Quantcast Rubicon Express 3.5" Super Flex ?'s and a Steering Stabilizer - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Rubicon Express 3.5" Super Flex ?'s and a Steering Stabilizer
Old 03-21-2008, 06:55 PM   #1
Trekman8
Hey. I just finished installing my RE 3.5" Super Flex Lift on my 98' XJ Limited. First off, it looks really high for 3.5 inches. Can anyone tell me the height from the ground to the top of your fender flares with this Lift Kit and 31" tires? Mine measures just about 37" in the Front and 36.25" in the Rear. Does it settle at all?
The tech part, What steering stabilizer/dampener do you reccommend? Will post a thread on the jeep later in the week. Looks like its gonna snow soon here and its dark out now.
Thanks
1998 Jeep Cherokee Limited Black
4.0L......AW4 Trans......NP231 SYE......DANA 30 in Front......Corp 8.25 in Rear
RE 3.5" SuperFlex, Bushwacker Flat Flares and 33" Goodyear Wrangler Duratracs
Black XJ on Moabs Club Member #2
Trekman8 is offline   Reply With Quote
Old 03-21-2008, 07:28 PM   #2
murrayman23
1987 XJ Cherokee
the steering stabilizer is not really a big deal. They only really are necessary when you are using 35" tires or higher. I have the Rancho RS5000 on mine and mine also has the RE 3.5" superflex. I never measured mine but yours is probably sitting at 4.25" ..its always a little higher when you first put it on.
[SIZE="1"][COLOR="Blue"][COLOR="Blue"] [SIZE="3"][COLOR="Lime"][COLOR="White"]"Rusty"[/COLOR][/COLOR][/SIZE] 1987 Jeep Cherokee XJ. 4.0L. 4X4. NP242. 3.5" RE superflex kit. RE Twin Tube Shocks. Rancho RS5000 Steering Stabilizer. Cragar soft 8's. 31" BFGoodrich A/T KO. Warrior Products Rock Crawler Bumper. Cobra CB. Firestik Firefly antenna. KC Daylighters.[COLOR="Black"]Half Herculined[/COLOR] [COLOR="Navy"]Half Navy blue[/COLOR] [/COLOR][/COLOR][/SIZE]
murrayman23 is offline   Reply With Quote
Old 03-21-2008, 07:50 PM   #3
tdogg55555
I just installed my Re 3.5 Super flex 2 weeks ago, and The front has settled a tad bit lower, but your right it does look like its lifted around 4 or more inches. It definitely sits high, which is good lol. And the ride gets smoother as well after a week or so.
96 Country...Weekend warrior
tdogg55555 is offline   Reply With Quote
Old 03-21-2008, 09:43 PM   #4
Trekman8
Ya the ride is very nice with the MonoTube shocks and full leaf packs. But i do have a lot of driveline vibes. Planning on an SYE, or a better word is probably saving. But a transfer case drop should get me from home to work until then.
Old 03-21-2008, 11:09 PM   #5
the_weirdo
It will settle. You are probably close to 5" of lift. My RE 3.5"SF gave me 5" of lift and settled to 4.5" or 4.25". RE gives you more lift than they advertise. Your stock steering stabilizer should be fine.
the_weirdo is offline   Reply With Quote
Old 03-21-2008, 11:52 PM   #6
XJ2000
The lift will definately settle, and RE lifts are known for netting a little more than what is advertised.
As for the steering stabilizer, if you have an alignment done after your lift (usually a must), then you shouldn't really need to worry about the SS. The SS usually just hides problems, and if you're all squared up in terms of alignment then it really doesn't/shouldn't make too much of a difference.
Oh, almost forgot..... POST PICS!!!!
North Jersey Jeep Club
Trail Rig: 2000 XJ w/ 4.5" RE SF, Locked XJ D44 Rear, Locked D30, and a bunch of other things
Pavement Pounder: 2001 XJ Daily Driver, 2" BB, 245/70R16 AT's on Moabs
XJ2000 is offline   Reply With Quote
Old 03-22-2008, 11:10 AM   #7
Trekman8
Ya it was aligned yesterday. Rides nice, and the steering is dead on now. Should wash it by monday and have pics then with a list of what was done.
Old 03-22-2008, 12:42 PM   #8
GottaBeJeep
Measuring from the ground is inconsistant so an accurate measurement of true lift cannot be attained. Measure from the center of the wheel hub to the bottom of the stock flares, this way you only get suspension measurement without accounting for inconsistancy of tire size. Stock measurements are 17.5" front and 17" rear. All the RE 3.5" leaf pack kits I have installed for customers were about 4.5" lift front and 5.5" lift rear, and the kit will settle a little depending on how much weight you put in it and how much flexing.
As for the steering stabilizer, I have 5" lift with 35's and 168,000 miles on my stock stabilizer.
Rock Lizard Fabrications
...Off Road Armor that's "Tough as Scales"
GottaBeJeep is offline   Reply With Quote
Old 03-22-2008, 07:14 PM   #9
Trekman8
I just measured 22 inches in the Front from the center of the hub to the top of the fender and 21.75" in the Rear.
Old 03-22-2008, 09:12 PM   #10
Highway 4x4
Any one with adj lower arms here, what did you set your lower arm length at to get proper allignment? I set mine at 16 in. I just put mine on and have 21 3/4 front and 22 3/4 rear.
Highway 4x4 is offline   Reply With Quote
Glock Forum
