Quantcast As Requested, Shackle/Spacer Options For An XJ - JeepForum.com
Truck-Lite 7" Round Headlamp Giveaway! - Drive OffRoad Gift Certificate Contest!
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > As Requested, Shackle/Spacer Options For An XJ
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSwag Off Road BIG-HIT TJ-YJ Rear BumperNEW Fawkes modular recovery & bull bar mounts for WJs.
Unread 04-05-2007, 10:13 AM   #1
XJK
The Guru of Nothing
XJK's Avatar
*All Cherokee Shackle/Spacer Options*
This thread will be added as a subthread to my cherokee lift post. But i decided to make it for people because there are many budget options out there to get a 1-2 inch lift without making shock/suspension mods. So here they are, and as always please let me know what im missing or what needs to be changed about the post. Thank you and enjoy.
Shackles
.75"-1" Shackle Options
T&T Customs XJ 1" Boomerang Shackles
Features: Poly-Bushings and a Greasable Outer Sleeve
http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=556
JKS XJ 1" Lift Shackles
Features: Greasable polyurethane bushings, and A strong cross brace to prevent shackle bushing fatigue.
http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=89
Rustys .75" Extended Shackles
Features: Greasable Polyurethane Bushings, Powdercoated Black
http://rustysoffroad.com/mm5/merchant.mvc?Screen=PROD&Store_Code=rustys&Product _Code=SR75&Category_Code=bui
Warrior 1" Lift Shackles
Features: Greasable Bushings
http://www.tellico4x4.com/product_info.php/cPath/3601_3602_3359/products_id/6337
1.25"-2" Shackle Options
T&T Customs XJ 1.5" Boomerang Shackles
http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=557
RE2700 1.25" XJ Lift Shackles
Features: Greasable BUshings and Powder Coated
http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=125
RE2705 1.5" XJ Lift Boomerang Shackles
http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=467
Rustys 1.5" Extended Shackles
http://rustysoffroad.com/mm5/merchant.mvc?Screen=PROD&Store_Code=rustys&Product _Code=SR15&Category_Code=bui
Teraflex 1.5" Shackles
Features: Greasable Bushing Shackles
http://www.trailquest.com/teraflex/xj/rsx.shtml
Currie Enterprises 2" Shackles
Coil Spacers
.75" Coil Spacer Options
Daystar 3/4" Coil Spacers
Features: Use With Or As Factory Replacements
http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=184
RE1333 3/4" Coil Spring Spacers
Features: Replace old isolators with new ones or stack them for added lift
http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=141
1.75" Coil Spacer Options
Daystar 1.75" Coil Spacers
Features: Available in Yellow, Black, or Red
http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=182
RE1334 1.75" Coil Spring Spacers
http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=140
Other Coil Spacer Options
JKS ACOS
Features: Fully Adj Coil Spacers, Minimum Hight 1.25", also Balences Out Uneven Suspension
http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=90
Shackle/Coil Lift Kits
Skyjacker 2" Coil Spring Spacer Lift Kit
Features:Hydro Shocks
http://www.tellico4x4.com/product_info.php/cPath/3601_3065_3067/products_id/18637
Features: Nitro Shocks
http://www.tellico4x4.com/product_info.php/cPath/3601_3065_3067/products_id/18638
Features: No Shocks
http://www.tellico4x4.com/product_info.php/cPath/3601_3065_3067/products_id/18636
Daystar 1" XJ Budget Boost
Features: 1" Greasable Shackles, 1.75" Coil Spacers
http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=183
Teraflex 1.5" Budget Boost
Features: 1.5" Greasable Shackles, 1.5" Coil Spacers
http://www.trailquest.com/teraflex/xj/BB1X.shtml
Thank You For Reading, Hope You Enjoyed
-Kyle
XJK is offline   Reply With Quote
Unread 04-05-2007, 10:18 AM   #2
dopod
Forgot teraflex
edit: teraflex also makes revolver shackles for xj if I remember correctly
dopod is offline   Reply With Quote
Unread 04-05-2007, 10:24 AM   #3
XJK
The Guru of Nothing
XJK's Avatar
Originally Posted by dopod
Forgot teraflex
Added
-Kyle
Unread 04-05-2007, 10:41 AM   #4
VDoubleUVR6
I don't follow the crowd
VDoubleUVR6's Avatar
Throw this in the FA-Q's in the sticky up top.
Good stuff.
I will be going up another inch all around with spacers and shackles and a friend of mine is insisting that I take his old 1" spacer (which we replaced with 1-3/4" this past weekend on his Rubi) but I feel bad not throwing some money at him.
Anyways...the question. When its listed 1" shackle like listed above does that mean a true 1" of lift of 1" longer shackle? Just want to make sure because people talking about doing MJ shackles and Ford Ranger stuff and so on and saying that just because its an inch or two longer doesn't mean they will see that height difference in the vehicle.
Bruno
1998 XJ Sport
My XJ / My old MK3
VDoubleUVR6 is offline   Reply With Quote
Unread 04-05-2007, 10:48 AM   #5
dopod
I think he has them listed as what the makers advertise as true lift height.
Unread 04-05-2007, 10:52 AM   #6
XJK
The Guru of Nothing
XJK's Avatar
correct, i have listed the "advertised" amound of lift that the shackles/spacers provide
i have this thread linked on my "All Available Suspension Lifts" post thats in the FAQ's
-Kyle
Unread 04-05-2007, 03:04 PM   #7
XJH-007
MJ Shackles offer about 1.5" of lift for the XJ.............
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline   Reply With Quote
Unread 04-06-2007, 05:45 PM   #8
sjd78
The "advertised" lift of the shackles isnt always exactly what you get of actual lift. I got RE 1.25 lift shackles with my 5.5" lift and the shackles actually provided less then 1" of lift. EricsXJ has a pic of some shackles on his site that shows the difference in length. The Terraflex shackles actually do give the advertised lift and some have reported a tad bit more then advertised.
1998 Cherokee XJ
AW4,NP231 W/SYE & CV Drive Shaft
D30 W/Detroit, Alloy's & 4.88's, D44 W/Detroit, Alloy's & 4.88's
35" BFG M/T's On 15x8 Soft 8's
5.5" T&T/RE Long Arm Lift, T&T Frame Stiffeners, JKS Sway Bar Dico's, RE Monotube's, T&T Steering Box Reinforcement, and much more!
sjd78 is offline   Reply With Quote
Unread 04-06-2007, 05:55 PM   #9
chance_p
Here is how to figure out how much lift shackles will give you...
As you can see, the stock shackles are 3.125 inches from eye to eye. Shackles will give 1 inch of lift for ever 2 inches longer they are, therefore to determine the actual lift a shackle will give you...
X=eye to eye measurement of lift shackle
(X-3.125)/2 = actual amount of lift gained from shackles.
1999 Cherokee Classic 4.0 aw4 242 30 8.25
3 inch coils, 3.5 inch RE leafs, HnT, 31 inch A/T's, 6.75 components, 1.25 tweeters, 600w 2 channel, 2x 12 inch subwoofers, 1800w mono, 6.5 3 ways
Stroker build/8.8 swap in the works
chance_p is offline   Reply With Quote
Unread 04-07-2007, 07:46 AM   #10
hitech_hick
What about belltech 6400's, give you about 2 inches of lift...
hick
'94 B4000, D35 TTB, Ford 8.8, 35's - Trail Rig
'97 XJ D30, Ford 8.8, 35's - Trail Rig
'98 XJ Limited Stock - DD
hitech_hick is offline   Reply With Quote
Unread 04-07-2007, 07:48 AM   #11
LEAD_NOT_FOLLOW
1989 XJ Cherokee
Rusty's also makes thier own ACOS's...
LEAD_NOT_FOLLOW is offline   Reply With Quote
