Rough Country 3" Questions - JeepForum.com
post #1 of 48 Old 03-08-2010, 10:03 PM Thread Starter
ChiliPepperXJ
2006 WK
So I have been looking at the Rough Country 3" lift (Jeep XJ Suspension Lift), and I noticed it doesn't come with any U bolts. I am driving a 92 Jeep Cherokee Laredo, and I am fairly positive that I have a Dana 35 rear. So now the questions! Do I need to purchase U bolts since they don't come with them? Also, another thing is about the brake lines. Will they need to be extended? I know, lots of questions, I am just hoping I can get some help. I saw somebody say to replace the bushings in the shocks. Should this be done? Thanks everyone!
ChiliPepperXJ is offline
post #2 of 48 Old 03-08-2010, 10:10 PM
Mike95xj
1995 XJ Cherokee
I bought a RC S2 3" lift. u-bolts were never listed but they were still shipped.
95 XJ RC 3" AAL, 31" General Grabbers AT2, RC Shackles, D30 Diff Guard, RC Discos, Baja Lights, Yakima Roof Rack, More coming soon.........
Mike95xj is offline
post #3 of 48 Old 03-08-2010, 10:17 PM Thread Starter
ChiliPepperXJ
2006 WK
Did you order the same one and from them directly?
post #4 of 48 Old 03-08-2010, 10:18 PM
RBxj
Same here with the bolts, but the stock ones should be long enough, they were with my other lift wich was a Skyjacker (two different XJs) As far as the brake lines go they should be fine with a 3". In the front I just moved the bracket where the flex line joins the hard line down about an inch, no problems rear should be ok. I just looked at the ad I believe the ubolts are just considered under hardware.
RB
RBxj is offline
post #5 of 48 Old 03-08-2010, 10:24 PM Thread Starter
ChiliPepperXJ
2006 WK
Oh well good! Thanks for the help! Did you guys order directly from RoughCountry.com?
post #6 of 48 Old 03-08-2010, 10:32 PM
XJ Jay
my 3" AAL lift (not the S2 kit) did not come with rear U bolts, so i reused mine. as for the brake lines, the rear i got a rear brake line from a 95 wrangler, and the fronts i relocated the front brackets down. i got mine from RC
HISWhite 99 XJ Sport
5" RC/ProComp lift, Serious long arms, 33" Cooper STTs, Soft 8s, 4.56s, Aussie locked D30, LSD 8.25,discos, armoured blah blah blah, HP44/9" coming soon
HERSBlack 08 JK Unlimited X, Teraflex 1.5" leveling kit, Rubi coils 35" TSRs and 5.13s
XJ Jay is offline
post #7 of 48 Old 03-08-2010, 10:36 PM Thread Starter
ChiliPepperXJ
2006 WK
So I am looking at the same one, not the Series II.
post #8 of 48 Old 03-08-2010, 11:08 PM
chuckyj95
I just got that kit but I got full spring packs and it came with u bolts. They even sent both dana and Chrysler because I didn't know what I had at the time. I called them direct 10% off if you tell them you are a jeep forum member no questions asked. I got the packs because I got in tho the project and found a broken rear spring.
lift with 30's
Chuck Longwell
Mohawk NY
Looking for my next jeep
2008 Triumph Speedmaster
chuckyj95 is offline
post #9 of 48 Old 03-09-2010, 12:32 PM
ShaneO
I got the 3" and it did not come with u-bolts and mine needed it (that was fun to source on a Sunday for your daily driver) - that means either someone already added a leaf or ??????? Now I'm curious because it looked like a stock spring pack that I took apart to add the RC leaf to. The kit is great and was a breeze to install. XJ Jay nailed with the brake line scenario.
ShaneO is offline
post #10 of 48 Old 03-09-2010, 02:23 PM Thread Starter
ChiliPepperXJ
2006 WK
So where would be the best place to order some U bolts from??
post #11 of 48 Old 03-09-2010, 05:35 PM
Bertamus
1992 XJ Cherokee
The kit should come with them. If it doesn't call them and have them send you some.
92 XJ, 3.5 RC Lift, Full Packs, JKS Discos, IRO Trac Bar, D30 HP, Ford 8.8 w/ discs, 31x10.50 KM2's on D Windows, JCR Front Bumper and Tie-ins, Custom built Rear Bumper, Warn 10k winch
Bertamus is offline
post #12 of 48 Old 03-09-2010, 06:14 PM Thread Starter
ChiliPepperXJ
2006 WK
Im really appreciating all the feedback here you guys!! So, would you guys prefer this lift??
post #13 of 48 Old 03-09-2010, 06:26 PM
blingblong94
1994 XJ Cherokee
i have the RC 3" kit and its worked great for me. my kit didnt come with u bolts so i used some off a 57 chevy, worked perfect!
blingblong94 is offline
post #14 of 48 Old 03-09-2010, 06:49 PM
Telecaster31
i got a rc 3" lift and it may not say anything about them but they will send you everything you will need and no nothing needs to be extended. just put it on and show it off
Telecaster31 is offline
post #15 of 48 Old 03-09-2010, 07:39 PM Thread Starter
ChiliPepperXJ
2006 WK
I have heard that from multiple people saying that all you have to do is call them? From the sounds of it, the customer service is A+
cragar , rough country , rusty's , soft 8 , wheel offset
3" Rough COuntry lift Questions chadwatson326 XJ Cherokee Technical Forum 14 05-14-2009 03:15 PM
Rough Country Comments and Questions Rough Country XJ Cherokee Technical Forum 32 12-14-2008 08:31 PM
3" "Rough Country" Lift Kit questions cheezboy6 XJ Cherokee Technical Forum 7 11-28-2008 10:28 PM
rough country 4.5" kit questions chainbrain2002 XJ Cherokee Technical Forum 8 08-29-2008 02:45 PM
Intstalled 6.5 Rough Country Questions Please blackgnx XJ Cherokee Technical Forum 14 09-26-2006 12:01 AM
