Rocks in a can? Aliens? The sky is falling!!! - Page 2 - JeepForum.com
post #16 of 53 Old 08-14-2014, 05:06 PM Thread Starter
citRon
2003 KJ Liberty
Originally Posted by JeepinInJackson View Post
Cancel that man I didn't listen long enough is there a whistling sound too? I swear I think I hear a whistling, between whistling sound and sounding like diesel I'm thinking you've got a cracked exhaust manifold or gasket. Have you checked those yet??
oh yeah- definitely have a cracked manifold- I have a new APN header and a Felpro gasket to install this weekend; I hear the ticking exhaust leak separate- would an exhaust leak cause the low end rattle too?
1996 Cherokee Country 4x4
citRon is offline
post #17 of 53 Old 08-14-2014, 06:23 PM
skyway0018746
I would say so , let us know if its still there after the header change .
7" long arm lift, HNT sye , herculined inside, bush wacker fender flares now geared and locked !!!
62 mm bored throttle body's fs - pm
skyway0018746 is offline
post #18 of 53 Old 08-14-2014, 07:36 PM
JeepinInJackson
1989 XJ Cherokee
Cruisers idea is good too and that's a nice write up/tip you found there cruiser. Your just packed full of useful information aren't you lol
JeepinInJackson is offline
post #19 of 53 Old 08-14-2014, 07:42 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Better to hoard Jeep technical info than old newspapers and the neighbor's mail, I guess.......
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #20 of 53 Old 08-14-2014, 07:57 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
I'm gonna have to borrow that into my sig for a while.
***Chris***
chris87xj is online now
post #21 of 53 Old 08-14-2014, 07:59 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Feel free!! Weird stuff pops into my head sometimes.
Good quote to show the wife, eh?
post #22 of 53 Old 08-14-2014, 09:53 PM
96jeepin
Checked all the pullys? A/c compressor clutch? Water pump going out?
dark green 2004 wrangler
1996 black cherokee
2001 grand cherokee
96jeepin is offline
post #23 of 53 Old 08-15-2014, 12:43 AM
JeepinInJackson
1989 XJ Cherokee
Lol yeah the lack of back pressure due to exhaust leak can cause a rattle or at least it did in buddy's 2000 YJ 2wd 4.0 that old motor of his had one problem after the other. Also how do you add quote into signature?
post #24 of 53 Old 08-16-2014, 12:45 PM Thread Starter
citRon
2003 KJ Liberty
Oil pump!!??
pulleys seem ok. AC kicks on and off as it should. Water pump spins free without any sounds, don't see/smell any coolant from it or the weep hole.
Ok- I'm into this thing right now- intake and exhaust manifold off. Doing rear main seal right now- oil pan is off. Pickup screen is clear. If I tap oon the pickup tube, the sound I heard sounds JUST like tapping against the tube with a wrench!! No marks inside the oil pan, pump looks ok.
Should I change the pump anyway while I'm in here?
citRon is offline
post #25 of 53 Old 08-16-2014, 02:35 PM
skyway0018746
If you have the money I think its a no brainer.
post #26 of 53 Old 08-16-2014, 02:41 PM
skyway0018746
While your down there its not too hard to check the rod bearing to rule that out. If you have the proper tools .
post #27 of 53 Old 08-16-2014, 05:51 PM Thread Starter
citRon
2003 KJ Liberty
the bearing surface of the cap I pulled off to get to the rms has some scoring along it...
citRon is offline
post #28 of 53 Old 08-16-2014, 06:38 PM
skyway0018746
Pictures?
post #29 of 53 Old 08-16-2014, 07:17 PM Thread Starter
citRon
2003 KJ Liberty
sadly, no. I'm just quitting for the day, after starting back at it this morning....it wasn't too bad, but I could catch my fingernail on it...
I think it is possible I found the culprit of the sound. Reminder- when I went around with the stethascope, the sound was strongest and most focused on the right side of the oil pan, right where the pump is. The bracket that holds the pickup tube to the pump was juuuuust loose enough to let the tube swing out of place -which is over and down- about 3/8" inch. I tightened it up and I'm wondering about whether or not to replace the pump, but like I said, if I tapped the tube with a wrench, it duplicated the sound exactly. I think the pickup was hitting the pan!
Anybody ever come across this?!
citRon is offline
post #30 of 53 Old 08-16-2014, 07:27 PM
skyway0018746
It may have been discussed before ... funny how your oil pressure was fine .
