rough idle when first start up until warms up. - JeepForum.com
 1Likes
  • 1 Post By vietboysi92
post #1 of 10 Old 07-02-2012, 07:03 PM Thread Starter
vietboysi92
Ok guys need help!! this is my first Jeep (love it by the way).. when i first start my jeep up in the AM. i have to let it warmup and get past the rough loping idle before i drive it, might take 3-5 min to get past it or faster if i rev it up and get it past the cutting out.. if i just start it and try to drive it, it starts sputtering and cutting out real bad.. but once it gets past all the initial crap then it runs great... also if i get past all that and drive it to lets say wal-mart.. which is 5 mins away.. i go inside for maybe 10-20min.. when i come out to my jeep i have to start it up and let it run again past the loping while i load everything up in it.. people think ive got it cammed or a loping V8 in it while its running at first!! lol BTW its the 4.0 no cat.. both O2 sensors are hooked up.. glass pack on it also.. love the way it sounds.. thanks guys and greatly appreciate your help
vietboysi92 is offline
post #2 of 10 Old 07-02-2012, 07:22 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
It sounds like you are describing some sensor issues that occur when the the Jeep switches to closed loop operation.
Test the O2 sensors, they can get old and slow to react. Typical O2 sensor service life is about 100,000-150,000 miles.
Replace the coolant temperature sensor on the thermostat housing.
CJ7-Tim is offline
post #3 of 10 Old 07-02-2012, 07:27 PM Thread Starter
vietboysi92
Ok.. The second o2sensor is brand new.. But the one closer to the motor is older.. I just got the jeep last summer after the tornado.. The second wasn't even hooked up.. Thanks man
post #4 of 10 Old 07-02-2012, 07:51 PM
n5xl
the o2 you want to change is the one closest to the engine.
99TJ,AX15,2"ACOS,33BFGKM2
99XJ,AW4,2"OME,JKSShortArms
98XJ,AW4,3"ACOS/Shackles/AASYE/TomWoodsDS
n5xl is offline
post #5 of 10 Old 07-02-2012, 07:58 PM Thread Starter
vietboysi92
Ok thanks.. Hopefully this will fix it.
post #6 of 10 Old 07-03-2012, 11:12 PM Thread Starter
vietboysi92
Thanks alot guys!! Replaced o2 sensor and it fixed my problem!!!!!
deadcode likes this.
post #7 of 10 Old 07-04-2012, 07:38 AM
Kalali
Glad to hear. Are both O2 sensors the same part?
Kalali is offline
post #8 of 10 Old 07-04-2012, 09:00 AM Thread Starter
vietboysi92
I don't think so.. I only replaced the upstream sensor.. The second one I installed recently..
post #9 of 10 Old 07-26-2017, 09:15 PM
jackson1970
jeep issues
hi i have a 1999 jeep grand cherokee ,idle is rough til it warms up to210 degrees then its fine,i had the oil pan gasket replaced then the next morning wouldnt start,i replaced cranck and cam sensers and coils and plugges fuel pump and regulator and i found one bad o2 by the oil pan where they did oil pan gasket and still runs rough til warm and i also just replaced temp senser and still no fix ,please any ideas??????????
jackson1970 is offline
post #10 of 10 Old 07-27-2017, 05:22 PM
CJ7-Tim
CJ7-Tim's Avatar
I would suppose the Grand Cherokee folks have more info, but I would suspect an O2 sensor issue such as a faulty O2 sensor, an engine wire harness or wire plug damaged by recent repair work, or perhaps a bad O2 sensor fuse.
CJ7-Tim is offline
bucking , misfire , o2 sensor , rough idle , sputering , stall , stalling
Rough Idle After Hot Start -> CEL Jeff9 XJ Cherokee Technical Forum 11 03-22-2010 03:48 PM
Rough idle after start dover21 XJ Cherokee Technical Forum 1 09-17-2009 10:42 PM
Rough idle at start up. JAVS XJ Cherokee Technical Forum 1 08-26-2009 10:58 PM
Hard Start, No Start, Rough Idle Hillbillydeluxe XJ Cherokee Technical Forum 11 09-19-2008 01:11 PM
Rough start - rough idle Primus462 XJ Cherokee Technical Forum 7 06-21-2007 12:40 AM
