Running rich? Codes P0132, P0135, P0138 - JeepForum.com
post #1 of 17 Old 04-10-2010, 04:05 PM Thread Starter
zackXJ
2000 XJ 4.0
I swapped in a reman'd engine almost 500 miles ago. The break-in has been going well and I just changed the oil for the first time today. Right after I finished changing the oil, I started her up and my engine light came on. I pulled the codes and got 0132, 0135, and 0138... o2 sensor codes. On the way to get the codes read, the engine was idling really rough while it was still cold. It was sputtering as if it was gonna die, and dropped to around 300rpm. Once it warmed up, it seemed to be fine.
I had an issue when I started up the new engine for the first time with the fuel synchronization. But I found some good instructions and followed them to line up the cam pos. sens with the top dead center of the camshaft. (toothpick method).
After I had done the fuel synch., everything seemed fine. But now I'm worried I messed it up again. Maybe I nudged the sensor while replacing the oil? Anyways, I really don't want to have to take it to a shop, but it looks like I may have to because I need their computers to properly tune my engine. Is there anything else I should try before taking it to the shop?
'00 XJ 4.0L 4WD LP30 & Chrys8.25
3.5 RE Flex 31 BFG ATs
Gig 'em Aggies!
zackXJ is offline
post #2 of 17 Old 04-10-2010, 05:19 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
It may just be a coincidence that the O2 sensor codes have come up, and they may not related to your engine swap.
Inspect the O2 sensor wires and connectors for damage. The wires can be mis-located and come in contact with hot exhaust parts, leading to a short circuit. Test or consider replacing the O2 sensor as part of your routine maintenance.
CJ7-Tim is offline
post #3 of 17 Old 04-11-2010, 07:19 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Also verify fuses in the power distribution center under the hood. The heater circuit for the oxygen sensor IS fused. I believe it is somewhere around fuse #16 or #17. 10-15 amp mini fuse probably.
One of those codes has to do with heater function and I recommend checking fuses anytime you see a code with the word "heater" in it.
Good luck and let us know what you find!
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #4 of 17 Old 04-11-2010, 11:39 AM Thread Starter
zackXJ
Well I cleared the codes and they haven't come back yet... And the engine seems to be running pretty well. I think I splashed some oil onto the exhaust manifold or something, or it was just a fluke? If it comes back, then I'll know I have a problem.
Gig 'em Aggies!
zackXJ is offline
post #5 of 17 Old 04-11-2010, 08:05 PM Thread Starter
zackXJ
I have a problem! The light is back on... I'll try to get the codes read tomorrow sometime, but I'm betting they're the same. It seems random, because today the idle was low and erratic even when the engine was warm. I'm gonna get a fuel pressure gauge and hook it up and see if that is a problem. Otherwise it looks like I may have to take it to a shop to get the computer calibrated? Any other options would be greatly appreciated. My wallet is empty right now, so I really don't want to fix what aint broke!
Gig 'em Aggies!
zackXJ is offline
post #6 of 17 Old 04-13-2010, 09:11 PM Thread Starter
zackXJ
Here's an update: I've checked the o2 sensors and their relays (are there supposed to be fuses as well? Or are mine just box 5-pin relays?) I went ahead and replaced the front sensor and it's relay. I cleared the code and after about an hour, the CEL came back on. Before the light came back on, the engine was running perfect. But now it's running a bit rough at idle again, albeit not as bad as before. I pulled the codes and now I have 4! p0132, p0135, p0138, and p0141 (Both o2 sensors and both relays).... which tells me that it's something else.
A mechanic I know told me to check for a vacuum leak. I had already done so visually, but now I'll spray something on the hoses and check a little closer. He told me that since it's the exact same motor I swapped in, I shouldn't need to have the engine re-calibrated or anything.
Would an exhaust leak or intake manifold leak cause this? That would make sense because the bolts on the intake/exhaust probably need to be tightened now after 500 miles of break-in.
Gig 'em Aggies!
zackXJ is offline
post #7 of 17 Old 07-06-2010, 07:39 PM
AMCMoe
AMCMoe's Avatar
Any update to this? Mine is doing the EXACT same thing, same codes (except p0141) and I'm stumped. I replaced the front O2 sensor, repaired a frayed wire in harness for the rear sensor and I'm still getting the codes (though right now only p0135 and p0138) and it has the rough idle and stumbles like it wants to die as I'm driving it. Can't figure it out!
AMCMoe is offline
post #8 of 17 Old 07-29-2010, 04:05 PM
Oops
This may be complete coincidence, I flagged those same 3 codes for 2 years. I replaced both O2 sensors over and over. Check your mini fuses under the hood. I had a 15 amp that was bad. Replaced it and haven't had any problems since. IF.... that fuse has anything to do with the O2 sensors, when my driveshaft ate the harness the bare wires grounded and killed the fuse. I repaired the harness, resecured the wires, and started getting those codes. All anybody ever says is replace replace replace. I overlooked the small stupid stuff.
Oops is offline
post #9 of 17 Old 07-29-2010, 06:03 PM
Bedore
Check your fuse. It's the middle 15A fuse on the row closest to the relays in the PDC under the hood.
Bedore is offline
post #10 of 17 Old 08-02-2010, 04:14 PM Thread Starter
zackXJ
I've tried replacing the o2 sensors, the relays, and the 15a fuses, and the codes still remain (all four: p0132, p0135, p0141, p0138). I'm STUMPED. Any other ideas not yet mentioned?
Gig 'em Aggies!
zackXJ is offline
post #11 of 17 Old 06-29-2012, 05:50 PM
inkei91
Hi I am also pulling up all of these codes. i would like to mention in my case i have had particular issues with the vacuum system in my 2000 xj. It controls alot more than i previously thought. replaced both o2 sensors a month ago and ran good for a couple days, then it started the same thing and codes came back... stutter and even backfire.Also pulled a code for EVAP P0443, wich is also related to the vacuum system. wondering if it is the pcm as i am having all sorts of electrical issues(back up lights out, speakers going in and out, shorts in lots of circuits)
inkei91 is offline
post #12 of 17 Old 11-19-2012, 08:07 AM
WJ910
did u get it fixed???
2000 wj 4.0 7""lift 35s
ford 8.8 4.88 gears
jk dana 30
WJ910 is offline
post #13 of 17 Old 11-21-2012, 12:13 PM
chuber1994
1997 XJ Cherokee
Having same issues... Would be nice if someone got this fixed???
1997 Jeep Cherokee Sport
Cherokee Forum
- More Extensive
Jeep Forum
- More Recent
chuber1994 is offline
post #14 of 17 Old 11-21-2012, 01:13 PM
WJ910
Fixed mine check ur fuses if u haven't already
Sent from my droid using JeepForum
ford 8.8 4.88 gears
jk dana 30
WJ910 is offline
post #15 of 17 Old 11-21-2012, 06:55 PM
CJ7-Tim
CJ7-Tim's Avatar
P0132 135 and 138 are O2 sensor codes.
Possible causes:
- Front Heated Oxygen Sensor harness is open or shorted
- Front Heated Oxygen Sensor circuit poor electrical connection
- Faulty Front Heated Oxygen Sensor
- Faulty Front Heated Oxygen Sensor Fuse
- Incorrect fuel pressure
- Faulty fuel injectors
- Intake air leaks
- Exhaust manifold leaks
CJ7-Tim is offline
Computer codes P0135 and P0141 hi2live XJ Cherokee Technical Forum 11 11-27-2011 07:20 AM
P0300, P0301 & P0138 CEL Codes...96 XJ Sagebrush1976 XJ Cherokee Technical Forum 12 03-26-2010 04:28 PM
Fix running rich! JeepinXJstyle XJ Cherokee Technical Forum 6 11-19-2009 11:28 PM
Fault codes P0133, P0132, P0463 -- O2 sensor, and fuel level gauge XJMuscle98 XJ Cherokee Technical Forum 10 07-23-2009 11:27 AM
P0138 and P0420 codes. Anybody help? couchdog XJ Cherokee Technical Forum 5 02-11-2009 08:04 PM
