-   -   Roof Rack Measurements for a LJ guy, please (http://www.jeepforum.com/forum/f11/roof-rack-measurements-lj-guy-please-1543342/)
-JD- 06-30-2013 09:03 PM
Hi, folks.
I'm looking to install a roof rack on my LJ's hardtop. One option is the THULE tracks but I'd like to go longer that the longest 60" THULE. A number of folks have used junkyard Cherokee racks.
Does anybody know, or be willing to measure, what the track-length (without end caps) and track-track spacing are for the various generations?
Thanks. Any help will be greatly appreciated.
chris87xj 06-30-2013 11:01 PM
Hey,
The track length on my '96 XJ is 68" w/o end caps. The cross bars are infinitely adjustable along the length. Grab extra cross bars if you see any at the yard. I don't think there was much change to the roof racks across the years of XJ generations but the most signicant change was from 96 to 97 so there is a difference, that's where it'd likely be. Good luck in your quest and may a little bit of XJ live on in your LJ. :tea:
-JD- 07-01-2013 05:52 AM
Originally Posted by chris87xj (Post 15626785)
Hey,
Thanks Chris!!!!
Any idea what the width (between the tracks) is?
I'm trying to hit a specific width (around 46" track-fasteners to track-fasteners) in order to tie in to both shell layers where they are bonded. That will let me know if I can use the factory cross bars or not. I'd certainly pick up the cross-bars if I see them and the width works, otherwise I'll be forced into Thule mounts.
Thanks again.
chris87xj 07-01-2013 11:38 AM
My tracks are at 46" OC (fastener to fastener), which leaves about 45.5" between them.
It seems like this might be a workable solution for you.
-JD- 07-01-2013 03:28 PM
Actually it is just perfect in both dimensions! Thanks again for checking on the width! Now I just need to find one ...
The time now is 02:36 AM.
