Ring gear torque - JeepForum.com
post #1 of 7 Old 02-08-2013, 11:09 PM Thread Starter
Phil12
1990 XJ Cherokee
Ring gear torque
I am replacing the pinion and ring gears in my Dana 35 rear diff. Can anyone tell me the torque spec for the bolts holding the ring gear?
Phil12 is offline
post #2 of 7 Old 02-08-2013, 11:46 PM
MJR
MJR's Avatar
1988
Bolt, Ring Gear 95 - 122 Nm (70 - 90 ft. lbs.)
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
post #3 of 7 Old 02-09-2013, 09:14 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Wondering if you have the measuring tools and instructions to check the pinion depth, bearing pre-load, and set the backlash ? You cannot just bolt in new differential stuff and expect it to fit.
CJ7-Tim is offline
post #4 of 7 Old 02-09-2013, 08:51 PM Thread Starter
Phil12
1990 XJ Cherokee
Yes I do, I do this on larger machinery all the time. Can any one tell me if the inside pinion bearing needs to be installed with a bearing heater or does it just slide on.
Phil12 is offline
post #5 of 7 Old 02-10-2013, 12:22 AM
MJR
MJR's Avatar
1988
Usually installed with a piece of tubing (factory special tool) and a hammer.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
post #6 of 7 Old 02-10-2013, 07:35 AM
foggybottombob
I hammer inner pinion bearings on but I am sure that would be easier if the bearing were heated some.
foggybottombob is offline
post #7 of 7 Old 02-13-2013, 07:16 PM Thread Starter
Phil12
1990 XJ Cherokee
I'm having a hard time getting a chance to work on my Jeep but thought these pictures of the old and new pinion might be interesting. The old ring gear still looks good but I'm changing it any way since I have the new one.
Phil12 is offline
