Rough idle and terrible gas mileage (worse than before) - JeepForum.com
post #1 of 7 Old 10-25-2013, 01:08 AM Thread Starter
WantMoreOUTDRS
#1 Thank you for your time #2 I searched the site for topics with "rough idle" and got great info. just thought it wouldn't hurt to explain my specific case. #3 I appreciate any, simple or complex, advice anyone will give me. I'm getting into working on my jeep, but im no full on mechanic...
'98 XJ I6 4.0L
192,000 miles
Rough idle the whole time I'm driving. usually dips down to about 600 rpm's when breaking. also makes a jump up from the rough idle to about 1000 rpm's every 2 mins or so. I've recently had the fuel injectors flushed. I pulled out the spark plugs, one of them was bent a bit. So i bent it back, cleaned them all with a bit of gas. the cleaning (and the flushing injectors) helped the problem for about 3 days... then back to rough. ive seafoamed her about 10k miles ago. i added the seafoam thru the brake booster, only. seafoam her again? thru the oil, gas tank, and vacuum hose? i guess ill ask my mechanic to run a compression test? (feedback?)
she doesnt over heat. stays at 210. there are some tiny bubbles coming up in the coolant.
like i said. thank you for your time and just want some help, not to get bashed for making a repeated thread or anything. thanks again.
WantMoreOUTDRS is offline
post #2 of 7 Old 10-25-2013, 07:02 AM
Azzy
Bent it back? Did you properly gap it, or just "bend it"?
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #3 of 7 Old 10-26-2013, 09:40 AM Thread Starter
WantMoreOUTDRS
bent... so now that you said that, i replaced all of them with champion spark plugs. still have terrible gas mileage. someone mentioned to me the ERG valve?
post #4 of 7 Old 10-26-2013, 12:58 PM
xjdantheman
1993 XJ Cherokee
Fuel pressure regulator is my guess. Diaphragm inside is probably leaking gas into the vacuum line. I had on old bmw that ran rich, idled bad and bad mpg, the fps was the issue.
xjdantheman is offline
post #5 of 7 Old 10-26-2013, 02:11 PM
habbyguy
Could be an exhaust leak messing with the O2 sensor (and therefore the computer that sets the fuel injection scheme). Or just a bad O2 sensor (if it's never been replaced, it's loooooong overdue). With the price of gas, it can't hurt to just replace the O2 sensor "just in case"... it'll likely pay for itself in short order even if it wasn't "bad".
habbyguy is offline
post #6 of 7 Old 10-28-2013, 07:36 AM
Azzy
Have you checked your fuel pressure?
Azzy is offline
post #7 of 7 Old 10-29-2013, 12:56 PM Thread Starter
WantMoreOUTDRS
my fuel guage has given wrong reads acouple time. saying theres no gas when i know there is. im guessing this supports the idea that the fuel pressure guage is bad and needs replacing?
