Reversed Polarity on Battery Install - Now Battery Doesn't Charge - 1989 Cherokee - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Reversed Polarity on Battery Install - Now Battery Doesn't Charge - 1989 Cherokee
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueSteering Stabilizer Brackets...The Original 3/8" Ruffstuff Diff Cover!
Unread 01-16-2014, 11:26 AM   #1
jonnymilano
1989 XJ Cherokee
Let's get this out of the way: I may be one of the dumbest people to work on a vehical, ever. Yep, I installed a battery backwards.
I recently bought a 1989 Cherokee with the intention of fixing/tuning it up. Things were going well until I replaced the battery in the dark. The new battery had the posts reversed on the other side compaired to the old one and I installed it backwards!!!
A few seconds after I conected the terminals, a blue wire on what I think is the starter relay blew up, shot sparks and looked like it was going to catch on fire. I obviously freaked, ripped the terminal off of the battery and said the F word a lot. The mysterious rectangular box with a bunch of wires connected to it lives mounted to a bracket with two screws. It sits pretty close to the battery and the secondary hot wire goes directly from the battery to top of it. The blue wire that is connected to the box (which I think is the starter relay) more than likely leads to the alternator. I can follow it visually with a group of wires to a junction where one way leads to the alternator.
After I installed the battery correctly, patched up the blue wire, and replaced all of the fuses (none were blown but did it anyway) I tried starting the Jeep and to my amazement, it started fine! Everything electrical worked! However, after driving it a little I realized that the battery wasn't charging. After about 3-4 starts it didn't have enough juice to turn over. Busted out the multimeter to confirm. Yep, dying battery. Put a fresh battery in, measured the voltage (12.5 with Jeep off), ran the engine and voltage dropped by about 1 volt. I know that voltage should go up by about 2 volts with the jeep on, so figured that I had fried the alternator with the battery incident. Replaced the alternator last night. Expected it to work, but same effect - no chargey battery!
So, kinda at a loss here. I don't know much about working on electrical systems. Why isn't the battery charging? Should I replace what I think is the starter relay? Is there a better way to tell what blew up? Is there a computer on this vintage and where would it be and how much does it cost? Is it "easy" to replace the starter relay?
I don't really want to take it to the stealership for a diagnostic(?), but may have to at this point because I can't think of what is broken. I'm mad at myself, I did the usual tune up stuff (fuel filter, throttle body clean, sparkplugs) and she was running pretty good. Now this... Thanks in advance for the help!
PS manual transmission and no ABS.
Last edited by jonnymilano; 01-16-2014 at 11:57 AM.. Reason: Realized I was using the wrong terminology.
jonnymilano is offline   Reply With Quote Quick reply to this message
Unread 01-16-2014, 12:40 PM   #2
CCKen
CCKen's Avatar
My 2 cents:
You cooked the alternator. Take it to a shop and have it tested.
If we have data, letís look at data. If all we have are opinions, letís go with mine.
CCKen is offline   Reply With Quote Quick reply to this message
Unread 01-16-2014, 01:42 PM   #3
jonnymilano
1989 XJ Cherokee
Thanks, I will do that. I've already installed a new one though. I think the 'wire' to the starter relay was a fusible link that is still not conducting. I guess that I will try replacing that. Does anyone have a good YouTube tutorial on replacing fusible links? I'm brand new at it. Thanks.
Unread 01-16-2014, 02:10 PM   #4
CCKen
CCKen's Avatar
That Blue wire sounds like a fusible link.
Go here and read about fusible links. They also show repair links available.
http://www.whiteproducts.com/fusible-faqs.shtml
I don't have a Youtuibe link for you.
Unread 01-16-2014, 02:38 PM   #5
uberxj92
1992 XJ Cherokee
Isn't the alternator on the renix a GM? You may have popped the fuse able link that goes there.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline   Reply With Quote Quick reply to this message
Unread 01-17-2014, 12:08 PM   #6
jonnymilano
1989 XJ Cherokee
CCKen, thanks for the info!
uberxj92, in the end it was indeed a $1.05 fusible link all along! I feel like a dummy - guess I'm still learning.. All I had to do was replace the blue 'wire' (fusible link) that fed juice from the alt to the battery. I thought that I had replaced it with a wire, to just test if it was working, but turns out it was a 12" link and ran out of sight (so it was still burnt out). Man, don't I feel stupid. Replaced that link and she's working again! The 26 year old Jeep lives!
As an aside, I have no idea if the alternator is a GM or not. I guess I should hold on to the old one as it's still good. Do you know if it will fit in a lot of vehicles? I'm loving the XJ platform. Will it fit in most of those?
Thanks all for the help!!!
Unread 01-17-2014, 12:41 PM   #7
CCKen
CCKen's Avatar
Good work, and thanks for the follow up.
Hang on to that alternator.
Here's a list of alternator part numbers, by year:
Alternator Part Numbers
1988-1990
JR775127
60 Ampere
JR775126
85 Ampere
53002898
85 Ampere Export
JR775125
100 Ampere
53002897
100 Ampere Export
1991-1993
56005685
90 Ampere
1994-1996
56005685
90 Ampere
56026811
117 Ampere
1997-1998
56005685AB
56026936
1999-2001
56041822AA
Unread 01-17-2014, 01:00 PM   #8
jonnymilano
1989 XJ Cherokee
Thanks again, CCKen! That's awesome!
alternator , battery , ecm , electrical , starter relay
