Rubbing noise? - JeepForum.com
post #1 of 7 Old 03-03-2011, 09:52 PM Thread Starter
XJgrizzly99
Rubbing noise?
So for the past few weeks my XJ has been making a rubbing noise when I turn the wheel left. Almost sounds like it's a wheel bearing but it's not. I checked. Any ideas what it could be?
XJgrizzly99 is offline
post #2 of 7 Old 03-04-2011, 11:36 AM
iDriveYJ
Power steering pump low on fluid?
iDriveYJ is offline
post #3 of 7 Old 03-04-2011, 11:47 AM Thread Starter
XJgrizzly99
No. It's not like a whine your PS would make. It's a rubbing like a shot wheel bearing but I can't pin point what it is. Tires are new so its not that and it's not loud enough to be a cv joint.
post #4 of 7 Old 03-04-2011, 12:14 PM
smitty81
I have never herd of a bearing making a RUBBING noise, I have heard of squealing and grinding.......
Are you sure its a "rubbing" noise?
Does it happen when you turn both directions?
Does the noise speed up and slow down with speed?
smitty81 is offline
post #5 of 7 Old 03-09-2011, 09:11 AM Thread Starter
XJgrizzly99
It's kinda like a grind I guess. And no it's only when I then left and usually only over 35mph
post #6 of 7 Old 03-09-2011, 11:16 AM
98xjninja
My cherokee periodically has a small binding sound when making very low speed lefts.... but I've looked under and can't find anything binding... I may steal the feedback people leave for you.
98xjninja is offline
post #7 of 7 Old 03-12-2011, 11:05 PM
discgolfus
Not sure if this would help because mine is newer. I have a 2007 and have a rubbing sound on right side when I have the wheel turned all the way to the left at full lock out. I inspected it and found that the tire is rubbing on the sway bar. No idea what would cause it but have a appointment next friday to have it looked at
discgolfus is offline
