RIP noble Limited, questions for new Rig. - JeepForum.com
post #1 of 19 Old 06-22-2006, 08:45 AM Thread Starter
FSTRDNU
Somebody cut in front of my 88 Limited last week and the insurance company totalled it mainly due to its high mileage, 211K.
Not surprising.
Now I am looking for a new rig and I want to find something that will be compatible with all of the $$$$$$$$ worth of maintenance parts I had put on.
I know the 87-01 were generally the same and most of my parts will cross over but I did the internet mod to convert to increase the size of the gas tank and want to bring that over.
Before the mod, I could barely get 13 gallons in the tank and after the mod I always got 25gals.
There is something about having a 25gallon tank that I dont want to get rid of.
I know that Jeep converted the tank somewhere in the mid 90 where the fuel pump was on top and the tank was made out of plastic.
What year was that exactly?
Also, has somebody figured out how to increase the capacity of the newer tanks?
If not, does anybody know of the older tank can be retrofitted to the newer XJ's.
Also, I know later on the fuel pressure was increased so was wondering if this would preclude putting my older tank/pump combo in a newer Jeep.
I will buy any year XJ as long as I can tell that the previous owners took care of it and everything works but want to make sure that I dont have to redo all of the maintenenace that Ive already done once.
Thanks for everybody's time.
FSTRDNU is offline
post #2 of 19 Old 06-22-2006, 03:17 PM Thread Starter
FSTRDNU
More comprehensive.
Perhaps my post was to verbose so I will consolidate it some.
Will an earlier model XJ tank fit into a later model XJ?
or can the same trick done to the earlier model XJ tank vent tube be done on the later model XJ tank to increase the tank capacity.
Where was the split for fuel tank between earlier metal tanks with the pump access in the front and the plastic tanks with the pump access on the top?
FSTRDNU is offline
post #3 of 19 Old 06-22-2006, 04:04 PM
IrishChef
1988 XJ Cherokee
Oh, not too verbose at all. Perhaps it's the fact that no one cares?
Come and take them.
IrishChef is offline
post #4 of 19 Old 06-22-2006, 04:14 PM
Bowhunter46563
Bowhunter46563's Avatar
The tanks changed in 97
01 XJ/4" lift/33" DC Muds/Sidebiter Wheels/Surco/ Hi-lift/Pilot lights/Bad Apple Fab diff gaurds/Front and rear receiver hitches/Rusty's LCA's/ Magnaflow/Rubi HD Track bar and Brace/Big Daddy tie rod/TB Spacer/Ractive air intake/ Jet Stage 1/Pioneeer & Fusion Sound/AJ's Super rails/Warn Skid /BW Flat Flares/Bedlined Rockers and Quarters
Bowhunter46563 is offline
post #5 of 19 Old 06-22-2006, 04:39 PM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
I would imagine that the pump flanges will be different sizes, seeing as how the pumps are much different. Good luck on that one...
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #6 of 19 Old 06-22-2006, 05:23 PM
Rock Kustoms
Rock Kustoms's Avatar
87-96 are the same
Rock Kustoms is offline
post #7 of 19 Old 06-22-2006, 07:47 PM Thread Starter
FSTRDNU
Thanks (most) of you guys.
I figured it was around those years.
I knew tealcherokee would come through as he helped me years ago when I first got the thing and helped me turn into a reliable backup truck.
Thanks mgertsch and Bowhunter46563, yuur input is greatly appreciated.
IrishChef: Confucious say, Its better to be thought as a total moron and keep your useless trap shut than to open it and remove all doubt.
FSTRDNU is offline
post #8 of 19 Old 06-22-2006, 11:44 PM
Matt Gertsch
www.lp.org
Keep us posted on how it goes. I'm interested in running a larger tank, but for some reason, everyone that carries the high capacity tanks only has them listed for the Renix rigs.
post #9 of 19 Old 06-22-2006, 11:56 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
One of the newer 4wd rags has a listing for a company that makes larger tanks fro the Xj. I'll try to find it tomorrow and post it up for you. It would be either JP or 4wheel Drive and Sport Utility Magazine taht had the small blurp about it in the what's new section.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #10 of 19 Old 06-23-2006, 12:30 AM Thread Starter
FSTRDNU
Same tank as me then.
mgertsch, If my information is correct your 93 should have the same tank as my 88.
Have you seen this link:
http://www.jeepforum.com/forum/newre...te=1&p=2310488
Ive done it, works great, and I went from 13 gallon fillups to 25 gallon fill ups which is why I want to move the entire setup to my new rig.
If it doesnt retrofit Ill be finding a way to modify the newer style tank and Ill see if I remember to keep an update.
So far ive got a bead on a really nice 90 Limited and my trouble will be over.
FSTRDNU is offline
post #11 of 19 Old 06-23-2006, 12:36 AM
Matt Gertsch
www.lp.org
I have a 20.2 gallon tank. I can get about 18.5 into it without topping off. I'm thinking about TIGging up a fuel cell that replaces the back seat. My target volume is 50-75 gallons.
post #12 of 19 Old 06-23-2006, 12:41 AM
Sairys
Location: Troy Michigan, attend college at Mich Tech Univ.
I couldn't imagine having 50-75 gallons with me. I would keep forgetting how much it costs to fill up and drive around aimlessly all day. Then once I got to the pump I'd only put like 5 bucks in to get home.
Sairys is offline
post #13 of 19 Old 06-23-2006, 01:04 AM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Damn!!!!!!!!!!!!!!! How much weight would that translate to anyway?
93 Sport
Specs in Profile.
balloo93 is offline
post #14 of 19 Old 06-23-2006, 02:25 AM
jocww
jocww's Avatar
sellin my 86 if ur intrested
red 86 xj 3.5 superflex with packs, deutush shocks hella 500 fog lights cb radio 31 dayton mud terrains on 15x8 ion wheels custom front bumper with winch and rear tow point
for you myspacers girlscuddlebug69
Bay Area wheelers click this link
TvisXJ Did he just pull a Woo Wong? Chevelle Yea... he just pulled a Woo Wong
Originally Posted by XJIceQueen98
Real women don't drive hummers... they give them
jocww is offline
post #15 of 19 Old 06-23-2006, 02:57 AM
tvisXJ
Recently purchased bone stock silverstone '01 XJ 4.0 4x4. Overland project to come.....
tvisXJ is offline
Many technical questions about 89 Limited BreadnButter XJ Cherokee Technical Forum 18 08-20-2009 11:10 AM
Just bought an '89 XJ Limited...a few questions maalox XJ Cherokee Technical Forum 3 01-23-2007 06:32 AM
90 XJ Limited, Few Questions LukeD XJ Cherokee Technical Forum 1 10-22-2005 09:36 PM
'91 XJ 4wd Limited, Good price? + other misc. questions FASTnSPEEDY XJ Cherokee Technical Forum 6 09-20-2005 05:04 PM
2001 Limited - Questions and help ! creekxj XJ Cherokee Technical Forum 5 12-29-2003 10:40 AM
