. Which would your perminant front speakers though
post #8 of 9 Old 03-28-2012, 07:50 PM Thread Starter
Wolfie
Im just going to daisy wire it til i can get an amp. Then ill run the rear speakers off the amp.
Wolfie is offline
post #9 of 9 Old 03-28-2012, 07:50 PM Thread Starter
Wolfie
Yeah i kinda understand what your saying. But idk. I dont have that problem...
Wolfie is offline
second soundbar , speaker , wiring
Daytime Running Light wiring? Cdn96XJ XJ Cherokee Technical Forum 0 06-01-2010 07:52 AM
2000 Cherokee Premium sound wiring mww1962 XJ Cherokee Technical Forum 4 02-15-2006 12:54 AM
2000 Premium Sound wiring mww1962 MJ Comanche Technical Forum 2 02-13-2006 08:05 PM
More wiring issues, running lights not working TwoOne XJ Cherokee Technical Forum 2 08-01-2005 08:36 AM
Wiring ?, about day-time running lights scotty'98 XJ Cherokee Technical Forum 3 06-30-2005 12:16 PM
