Quantcast roaring coming from front end - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > roaring coming from front end
Old 03-12-2009, 04:01 PM   #1
cbordea
98 xj 4x4 completely stock. there is a roaring coming from the front end.
It sounds like I have a set of big mud tires on it going down the highway.
The tires themselves look fine, no bumps, even treadwear.
when you go around a curve it goes away(or you can't hear it).
if you let off the accel, you still hear it, the sound is related to how fast you are going. You still hear it when braking and I don't feel anything unusual in the pedal.
we jacked up the front wheels and they don't spin freely, is that normal?
They don't seem to rock back and forth(top and bottom) too much.
I also noticed there appears to be a leak coming from the "hog head".
Any ideas? I'm going to check the fluid, if it was fluid and it is roaring, is it toast?
my 16you has been driving it and with his music blaring who knows how long it has been going on. I haven't driven it in a month or so.
thanks, for your help
cbordea is offline   Reply With Quote
Old 03-12-2009, 04:20 PM   #2
bikedude189
1993 XJ Cherokee
since it goes away in turns, i would suspect hub bearings. the pinion leak could be unrelated
'93 4X4
AX-15
NP-231
2" LIFT
BFG A/T'S
bikedude189 is offline   Reply With Quote
Old 03-12-2009, 04:50 PM   #3
cbordea
would you expect both to happen at the same time? The noise seems to be evenly distributed to the front, not one side or the other.
Old 03-12-2009, 04:54 PM   #4
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
I would go ahead and pull the front cover, to have a look inside. See if there is an abnormal amount of metal shavings in there. Most likely it is the hub bearings, or a bearing in the diff.
  2. '99 WJ limited, 4.7L, 3" IRO lift. Bilstein shocks, JK rubicon wheels, 255/70/17's, carolina driveshaft, IRO adjustable control arms, IRO adjustable A-arm
xjfever is offline   Reply With Quote
Old 03-12-2009, 05:06 PM   #5
jontz
1995 XJ Cherokee
That's just your badass 4.0L I-6 doing its thing
Originally Posted by BunnyHunterOG View Post
i feel like i didnt deserve it, but still had a seizure
jontz is offline   Reply With Quote
Old 03-12-2009, 05:53 PM   #6
cbordea
LOL, we thought about selling it to get my son something better on gas to drive but I'm not sure anything else could take the abuse!
Old 03-12-2009, 10:29 PM   #7
cbordea
ok, I jacked her up, put her on stands and pulled the drain plug and there was a good sized shaving there and some cruddy silver stuff on the end of the plug so I was thinking oh brother. I pulled the cover off however to find it actually really clean. There was even the red RTV gasket stuff on there like someone had actually changed the fluid before (154k miles).
I spun the wheels with cover off to see if I could feel or hear anything and everything felt and sounded fine. I turned them as fast by hand as I could and couldn't hear anything I thought was unusual. I know I might not even be able to turn it 1mph but everything seemed ok so I started wiggling them. first top and bottom, then side to side. when wiggling side to side I noticed a tie-rod end was loose. I figured it was bad but the nut was actually loose, even with the key through it. I pulled the key out, tightened her up, put the cover back on the diff and filled her back up with fluid.
I drove her down the road and still hear some noise but it isn't nearly as loud. I figure I need to change that tie-rod end and I might as well price and replace the others if the cost isn't too bad. With 154k, it is likely time. Then I'll go get it aligned.
Thanks everyone for your help.
Old 03-12-2009, 10:42 PM   #8
Tweeternpi
Sounds like the Hubs need to be changed.
Tweeternpi
New 2003 Green Tj Rubicon. 4 Inch lift 305/70/16 MTR's Milemarker 8000 winch.
OLD 92 Cherokee Larado. Red and Grey. 7" lift, trim fenders Long arm 4:10 gears with lockers and 35/12.50/15 Toyo AT. So to be parted out to the wifes YJ.
Tweeternpi is offline   Reply With Quote
Glock Forum
