On road/Off road tire pressure - JeepForum.com
post #1 of 26 Old 10-06-2009, 11:22 PM Thread Starter
XJoutlaw
When I go wheeling I always get stuck in the sand we have down here I have brand new Michelin Radial X's on stock rims the tire size is 235. I run at 30 psi on road and off. what is a nice psi to go down to so that I get stuck less but so that I can get on the road and make it to a gas station thats only bout a mile and a half a away to air back up with out killing my new tires? Thanks for the help.
XJoutlaw is offline
post #2 of 26 Old 10-07-2009, 12:42 AM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
when i was in the sand i went down to 15 psi and did pretty good. just dont drive fast or far on the road at that psi.
1990JEEPXJ is offline
post #3 of 26 Old 10-07-2009, 12:47 AM
aircruiser
aircruiser's Avatar
i run 12-15psi on the trails and 32 on road. im always worried as well about running on the road with low pressure. just dont drive fast and you will be fine.
aircruiser is offline
post #4 of 26 Old 10-07-2009, 04:36 AM
scavengerj
Most of my driving is in the sand at the beach. Typically air down to around 20psi. That leaves a little room to go lower if/when needed.
Here are the rules most of us running on the beach follow...
Airing down isn't just about not getting stuck.
Airing down reduces the strain on your entire drivetrain especially the transmission and transfer case. Driving on loose sand with hard tires takes its toll on those components.
There is a way to determine what the optimal tire pressure is for your vehicle:
Perform the following test on a flat, level and smooth surface, fully loaded as you would be for a sand run (gas tank full, passengers, cooler rack etc. included). Measure the vertical height to the bottom of the wheel (rim) from the ground. This is your 100%, street pressure, wheel height. Now reduce this height by 25%. In other words, let out air until your wheel is 75% of the street height. Measure and record this pressure and depending on your vehicle and loading scheme, front and rear tires pressure will probably differ.
This is your optimum sand pressure. This reduction typically results in more than a 250% increase in footprint area. That is like having ten tires where you only had four. This pressure is only valid for exactly what you tested. Change vehicle, tires, wheels or load and you have to retest.
Too low a tire pressure isn't good either . . . The center of the footprint begins to well up reducing the effective footprint and creating a small “traveling hill” in the center of the footprint. This hill offers increased resistance to vehicle movement.
DMS #525
AMSA #1102
OBPA
scavengerj is offline
post #5 of 26 Old 10-07-2009, 06:16 AM
Greenmonster138
Air down off road, Obviously each jeep and tire is different. As scavenger said too low air pressure is a bad thing. Makes a rig unstable.
Greenmonster138 is offline
post #6 of 26 Old 10-07-2009, 08:05 AM
RoyalXJ
i wouldnt air to low w/o bead locks
RoyalXJ is offline
post #7 of 26 Old 10-07-2009, 08:13 AM
lilnapsak
1997 XJ Cherokee
i leave mine at 30-35 on road or off
lilnapsak is offline
post #8 of 26 Old 10-07-2009, 08:18 AM
chevelle4321
chevelle4321's Avatar
1993 XJ Cherokee
And you probably have not been in some loose sand lol or like digging / getting pulled out.
I went down to like 10psi on my 33's last time I was @ Pismo.
1993 Jeep Cherokee 4 door
4.0L HO 5speed, np231
33 x 12.50 GT Radial M/T's on 15x8 Soft 8's
RE 4.5" SuperFlex
AA SYE Installed
Locked front d30 / rear d44
chevelle4321 is offline
post #9 of 26 Old 10-07-2009, 08:27 AM
lilnapsak
1997 XJ Cherokee
well considering im in nj i do alot of NJ pinebarrens sugar sand, quick sand, poop doodoo sinkage muk. getting stuck isnt so bad.. i mean if your alone yeah but with other people its really fun.
post #10 of 26 Old 10-07-2009, 08:53 AM
littlehoov
1986 XJ Cherokee
Just get an inexpensive 12v tire inflator and you wont have to worry about driving on the highway with underinflated tires. Even the little tiny ones work well enough, theyre just slower.
1986 Cherokee 2.8 V6, Torqueflight 904 transmission, NP-228 transfer case. 235/75/15 AT tires. Factory tow hooks...thats about it.
littlehoov is offline
post #11 of 26 Old 10-07-2009, 05:50 PM
jpg0511
1992 XJ Cherokee
Just put in am on board air system. Air down on the trail and air up when your done.
92 XJ 6 1/2 RC lift plus 2in BB, 35x12.5 Mud Rovers m/ts Aussie front D30 and Powertrax locker C8.25 rear, Rusty HD steering, RC control arm drop brackets, Nates rear bumper, HD SYE, YJ brake lines, Transfer skid plate, Nates slim line front bumper, Smittybilt XRC-8 winch, converted A/C to onboard air, Rino lined Floor boards
06 TJ stock gone
08 JK Rubicon 3in Zone lift, 35x12.5x17KM2s 1.5 wheel spacers, Super Chips programmer
jpg0511 is offline
post #12 of 26 Old 10-07-2009, 06:42 PM
MrJCRod
I'm running 33's on 15x8's also and am curious to see what psi you run on the street...
MrJCRod is offline
post #13 of 26 Old 10-07-2009, 07:14 PM
RoyalXJ
easier said then done. shi*t is pricey
RoyalXJ is offline
post #14 of 26 Old 10-07-2009, 08:09 PM Thread Starter
XJoutlaw
Exactly why I haven't done it I know bout it and I am not new to off roading or cars but I am broke.
XJoutlaw is offline
post #15 of 26 Old 10-07-2009, 08:31 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
No sand, and a little larger tire....
street: 24 front, 22 rear.
wheeling: 10 front, 8 rear.
No beadlocks and no problems.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
Road/Tire noise Differential or elsewhere? mfinkler XJ Cherokee Technical Forum 1 05-13-2008 06:37 PM
Tire PSI on road/off road 89Cherokee4x4 XJ Cherokee Technical Forum 2 09-06-2006 11:24 PM
What tire pressure are you running? On road and off MattS XJ Cherokee Technical Forum 25 04-11-2005 08:51 PM
air pressure - on and off road LOCKED UP XJ Cherokee Technical Forum 6 07-02-2003 11:01 AM
tire pressure before off road 94xj1 XJ Cherokee Technical Forum 2 12-16-2002 03:09 PM
