Quantcast rocker gaurds pics needed - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > rocker gaurds pics needed
Old 02-07-2010, 10:23 PM   #1
94xj4x4
1994 XJ Cherokee
any made theyre own rocker gaurds????? if so have any pics i wanna mmake my own what i wanna do is weld to the sub frame and come out and weld to the top of the rockers. if anyone has done this please post pics
A JEEP CAN NEVER NOT BE BIG ENOUGH OR THERE WOULDNT BE A BIGGER LIFT THAN THE ONE YOU HAVE NOW my bluid thread http://www.jeepforum.com/forum/f22/little-green-jeeper-bluid-967561/
94xj4x4 is offline   Reply With Quote
Old 02-08-2010, 12:32 AM   #2
EricsXJ
The Post man
EricsXJ's Avatar
This is probably a little higher up than you are asking but...
Full write-up is here on page 7: http://www.jeepforum.com/forum/f11/time-beef-things-up-build-thread-sorts-540357/
Eric
2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette
My website - EricsXJ.com
EricsXJ is offline   Reply With Quote
Old 02-08-2010, 12:35 AM   #3
94xj4x4
1994 XJ Cherokee
no thats omost execty what i had in my head
Old 02-08-2010, 12:39 AM   #4
94xj4x4
1994 XJ Cherokee
thank you if any one has any more please post pic
Old 02-08-2010, 03:04 AM   #5
93_xj
heres mine.. I cut out my rockers... I used to have these as my sliders, but i cut off the supports that ran to the unibody off, and welded just the "slider" in place.
93_xj is offline   Reply With Quote
Old 02-08-2010, 08:30 AM   #6
94xj4x4
1994 XJ Cherokee
THANKS MORE PICS need more ideas please
Old 02-08-2010, 11:29 AM   #7
Starboard M
This might be a little higher than you want to go, but you asked....
Even with the body line halfway up the door
The framework under the plastic skid(Not finished in this picture)
Originally Posted by NoVaHunter View Post
Honestly, its dicks like you that make unnecessary comments via the internet that have no impact what so ever.
Boatsides/Hybrid Cage/Tube Dash== Custom Winch Bumper== Bolt in HP44
Starboard M is offline   Reply With Quote
Old 02-08-2010, 09:05 PM   #8
94xj4x4
1994 XJ Cherokee
more pics for more ideas would be great
Old 02-08-2010, 09:31 PM   #9
bmyohn
Youngin'
bmyohn's Avatar
I think thats a fairly good range of the different "rocker guards" (more like rocker replacements) out there.
What level of fab skills do you have? Are you looking for pictures of basic bolt on rock rails? Replacements like Eric posted? Or. Full on boatsides like starboard posted?
2001 Dodge Ram 2500 SLT 4x4
5.9L Cummins Turbo Diesel
"The Tow Rig"
1988 Jeep Comanche
2.5L 4cyl - 4 speed manual
2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker
6.5" TnT Customs Longarm Kitl Ford 8.8" w/ disc brakes l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l 35" Maxxis Bighorns l 15 x 8 Cragar Black Soft 8s (4" BS) l High Clearance Shock Mounts l 4 - BAJA off road lights l TnT Customs D30 Truss l Hidden Hitch l ARB Front Diff Cover l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l HP D30 l JKS Mini Skids and Sway Bar Brackets l TnT Customs OTK Steering
bmyohn is offline   Reply With Quote
Old 02-08-2010, 09:39 PM   #10
94xj4x4
1994 XJ Cherokee
well my fab skills are vary high as i used to work at a fab shop bluiding pro-mod drag cars/full tube chaises cars. im kinda looking for ideas on rocker replacements/ rock sliders in one
Old 02-08-2010, 09:40 PM   #11
94xj4x4
1994 XJ Cherokee
more on the lines of like what eric posted
Old 02-08-2010, 10:40 PM   #12
EricsXJ
The Post man
EricsXJ's Avatar
If you go up as high as I did, be prepared to cut about 1.5" off the bottom of your doors. If you go up as high as Starboard M you will need to cut more (obviously).
Eric
Old 02-08-2010, 10:55 PM   #13
94xj4x4
1994 XJ Cherokee
i dont think im gonna go that high to where the doors need cuttin but im def. gonna do the same type deal that you did i like that alot it omost exectly the idea i had in my head
Old 02-08-2010, 11:59 PM   #14
joec89
93 xj... I just got to throw it out there, that "rocker replacement" looks awesome.
joec89 is offline   Reply With Quote
Old 02-09-2010, 03:02 AM   #15
93_xj
haha thanks...
Originally they were custom rock sliders, and mounted under the rocker. You can see in the 1st pic where they used to be mounted to my frame stiffeners..
The sliders came from my buddy, they fit his jeep fine but for whatever reason, they fit crooked on mine and looked crappy.
My drivers side rocker was rock solid, no rust at all. My passenger side rocker was 95% solid, but there was one tiny hole in it. After getting pissed, I just went to town. It was totally on a whim and I kind of winged the whole thing, but I just broke out the grinder and jig saw and welder and went to town..
Hardest part was welding thick metal ( the slider ) to the very thin sheet metal of the rocker...
The jeep was on the lift and we were welding the slider in place along the top seam.. It got so hot on the inside that my amp wire that runs inside along the floor behind the trim melted and cought fire, and cought part of my trim and carpet on fire... The windows were closed on my jeep so we didnt see or smell it initially. My neighbor was chillin in the garage drinking beers and he goes "oh **** your jeeps full of smoke". Had to lower the lift, but the lift lowers a car very slowly, so it burned for probably 30-45 seconds... Good thing someone noticed it because otherwise my jeep would have been a lot worse....
Glock Forum
