Right front suspension troubles - JeepForum.com
post #1 of 3 Old 10-11-2012, 06:48 PM Thread Starter
Propane_SC
I've noticed something's wrong with my right front suspension lately and it's getting worse.
I go on trails with my jeep, nothing special, just a little trail next to some train tracks close to where I live. There's bumps and humps, you know, everything that makes a trail.
If I go just fast enough over a bump with my right front wheel will cause a loud thump. Loud enough to cause you to think you broke something. I think it's just the tire hitting the wheel well. But here's the problem I'm concerned with. I can go over the same bump, going the same speed with the left front wheel, and it will not make the same noise. I'm thinking the shock or spring is loose in the right front. If it's not that, then It's because it was in a wreck 2 previous owners ago in the right front; it would be something connected to the axle?
Me and my dad (iSpark; he told me about this forum) took the front axle off (before I noticed the "bumping") and everything like the control arm, and sway bar looked fine, so what else could it be?
This is my first post so if there's any additional information you need just let me know.
-Cheers
2000 XJ Cherokee Sport: Stock everything; 138,800 miles.
(Comin' Soon: 4.5'' lift, with 31'' tires, BF Goodrich All Terrain T/A KO (OR) Firestone - Destination M/T)
Propane_SC is offline
post #2 of 3 Old 10-11-2012, 06:59 PM
Armycherokee
1992 XJ Cherokee
Your not the only one I noticed the same problem with my 92 and I have an aftermarket track bar and when it gets loose I have more noise but when I tighten it it will quiet it down to just a thump it still sounds horrible but from other jeepers I go mudding with they all tell me it's just the Cherokee way they are all loud off road it's just something I had to get used to just check and make sure everything is tight and greased where you can and just take it easy
Armycherokee is offline
post #3 of 3 Old 10-11-2012, 07:28 PM Thread Starter
Propane_SC
Once I get the time, probably this weekend, i'll take the tires off and check them... hopefully tightening them will help.
And by tightening you mean the nuts and bolts that hold the shocks in right?
Edit: Actually looked at pictures of XJ's with everything they're suppose to have on the front, and I noticed I don't have a bump stop.
I'll have to find out where I can get one. Do they come in different variants, like good and bad ones?
shock , spring , suspension
