Rough idle then smooth? - Page 3 - JeepForum.com
post #31 of 37 Old 01-20-2013, 01:43 PM Thread Starter
svshaw82
1989 XJ Cherokee
What do you mean cascade down with no low spots? Its a direct shot to the TB and same length as old one. Im confused... lol!
svshaw82 is offline
post #32 of 37 Old 01-20-2013, 01:48 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
The factory used hard piping for a reason. The piping has to run downhill from the MAP with no low spots like you can get with flexible vacuum hose. Fuel can collect in the low spot effectively blocking vacuum from reaching the MAP.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #33 of 37 Old 01-21-2013, 01:06 AM Thread Starter
svshaw82
1989 XJ Cherokee
Ok, make sence. Thats interesting. Do you happen to know a part number for a replacement? I know its working somewhat because while the engine is running I can pinch the hose and it dies.
Just finished a few major things tonight...
Fresh oil change
Transmission Filter plus oil change
New fan clutch (old one was bad)
New temp gauge (old one died)
New ground #6 stranded from firewall to fuel rail bolt.
So far she starts right up, and shifting is smooth. Oil pressure is about 35psi to 40psi idle. WOT its around 50psi to 60psi. New fan clutch installed, I hope this starts to get my temp normalized! She ran cold tonight on my 4 block test drive. I dont think she went over 190 degrees. Then again it is only 46 degress outside right now. Will have to see how she does one a warmer day.
svshaw82 is offline
post #34 of 37 Old 02-12-2013, 05:30 PM Thread Starter
svshaw82
1989 XJ Cherokee
So temps are still low... She is still running really rich. Now the stumble is getting worse. Like a dead cylinder. It's happening almost every startup and goes away while driving. Damn near all my ignition components are brand new.
I'm lost guys :-(
svshaw82 is offline
post #35 of 37 Old 02-12-2013, 08:02 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I wonder if your MAP sensor is possibly bad.
post #36 of 37 Old 02-12-2013, 09:17 PM Thread Starter
svshaw82
1989 XJ Cherokee
How can I test it? Use my ohm meter?
svshaw82 is offline
post #37 of 37 Old 02-13-2013, 04:55 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Voltmeter. I don't have the testing procedure at my fingertips.
