Rough idle, stumble at idle. - JeepForum.com
post #1 of 3 Old 11-09-2009, 08:17 AM Thread Starter
98xjnick
I have a '98 Cherokee with the 4.0, 136,000 miles. I purchased it about 18 months ago and it always had a little vibration/roughness at idle but very minor. Lately it'll stumble in stop and go traffic, usually after stopping for a short time like fueling up. It runs fine at higher rpm and power seems good. I did a tune up about a year ago, and have since checked that stuff over due tracking down another issue that turned out to be a faulty crankshaft position sensor. I also recently cleaned out my throttle body and IAC valve.
I have a scan tool that monitors the computer and my throttle position sensor reads 14.9% angle at idle. Does anyone know if this is normal for our Jeeps? Logically that seems like it might be the issue, but before I shell out for a new TPS, does anyone know any other issues that might be causing this reading, or my problem?
Thanks for the help.
-Nick
98xjnick is offline
post #2 of 3 Old 11-09-2009, 08:24 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
I don't know what the TPS reading should be at idle, but I would get a meter and a manual and perform the recommended testing on that hardware before replacing it. TPS can be tested.
Did your tuneup include plugs, plug wires, cap, rotor?
A bottle of high quality fuel injector cleaner (I like Chevron/Techron) in about 3/4 of a tank of gas is never a bad idea.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #3 of 3 Old 03-23-2010, 03:18 PM
vabeachtennis
-Nick
Did you ever find out what the problem was. I seem to have similar symptoms.
vabeachtennis is offline
no vac leaks - backfire, rough idle, fast idle, slow response alhefner XJ Cherokee Technical Forum 7 09-16-2009 12:58 AM
Wierd miss / stumble at idle? Mike94ZLT1 XJ Cherokee Technical Forum 3 02-23-2009 11:20 PM
rough idle tjfun XJ Cherokee Technical Forum 9 11-29-2007 07:56 PM
stumble at idle myanoch XJ Cherokee Technical Forum 2 12-29-2006 07:35 AM
slight stumble off idle jeeptorino68 XJ Cherokee Technical Forum 3 06-08-2006 03:21 AM
