Rumbling/grinding sound at highway speeds. Wheel bearings? - JeepForum.com
post #1 of 4 Old 02-14-2011, 04:18 PM Thread Starter
ChrisTJCO
My 2001 XJ Sport makes a fairly loud rumbling sound going at highway speeds (60+). It's sounds like a dull grinding or rumbling that is loud enough to make talking with a passenger a little bit difficult. Could this be the front wheel bearings?
The XJ is a 2001 with 135K miles and still has the original bearings/hub assemblies (as far as I know).
White-Out Jeep
Colorado Jeep Club Member #230
ChrisTJCO is offline
post #2 of 4 Old 02-14-2011, 04:43 PM
thorszj
I have a 95 grand cherokee. I recently put a 4" lift on it. I was experiencing the same thing that you are talking about. I experience a rough grinding sound coming from the jeep's drive train. The ride is rough, as if i were running big mud terrain tires, and i have not yet changed the tires. I do not experience much vibration while execrating, but as soon as I come off the gas the grinding sound comes back. if i am going down hill and not accelerating the grinding is very evident. At highway speeds around 65mph the sound is a lot more louder. and it intermittently gets louder to the point that the grinding/vibration makes the interior vibrate and rattle. This vehicle has all-time 4wheel drive, when I took the front factory drive shaft off noise went away. I had a custom drive shaft fabricated by the guys at Carolina Driveline, they did a great job. As soon as I put the shaft on the Grinding vibration came back..... any ideas?
thorszj is offline
post #3 of 4 Old 02-14-2011, 04:45 PM
bds5
Yes it could be, my sons were bad and they made a very loud rumble Almost scary rumble..
bds5 is offline
post #4 of 4 Old 02-14-2011, 04:45 PM Thread Starter
ChrisTJCO
That sounds like a completely different problem - and you're in the wrong forum. Might have better luck at the ZJ forum: http://www.jeepforum.com/forum/f2/
White-Out Jeep
Low rumbling upfront at highway speeds ChrisTJCO XJ Cherokee Technical Forum 3 09-08-2010 03:14 AM
grinding/rumbling sound in the rear end? bmyohn XJ Cherokee Technical Forum 11 10-27-2009 05:36 PM
grinding sound in 4 wheel drive davejeep1 XJ Cherokee Technical Forum 3 08-11-2009 02:03 PM
Grinding sound coming from driver side wheel area... jdhughes XJ Cherokee Technical Forum 6 01-18-2009 08:02 PM
Hey man, why is the jeep rumbling like that on the highway? I think she's hungry... xj_newb XJ Cherokee Technical Forum 4 05-15-2006 04:27 PM
