Rough start - rough idle - JeepForum.com
post #1 of 8 Old 06-15-2007, 09:08 AM Thread Starter
Primus462
2000 Jeep Cherokee Sport - 4x4
I've got two things going on:
1. When the engine is cold (not cold outside, just a cold engine) it starts kind of rough, but then runs smooth: I use fuel injector cleaner with every oil change and replaced the 02 sensor last month. It seems like maybe it doesn't have quite enough gas or something is dirty. It always starts on the first try. It turns over 2 or 3 times before it starts.
2. When the fan kicks on, it seems to cause everything to strain, and causes my dash and everything to rumble. It just started a couple of months ago and doesn't happen all of the time. I really just notice it at stoplights. While it's rumbling, it sounds like an air compressor is running, too. At least, that's what it reminds me of.
Any ideas?
Are they related?
Thanks in advance!
2000 Cherokee Sport - 4x4- 4.0L
30" BFG Mud Terrain T/As
Monroe Sensatrac shocks
Mud Flaps
Yakima Boa Bike Rack
60K miles
Primus462 is offline
post #2 of 8 Old 06-15-2007, 01:38 PM
Higgs98XJ
Higgs98XJ's Avatar
have u tried seafoam? usually an easy fix
or maybe u just need new spark plugs
2001 WJ Laredo
4" IRO lift w/ front long arms, Bilstein 5125s, 32" BFG KM2s on JK Moabs
Past: '98 XJ Sport
Higgs98XJ is offline
post #3 of 8 Old 06-15-2007, 01:52 PM Thread Starter
Primus462
Sorry, newbie here. What's seafoam? I guess I can search for it.
I replaced the spark plugs last year.
Mud Flaps
60K miles
post #4 of 8 Old 06-15-2007, 02:50 PM
illz302
seafoam is a white can of engine cleaner that you can put in numerous places to clean the engine
07 WK Laredo
88 XJ 4x4
illz302 is offline
post #5 of 8 Old 06-15-2007, 06:53 PM
collkid
I would think its the fuel filter. Just an idea...
And seafoam ROCKS!
collkid is offline
post #6 of 8 Old 06-16-2007, 06:15 AM
monty1320
There is no fuel filter on a 2000 XJ.
monty1320 is offline
post #7 of 8 Old 06-20-2007, 08:09 PM
plantmatter
I have a 99 Grand Cherokee Limited with V8 4.7 engine. When I start it up the idle shoots way up up, then down, then way up. once its a little warm it runs perfectly fine. Any ideas?
plantmatter is offline
post #8 of 8 Old 06-20-2007, 11:40 PM Thread Starter
Primus462
I tried Seafoam this past weekend. I can tell that it's idling smoother and it starts easier. Seafoam DOES work! I put the rest in my gas tank. We'll see if that helps, too.
I noticed that I only got a few seconds of white smoke. Does that mean it wasn't very built up/dirty? I was wondering if maybe I put the Seafoam in too slow, also. It probably took 10 minutes. I put it in through the brake booster. Any ideas? My brother put it in his Chevy ZR2 in just a minute or two, of course his air line was bigger.
Thanks for the input!
Mud Flaps
60K miles
very rough idle and wont start when hot! jaykudach XJ Cherokee Technical Forum 3 10-12-2009 05:53 PM
Rough idle after start dover21 XJ Cherokee Technical Forum 1 09-17-2009 09:42 PM
Rough idle at start up. JAVS XJ Cherokee Technical Forum 1 08-26-2009 09:58 PM
short rough idle after start up Muddeprived XJ Cherokee Technical Forum 13 08-12-2009 04:42 PM
Rough idle at start-up on 2000 4.0 Dirt Surfer XJ Cherokee Technical Forum 10 12-01-2003 09:04 AM
