Roller Rocker Arms - JeepForum.com
post #1 of 3 Old 03-25-2004, 05:57 AM Thread Starter
Jeepomat
Roller Rocker Arms
Hallo
I am new in this Forum and i write from Austria, but my english is not so good,sorry.
Also i am searching for a Roller Rocker Arm Kit for my XJ 242cui 1989.
What does it bring on HP
Where can i by something?
Greetings
Michael
Jeep Cherokee 242cui ,1989, 8,5" Lift , Arb Snorkel, 100%DL, SYE , Long Arms , 33er and many more
Jeepomat is offline
post #2 of 3 Old 03-25-2004, 08:54 AM
75SV1
Originally Posted by Jeepomat
Hallo
Greetings
Michael
Micheal,
I can't comment on what HP this mod offers. Claims from manfactures are 10-25 HP. I do have a set on the Ford 351W, but I can't make any comparision. For the Jeep 4.0L, the selection is limited and relatively expensive. MoPar has a set. They are $120 each and you will need 6 sets (one per cylinder), plus a spacer for the valve cover ($75). Hessco sells a complete set.
http://www.hescosc.com/
At this point it might be your best bolt on option. Still, pricey at $650.That includes the valve cover spacer. Clifford is looking for a distributor. I don't know what price they will be, when available. Crower sells a set ($316). From description some modification to the head is needed (machining). I would guess you would need the valve cover spacer. Theese are rail type rockers. No need for guide plates.
Some say Harland Sharp makes a set for the 4.0, but I don't see it listed on their website. Others reference a website that uses Chevy roller rockers. It takes some machining to adapted the Chevy roller rockers. From what most people say, this modification doesn't produce the power (some say none) for the money involved (and work).
I have looked at other options (Ford Pedistal type), but nothing I can say will work. I think at this point the best option is the Hessco. Most say its the last power mod to be made.
Tom
75SV1 is offline
post #3 of 3 Old 03-25-2004, 05:40 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
As stated above, the roller rockers don't usually produce huge gains. It will allow higher reving, but IMO the cost to result ratio would not be big enough. Just go with a new set of factory lifters, push rods, and if necessary rockers. Then spend the cash you'd save on a better cam that will give you solid gains.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
bent bridges on rocker arms (renix 4.0L) dix0r XJ Cherokee Technical Forum 0 02-11-2010 02:41 PM
torqueing rocker arms with distributorless system.. mrtosh XJ Cherokee Technical Forum 5 04-01-2009 03:01 AM
How do I change Rocker Arms ?? danielhays_98xj XJ Cherokee Technical Forum 14 08-16-2007 11:38 AM
rocker arms and intake bart1 XJ Cherokee Technical Forum 4 05-17-2006 01:16 PM
Benefis of new rocker arms? beckXJ XJ Cherokee Technical Forum 6 02-26-2006 11:09 PM
