Rough Idle on '99 Cherokee--TPS - JeepForum.com
post #1 of 8 Old 10-01-2007, 11:16 PM Thread Starter
XJER
My xj is idling wildly at various times for no reason. It will go from almost dying to 2,000+ RPM's. My buddy told me the throttle position sensor. I already cleaned all air intake ducts, changed air cleaner, new plugs and wires. Any other ideas?
Thanks for any response.
XJER is offline
post #2 of 8 Old 10-01-2007, 11:27 PM
BlkBird
Does it continue to do it as you drive it or only at idle? Personally, Im thinking the IAC.
2004 Wrangler X 4.0
2000 Cherokee Sport 4.0
1992 Dakota Sport 5.9
1971 Pontiac Firebird
BlkBird is offline
post #3 of 8 Old 10-02-2007, 12:09 AM Thread Starter
XJER
It does it while driving and idling. I notice it more at idle, but it does it in both instances.
XJER is offline
post #4 of 8 Old 10-02-2007, 07:49 AM
BlkBird
Well, he might be right then. My TJ kinda bucked going down the road when its TPS went south, but I got a CEL immediately though.
2004 Wrangler X 4.0
BlkBird is offline
post #5 of 8 Old 10-02-2007, 07:59 AM
XJAce
My TPS went south long before it threw the code at me. I had to pull the fuse for the transmission so I could manually shift the AW4 and get to the parts store. This lead to the check engine light coming on while I was driving, the engine started to misfire. Put the new sensor on......perfect!!!
"My I-6 feels like it has more balls then your V-8. Too bad the gas guage doesn't say so..."
Attending Morrisville State College to obtain my Bachelors Degree in Automotive Technology
ASE Certified Automotive Technician in May 2010
XJAce is offline
post #6 of 8 Old 10-02-2007, 09:21 AM Thread Starter
XJER
Little bit of a novice here, so what is the IAC and CEL? Thanks
XJER is offline
post #7 of 8 Old 10-02-2007, 09:08 PM
BlkBird
Idle Air Controller, and Check Engine Light
2004 Wrangler X 4.0
BlkBird is offline
post #8 of 8 Old 10-02-2007, 09:19 PM
98redXJ
i had the problem and replaced my distro cap, rotor button, and coil... works much better now.
98redXJ is offline
Jeep Cherokee has rough/low idle and is stalling hotmomma XJ Cherokee Technical Forum 43 01-11-2016 10:05 AM
96 Cherokee rough idle lacks power. 4.0 engine. johnspinner XJ Cherokee Technical Forum 7 03-10-2015 11:52 AM
no vac leaks - backfire, rough idle, fast idle, slow response alhefner XJ Cherokee Technical Forum 7 09-16-2009 12:58 AM
1992 cherokee rough idle - fixed bdhaley XJ Cherokee Technical Forum 0 11-10-2005 03:13 PM
HELP!!!! 91 jeep cherokee 4.0 Extremely Rough Idle dspivey XJ Cherokee Technical Forum 1 04-16-2005 08:09 PM
