Rough start when warm - JeepForum.com
post #1 of 9 Old 10-18-2013, 09:48 PM Thread Starter
blue_xj_95
I Have a 2001 Cherokee xj and I plugged in the obd 2 reader and I got the code p0103 and it comes up as Maf or vaf A circuit high input but I have no idea what vaf stands for. Could anyone help me out with that?
blue_xj_95 is offline
post #2 of 9 Old 10-19-2013, 03:40 PM
psychoteen101
vaf-Volume air flow.
What kind of code reader are you using? Id try and plug in a full on scan tool to check for codes because that code shouldnt come up on a cherokee.
1996 Jeep Cherokee- Project-- Rusty's 8in long arm, SYE kit, Teraflex driveshaft, Cragar soft 8's 15x10 with 33x12.5 Firestone Destination MT's, Eaton Tru Trac in the front
psychoteen101 is offline
post #3 of 9 Old 10-21-2013, 08:43 PM Thread Starter
blue_xj_95
I just have a standard obd2 code reader it's just a cheaper code reader. Do you think it could possibly be the MAT sensor ?
post #4 of 9 Old 10-22-2013, 10:45 AM
psychoteen101
Its a possibility i suppose. I would get a scan tool or bring it to a dealer and have them plug a factory tool into it and see what they come up with.
post #5 of 9 Old 10-22-2013, 10:50 AM
biffgnar
biffgnar's Avatar
Code doesn't seem consistent, but rough starting when the engine is warm is often heat soak.
biffgnar is online now
post #6 of 9 Old 10-22-2013, 11:14 AM Thread Starter
blue_xj_95
What could be the cause of heat soak and with the trmpurature rise do you think it could be messing with the water temp sensor ?
post #7 of 9 Old 10-22-2013, 11:17 AM
psychoteen101
The design of the manifold sucks. The heat from that side of the engine heat soaks the injectors and it will run rough. Typically you will get misfire codes with that. There are ways around it. I bought new injectors and wrapped them with heat shield tape. There are also heat shields available to help block the problem areas.
post #8 of 9 Old 10-22-2013, 11:19 AM
biffgnar
biffgnar's Avatar
Hood vents help also
post #9 of 9 Old 10-22-2013, 01:15 PM Thread Starter
blue_xj_95
Alright well thanks for the help. It's appreciated.
