Quantcast Rough Country Long Arm kits - Page 21 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Rough Country Long Arm kits
Old 12-04-2009, 03:23 AM   #301
iraqsucks
1994 XJ Cherokee
Originally Posted by cumminsjeep24 View Post
nah man im getting some bad vibes from it being low. I do have shot u joints up front and that could be that problem. but when i take off from a stop the whole jeep shakes like crazy. and its a 4.5" and 33s with an SYE and 6 degree shims. there are no driveline angle problems. also, the fan is now hitting the shroud cause the motor is coming up cause the trans is low
well those pics look exactly like the ones i email ryan at roughcountry. and mine is rolling just like that? i put in a new tranny mount and engine mounts as well. have no problems with my fan hitting? and i have no vibes. i did the sye and tom woods ds. so maybe it is your u-joints? i have no clue tho man. im happy with mine.
iraqsucks is offline   Reply With Quote
Old 12-04-2009, 07:30 AM   #302
cumminsjeep24
1997 XJ Cherokee
Yea I wish mine was fine. If it is the U-joints making the vibes than I have to figure out why the fan is hitting the shroud. maybe ill just take the shroud out
97 XJ. 4.0/5speed/NP231/4.10 gears. D30 open/8.8 spooled. 4.5" lift. RC Long arms, 35" Kevlars, Fox 2.0 Resi, Ruff Stuff, lots of armor, 1 ton, etc etc
97 TJ massive 2.5L engine. 5 speed. cherokee springs up front, skyjacker 7000, 31" BFG mall crawlers.
cumminsjeep24 is offline   Reply With Quote
Old 12-04-2009, 07:38 AM   #303
98muddyjeep
98muddyjeep's Avatar
Yeah I think im looking at a 3 inch lift as well, those coil spacers and snug 32's scream it at me. Also looks like the axle might be a little far forward. No offense, Correct me if im wrong
well if a stock XJ measures from the center of the wheel to the bottom of the fender flare at 17.5" and I measure the same way and come up with 22.5" by my math it seems like I have about a 5" lift in the front,The axle is set at the measurements from the instructions,plus its very close to the original position.
ah,beer the cause of and cure to all of lifes problems ...Homer J Simpson... I am the guy in the red jeep!
98muddyjeep is offline   Reply With Quote
Old 12-04-2009, 08:56 AM   #304
iraqsucks
1994 XJ Cherokee
i definitly would not remove the shroud... jeeps already have enough of a problem staying cool as it is. and its hard to say what your vibes are from without driving the vehicle. you did the SYE and CV driveshaft right?
Old 12-04-2009, 10:43 AM   #305
cumminsjeep24
1997 XJ Cherokee
Yes. And removing the shroud is a last resort. and its not really vibes its more violent shaking that started after I installed the long arms. I had rustys arms on there beforehand and never had any problem like this.
Old 12-04-2009, 11:07 AM   #306
matt62485
how come their site says the 6.5" won't work with the np242? the project i just picked up has a 242 in it. im a complete noob but ive been doing an a$$ of reading over the past 2 days. i know theres difference in the sye/cv setup but why would the long arm kit work?
the 4.5 la on their site just says the sye only works with the 231 which i know, but doesnt mention the "kit" not working with the np242.
anyways i wanna run 33's, been debating on the 4.5 or 6.5 lift. im going to get all the parts ordered such as the cv/sye when i get the kit, is there anything extra i would have to do for the 6.5 over the 4.5?
probably gonna go 4.5 to keep the CG lower but the 6.5 would be sweet with some 33s.
notes from their site....
"""""Notes: • SYE Kit only fits models with NP231 Transfer Case. • 35" tires require minor fender trimming to clear. • Kit does Not fit vehicles equipped with the
NP242 "Select Trac" transfer case. """""""
[]IIIIII[]
matt62485 is offline   Reply With Quote
Old 12-04-2009, 11:15 AM   #307
Muddeprived
I think it's related to the skid plate/crossmember clerances. I'm not 100% though.....
2001 XJ Sport 4.5" RC LA
Custom snorkel
Detours/winch
Flux Capacitor Heat Machine
Muddeprived is offline   Reply With Quote
Old 12-04-2009, 11:19 AM   #308
matt62485
^ hmmm. thanks, ill look into it. hopefully someone can confirm this. i hope the 4.5" lift works, im leaning towards it with some 32s this spring. i wanna go longarm though
[]IIIIII[]
Old 12-04-2009, 11:37 AM   #309
Prosonic
It could also be because they don't offer an S.Y.E. for the 242, and at 6" of lift you would most definitely need one.
Mayhem in potentia
Prosonic is offline   Reply With Quote
Old 12-04-2009, 11:52 AM   #310
matt62485
right. but the way i look at it, RC is just selling the lift kit, i'm getting the sye/cv from tom woods. i wanna make sure the lift works before i get it, not concerned about the sye deal.
even with a 4.5 im getting a sye before i even install the lift. i wanna do this build right.
[]IIIIII[]
Old 12-04-2009, 08:12 PM   #311
iraqsucks
1994 XJ Cherokee
well im positive the arms arent whats causing your vibes. unless you have the lenght of them incorrect. may want to double check it and make sure you are measuring the correct places.
Old 12-04-2009, 08:13 PM   #312
iraqsucks
1994 XJ Cherokee
i run 33x12.50's and i have the 6.5" LA kit. and i had to trim so when im flexed out i could clear my tires...
Old 12-05-2009, 08:59 AM   #313
UltimateCC
I have the 4.5 LA kit on my 95 country with a 242 and it installed no problem. I upgraded the U-joints and so far no need for Hack N Tap.
UltimateCC is offline   Reply With Quote
Old 12-05-2009, 03:38 PM   #314
UltimateCC
quick iphone pick from last night, will get some high res shots hopefully tomorrow...been out ripping around in it today with the snow and its been awesome...rides very smooth
Old 12-06-2009, 06:56 AM   #315
lliamsdad
Hey I've got your 4.5 in rc lift and was wondering. I'm putting 2 in coil spacer and 2 in shackles for a total of 6 and a half in. Will the upgrade perform fine with a setup like this. Will be ordering the tom woods sye/Ds.
96 XJ Country, 4.5 RC, and more
98 ZJ Laredo, Stock
lliamsdad is offline   Reply With Quote
Glock Forum
