Rough idle, Low Power, Idle Vacuum Steady 15 inHg - Page 2 - JeepForum.com
post #16 of 18 Old 11-14-2011, 08:16 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
2 seconds isn't too slow.
cruiser54 is offline
post #17 of 18 Old 11-14-2011, 11:35 PM Thread Starter
Double0Jeep
Ok, things are getting interesting now. The Jeep is now running so bad that it is no longer drivable. Good news is I finally got a CEL!
P0400 Exhaust Gas Recirculation Flow Malfunction
That bad news is that the 4.0L does not have an EGR Valve!! What going on here? Has anyone ever seen or heard of this before?
TIA!
Double0Jeep is offline
post #18 of 18 Old 11-15-2011, 01:02 AM Thread Starter
Double0Jeep
TIA!
It looks like this is just a symptom of the low engine vacuum.
P0400-P0405
The PCM tests the exhaust gas recirculation (EGR) system during deceleration by momentarily commanding the EGR valve to open while monitoring the manifold absolute pressure (MAP) sensor signal. When the EGR valve is opened, the PCM should see a proportional increase in MAP.
If the expected increase in MAP is not seen, the PCM notes the amount of error that was detected and adjusts an internal fail counter towards a fail threshold level. When the fail counter exceeds the fail threshold level, the PCM will set this DTC. The number of test samples required to accomplish this may vary according to the amount of detected flow error.
4.0l , low power , rough idle , surging , vacuum
Rough idle, loss of power on acceleration…..but only sometimes. firedoghfd XJ Cherokee Technical Forum 8 12-05-2013 11:49 PM
bogging/no power/rough idle. 87 wagoneer 4.0L pearsonmx6 XJ Cherokee Technical Forum 3 07-29-2011 12:44 PM
no vac leaks - backfire, rough idle, fast idle, slow response alhefner XJ Cherokee Technical Forum 7 09-16-2009 12:58 AM
00 XJ Rough idle and no power? GuitarJer XJ Cherokee Technical Forum 2 08-16-2007 08:32 PM
Rough idle and power loss JEEPAUL XJ Cherokee Technical Forum 0 02-20-2007 01:25 PM
