Rocker arm replacement - JeepForum.com
post #1 of 8 Old 03-12-2009, 10:48 AM Thread Starter
Chip682
1992 XJ Cherokee
I am going to be replacing my rocker arms soon on my 92 XJ 4.0 I was wondering if anyone that has done this can give me a more detailed explanation than the repair manual. I know it is fairly easy and i have a good idea of how to. The repair book says to bring the #1 piston to TDC and then remove all the rockers a 1/4 turn at a time. Do you have to bring each cylinder to TDC individually before removing the rockers that go to it? That makes more sense to me. I just dont want to mess anything up. Thanks
Chip682 is offline
post #2 of 8 Old 03-13-2009, 10:26 AM Thread Starter
Chip682
1992 XJ Cherokee
Anyone????
Chip682 is offline
post #3 of 8 Old 03-13-2009, 10:31 AM
Vassago
umm i'd be more worried about putting them back in the right way. from what i know. TDC the first one snug tight then 1/4 turn then the same for each cylinder after that. i'll be doing this on sunday when i replace my head so i'll get it down by then
"He almost broke the land speed record in 1977, popular opinion amongst his team was that his beard caused to much wind resistance. He would have shaved it… No, no he wouldn’t have."
MY BUILD THREAD:
My Photography
Vassago is offline
post #4 of 8 Old 03-14-2009, 05:24 AM Thread Starter
Chip682
1992 XJ Cherokee
Thanks let me know how that works out if you could. I just wanted to know if i TDC #1 to get those ones off would i have to TDC #2 and so on to get the others off?
Chip682 is offline
post #5 of 8 Old 03-14-2009, 10:02 AM
AZ Jeff
2014 JK Wrangler
Guys---there is absolutely NO REASON to run the cylinder to TDC before removing/replacing the rocker arms.
The FSM DOES caution to loosen the rocker retaining bolts one turn at a time, alternating back and forth between the pair, so as to prevent distorting the saddle bracket on top of the pair of rockers. Likewise, tightening them is done the same way--1 turn per time, alternating. Final bolt torque is 21 ft-lbs.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #6 of 8 Old 03-14-2009, 10:44 AM
Vassago
ok thats a help for tomorrow, may i ask why you dont need to while assembling???
MY BUILD THREAD:
My Photography
Vassago is offline
post #7 of 8 Old 03-14-2009, 11:32 AM
AZ Jeff
2014 JK Wrangler
I don't exactly understand your question. Please restate it another way, and I will try to answer.
AZ-Jeff
AZ Jeff is offline
post #8 of 8 Old 03-14-2009, 07:01 PM Thread Starter
Chip682
1992 XJ Cherokee
Thanks AZ Jeff I will keep that in mind. I just didnt think it could be that simple.
Chip682 is offline
Rocker Replacement Scott00TJ XJ Cherokee Technical Forum 0 03-20-2009 09:13 AM
Rocker replacement VR6NH XJ Cherokee Technical Forum 0 03-10-2009 10:21 PM
Replacement rocker panels WoodyinTroy XJ Cherokee Technical Forum 2 04-10-2008 07:58 AM
Rocker arm replacement RamboPants XJ Cherokee Technical Forum 2 12-11-2007 02:10 AM
Replacement Rocker Panels rescuejeeper XJ Cherokee Technical Forum 3 09-27-2007 07:11 AM
