Quantcast Rigidco winch bumper or C4x4 Tapered winch bumper? - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Rigidco winch bumper or C4x4 Tapered winch bumper?
View Poll Results: Which bumper?
Rigidco winch bumper 25 58.14%
C4x4 winch bumper with tapered ends 18 41.86%
Voters: 43. You may not vote on this poll
Old 02-24-2008, 11:21 AM   #16
XJohnnyC
1992 MJ Comanche
I used to have the older version of the C4X4 winch bumper.
The bumper was actually two pieces. The winch box mounted up to the brackets. It mounted very securely and was pretty beefy.
The rest of the bumper was like a shell that bolted to the winch box. This was not quite as strong as I would have liked.
My question is - Is the newer tapered bumper designed in the same way? Or is it a one-piece?
XJohnnyC is offline   Reply With Quote
Old 02-24-2008, 11:30 AM   #17
andrew2516
The new C4x4 tapered bumper is all one 3/16" piece.
93 Cherokee Sport 4.0
5 speed(ax15), np231
8" Lift
36" TSL's on RockCrawler rims
www.PGHOFFROAD.com
andrew2516 is offline   Reply With Quote
Old 02-24-2008, 11:35 AM   #18
XJohnnyC
1992 MJ Comanche
Thanks.
I'm glad they improved the design. That was my one complaint about the older bumper.
Old 02-24-2008, 04:22 PM   #19
andrew2516
Originally Posted by tntempest View Post
If I were to go with no winch then I would go rigidco nothing looks better, but if you were to go winch go with c4x4, that plate system looks like the harbor freight winch plate. The rigidco plate that has all the extra mounting bolts only attaches to the core support that is 20 gauge steel so it is not adding any strength. The c4x4 becomes a single strong system with heavier metal and internal gussets.
I think the plate that attaches to the front crossmember is just for side to side support. I still think that the rigidco front winch bumper is stronger than the C4x4.
8" Lift
www.PGHOFFROAD.com
Old 02-24-2008, 05:12 PM   #20
tntempest
How do you figure the rigidco is stronger if the plate is thinner and bolted on and does not have any gussets. Have you seen under the C4x4 bumper?
tntempest is offline   Reply With Quote
Old 02-24-2008, 06:40 PM   #21
Topgun514
1988 XJ Cherokee
ridgco is by far stronger in the mounts
but the c4x4 may look better...
you decide, looks or function (i choose function)
87 XJ pioneer-Totalled
96 XJ Sport- Sold
Now: 88 RENIX 4.0 XJ, Project Overlander
3.5" Lift, RE SF LCA's with skids, 31x10.50R15 Duratracs, ARB Roofrack, Custom Bumper, Glasspack, Bored TB, Custom seats
Topgun514 is offline   Reply With Quote
Old 02-24-2008, 06:58 PM   #22
BIGNUTT
Yeah cause the C4x4 has a bulk head and mounts in 19 places like the rigidco riiight? Its well known the rigidcois the strongest mounting bumper out, its fine to like c4x4, but don't go crazy.
I don't see how people think the c4x4 looks better, its a big block while the rigidco actally has shape to it. Its obvious way more time goes into a rigidco than a c4x4 bumper.
[B]CANCER AND LUEKEMIA SUCK[/B]
Proud to be a Christian
BIGNUTT is offline   Reply With Quote
Old 02-25-2008, 12:03 PM   #23
andrew2516
Cancelled my C4x4 order
I'm going with the Rigidco
8" Lift
www.PGHOFFROAD.com
Old 02-25-2008, 12:22 PM   #24
white_elephant
...i like the c4x4 more.....................NOT
1991 jeep yj 2.5
EXPERIENCE ISNT BOLT ON
I DONT GO FAST, I GO ANYWHERE
white_elephant is offline   Reply With Quote
Old 02-25-2008, 01:36 PM   #25
gregmondro
Tell us how you like it when it finally arrives sometime in late 2009
99 Jeep XJ - NP231, SYE, 4.56's, Rear D44 w/ Detroit SoftLocker and a RockCrusher Diff Cover, 35x12.5 BFG A/Ts, RE 5.5" XD Lift, Skidrow TC Skid, ORT Rear Bumper + Carrier, Rigidco Front Winch Bumper + Steering Box Plate, Milemarker 8000 Winch, Rock Sliders, HD Currie Steering, Control Arm Skids, Goferit Tie Rod Flip Insert, Optima Red Top and a few other goodies...
FiveZeroFive
XJ 8.25 Rear End Disc Brake Conversion For Sale!
gregmondro is offline   Reply With Quote
Old 02-25-2008, 01:45 PM   #26
andrew2516
Thats what I hear...I called and got no answer, I'll post up how far he is backed up once I get a call from them.
8" Lift
www.PGHOFFROAD.com
Old 02-25-2008, 02:19 PM   #27
89warwagon
1989 XJ Cherokee
did you have to modify your c4x4 bumper to get it to mount over the c-rock plate?I have the same bumper and always wondered if the c-rock plate would interfere with the bumper "horns".The only thing I can gripe about the c4x4 is the ends are not boxed like the rigidco.I lightly bumped a tree last time out and it bent the corner in a little.Its a good bumper for the price as long as you know how to drive and avoid hitting trees.
89 xj 5.5 rubicon express,34" swamper ltb's
89warwagon is offline   Reply With Quote
Old 02-25-2008, 02:36 PM   #28
andrew2516
Unbolt the side bracket from the bumper and put a 3/16" spacer(washers, steel sheet) behind the bracket.
8" Lift
www.PGHOFFROAD.com
Old 02-25-2008, 03:25 PM   #29
Arcticcat843
dakuda is a god
Arcticcat843's Avatar
1980 CJ5
no all i did was tighten it down. it takes a little work to get on because the brace spreads it apart more but it wasnt to bad. Oh and if i remember correctly, you cant use a spacer on the other side like the guy above said. I know jeepingjason has a writeup and that is how he did it but c4x4 has changed there design and added a bar across there so you have to mount it with horns inside the brackets on both sides....i hope that makes since....
Oh and i plow trees over all the time and have never bent mine. Ive hit trees that i thought we dead and when i hit them it jarred me to a dead stop and it didnt bend....
Arcticcat843 is offline   Reply With Quote
Old 02-25-2008, 03:26 PM   #30
Arcticcat843
dakuda is a god
1980 CJ5
Cant do that on a c4x4 bumper......
Glock Forum
