Rolls In Park. Bad T-Case or more? - JeepForum.com
post #1 of 23 Old 06-28-2013, 09:59 AM Thread Starter
KevLaredo
1997 XJ Cherokee
I have a bad transfer case and my jeep rolls in park and will not move forwards or backwards in any gear. Makes a horrible grinding noise when I try. Could just the T-case cause this or is my trans more than likely blown too?
1997 Jeep Cherokee XJ Sport
4.0L inline six, 4x4 (obviously)
Thank You
-97 XJ Cherokee Sport. Bone Stock. Inline 6, selec-trac and factory tow package with Chrysler 8.25 Rear. ▀ lllllll ▀
-98 White ZJ Grand Cherokee Laredo. 3.5" Rough Country Lift, Manik Brush guard, Hella 500 Fogs, 31x10.50x15 Cepek Crushers, K&N cold air intake, 4.0L I6, Cobra CB. SOLD
KevLaredo is offline
post #2 of 23 Old 06-28-2013, 10:03 AM
CCKen
CCKen's Avatar
Thank You
Sounds like your tranny went South.
CCKen is offline
post #3 of 23 Old 06-28-2013, 11:23 AM
Paradise XJ
1988 MJ Comanche
Wow, I think I'd do a bit more "diagnostic" inspection before I threw in the towel on your tranny.
Is the t-case in...or in between... neutral and any other gear? 4H or 4L
How do you know your t-case is shot?
If the t-case IS shot why do you think the tranny is too?
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #4 of 23 Old 06-28-2013, 11:26 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
What is wrong with your Transfer Case, and how did you diagnose the failure ? Are you sure the problem/noises isn't because the T-Case is not fully engaged in gear ?
If the T-Case is not in gear, it will grind, the Jeep will probably will not move under power, and the Jeep can roll around by itself when in park.
Edit: I type slowly.
CJ7-Tim is offline
post #5 of 23 Old 06-28-2013, 11:37 AM
CCKen
CCKen's Avatar
If the vehicle 'rolls' in park doesn't that mean the Park Pawl in the tranny is broke?
CCKen is offline
post #6 of 23 Old 06-28-2013, 11:53 AM Thread Starter
KevLaredo
1997 XJ Cherokee
This is what I thought too. I had every gear but reverse and the truck ran and drove until the other day. Reverse made a horrible grinding noise. Every other gear was smooth. Tried to drive it over to my mechanic and shortly after leaving I heard the grinding noise while I was moving forward and the Jeep suddenly acted like it was in neutral in every gear. So I took my foot off the gas and rolled it back downhill (in drive acting as nuetral) to a parking lot and had it towed. I thought my transmission went but my mechanic says the T-Case is blown too. I have no idea. Also the T-Case says 242 J on the id tag. Will an NV242 swap in?
post #7 of 23 Old 06-28-2013, 02:07 PM
sAe23
1995 XJ Cherokee
If the T-case is in neutral, or otherwise broken, the engine AND transmission are disconnected from the wheels, allowing for movement in park and/or non movement in gear...
Fix the T-case FIRST, THEN see what's going on with the transmission.
sAe23 is offline
post #8 of 23 Old 06-28-2013, 02:13 PM Thread Starter
KevLaredo
1997 XJ Cherokee
Thank you. That is my speculation. Any word on what the horrible grinding noise might be?
post #9 of 23 Old 06-28-2013, 02:38 PM
94TwoDoor
1994 XJ Cherokee
Maybe the shift linkage is just snapped and it happens to be stuck in nuetral in the T-case, close enough to engaged to grind when in reverse.
Always verify an expensive or difficult part is really broken before replacing it.
94TwoDoor is offline
post #10 of 23 Old 06-28-2013, 03:30 PM Thread Starter
KevLaredo
1997 XJ Cherokee
That seems likely. I suspect my mechanic may be stupid. Is that something I can inspect without removing the T-Case? If the linkage snapped would I have to replace the whole case?
post #11 of 23 Old 06-28-2013, 03:46 PM
94TwoDoor
1994 XJ Cherokee
The linkage is just a collection of metal pieces that connect the 4WD shift handle inside to the side of the transfer case, look up towards the drivers side of the t-case from underneath with a flashlight while someone shifts the 4wd shifter and you'll see it moving. Just make sure it's actually moving the arm on the T-case. I know mine got pretty rusty and the hinge parts were trashed.
post #12 of 23 Old 06-28-2013, 10:28 PM
AZ Jeff
2014 JK Wrangler
It is VERY unusual for the XC to totally crap the bed. I suspect a misadjusted/broken XC linkage is causing the XC to be partially "out of gear" and thus making the horrible noises.
Adjust the XC linkage per spec. Inspect to confirm the linkage is in good working order. Repair/replace as needed.
if it STILL makes horrible noises, start by adjusting the trans linkage.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #13 of 23 Old 07-01-2013, 10:12 AM
CitadelXJ
The 242 is pretty much the same on jeep vehicles. The j on it stands for jeep. But, they changed the designation from NP242J to NV242. They should be the same thing with the same bolt part if pulled out of an XJ/ZJ/WJ?. The main issue is to double check the input shaft spline count. There are 21 and 23 spline models.
CitadelXJ is offline
post #14 of 23 Old 07-02-2013, 06:37 AM
gs69350
WJ is different, speedo housing and gear not present.
Be sure to check for internal or external yoke.
1998 Jeep Grand Cherokee 5.9 Limited - Stone White - Stock for now.
<-- 5.9 Owner's group on FB.
gs69350 is offline
post #15 of 23 Old 07-02-2013, 07:36 AM
Azzy
If you have not already... Chock the wheels and make sure the parking brake is on. get under the jeep, and find the transfer case selection lever. Physically move it and see if it clicks into gear. (IIRC, pulling it forward and down will make it go into 2WD)
if it does go into gear, your linkage is out of adjustment or shot. The AW4 trans is pretty hard to kill, and generally doesnt grind and die.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
