running rough - JeepForum.com
post #1 of 17 Old 08-13-2013, 04:31 PM Thread Starter
lance89xj
1989 XJ Cherokee
running rough
so I have been working on my 89 xj for about 2 monthes. I ended up rebuilding the moter and now it runs, but if im not barely on the gas or really getting on it its sputtering and a little backfire everyonce in a while. it don't like driving down the road at a certain speed. I have to be really on the gas or barely touching it. I have replaced the ideal air control valve and the TPS. that helped a little but its still doing it. any ideas???
lance89xj is offline
post #2 of 17 Old 08-13-2013, 06:15 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
How are the 3 ground wires at the dipstick tube stud?
Did you index the distributor?
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #3 of 17 Old 08-14-2013, 10:37 PM Thread Starter
lance89xj
1989 XJ Cherokee
ok yes I made sure it was at TDC befor I put the head back on and stabbed the dizzy to face #1 plug wire. I just got done cleaning the ground wires on the dip stick stud and the main ground on the fire wall. its running the same. just so u know I have replaced the camshaft, lifters, push rods, rocker arms, oil pump, ignition coil, ICM, dizzy, cap, rotor, plugs, wires, CPS, fuel pump, fuel filter, and all fluids and all filters. im so lost in what to do now.....
post #4 of 17 Old 08-15-2013, 05:23 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
What kind of shape is that vacuum line from the throttle body to MAP sensor on the firewall in?
post #5 of 17 Old 08-16-2013, 01:08 PM Thread Starter
lance89xj
1989 XJ Cherokee
when I did the motor rebuild I had some broken vaccume lines so I bought a whole new setup
post #6 of 17 Old 08-16-2013, 03:55 PM
psychoteen101
check fuel pressure to make sure you didnt get a bad pump
1996 Jeep Cherokee- Project-- Rusty's 8in long arm, SYE kit, Teraflex driveshaft, Cragar soft 8's 15x10 with 33x12.5 Firestone Destination MT's, Eaton Tru Trac in the front
psychoteen101 is offline
post #7 of 17 Old 08-18-2013, 04:05 AM Thread Starter
lance89xj
1989 XJ Cherokee
I tested the fuel pressure today and it was around 45-47. that's not it any other ideas. I also changed my spark plugs again yesterday and no change
post #8 of 17 Old 08-18-2013, 05:24 AM
xjman242
Stock cam specs?
xjman242 is offline
post #9 of 17 Old 08-18-2013, 06:26 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Only supposed to be 39 psi. High fuel pressure causes rich running.
The vacuum line from the throttle body to MAP isn't available anymore. Sure you replaced it?
post #10 of 17 Old 08-18-2013, 03:55 PM Thread Starter
lance89xj
1989 XJ Cherokee
I pulled it off and I could blow trough it so its fine. I cheaked it again today. that fuel pressure was while it was running. I replaced the o2 sensor just now and no difference. it was broken so I thought it would help. just waisted another $64. I need to have this fixed asap
post #11 of 17 Old 08-18-2013, 05:47 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I'm more concerned that the tube is leaking vacuum.
and, that fuel pressure is too high when running!!
post #12 of 17 Old 08-19-2013, 03:21 AM Thread Starter
lance89xj
1989 XJ Cherokee
I just replaced the egr valve and still nothing. idk what to do now. I need this fixed soon
post #13 of 17 Old 08-19-2013, 05:26 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Your fuel pressure is way too high. 31 at idle with vacuum hose connected to fuel pressure regulator and 39 psi when the vacuum hose is disconnected.
post #14 of 17 Old 08-23-2013, 11:54 AM Thread Starter
lance89xj
1989 XJ Cherokee
so how do I fix that? replace the fuel regulator?
also I believe my timming is off cause I get the ocational backfire
post #15 of 17 Old 08-23-2013, 02:50 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Timing is not adjustable.
Quite possibly your fuel pressure regulator has failed, or your fuel return line is kinked/crushed.
