Replacing Valve Cover Gasket - JeepForum.com
post #1 of 11 Old 01-30-2007, 06:18 PM Thread Starter
BassAngler
My wife took our jeep in for an oil change, and he said that the valve cover was leaking. So I had her pick up a gasket, so I can change it. How hard is the valve cover to do on a 2000 Cherokee 4.0L, is it pretty straight foward?
BassAngler is offline
post #2 of 11 Old 01-30-2007, 06:22 PM
cmotsvt
Id rank it on par with changing the oil. Although my experience is with renixes, its all the same.
cmotsvt is offline
post #3 of 11 Old 01-30-2007, 06:25 PM
jmundale
1981 J-Series Truck
me and my little sister did my valve cover gasket over christmas, wasnt too bad - the bolts towards the rear of the engine get kinda cramped - also, beware of "German Torque" when you put the bolts back in - Guten Tight ended up snapping one of mine, lucky it was right up front and came out real easy.
live free or die
98xxx, 33's, 4.10's, and plenty of flaky red stuff
jmundale is offline
post #4 of 11 Old 01-30-2007, 06:30 PM
TMCXJ
Pay attention to torgue, you'll be torquing in INCH-pounds, not foot pounds... most folks just tighten "by eye," if that makes sense; you just don't want to crush the gasket and get it squeezing out. The newer vehicles (including yours) have no lip in the head to "crimp" the gasket. But all in all, on a scale of 1 to 10, probably I'd rate it between a 1 and a 1.5.
"...a long habit of not thinking a thing wrong, gives it a superficial appearance of being right, and raises at first a formidable outcry in defense of custom. But tumult soon subsides. Time makes more converts than reason." Thomas Paine
TMCXJ is offline
post #5 of 11 Old 01-30-2007, 06:43 PM Thread Starter
BassAngler
Cool, doesn't sound to bad, what inch pounds do they need to be torqued to.
post #6 of 11 Old 01-30-2007, 06:49 PM
TMCXJ
...crap... I knew you were gonna ask dat...
um, well, the simple answer is that I don't remember off the top of my head, and the year might matter, too, if I recall... I hate to give you the wrong answer, but what sticks in my memory is like 55 in.lbs. for a 2000-2001? Somebody? ANYBODY?!?!
Sorry, I know that's not the kind of answer you're looking for. Hopefully someone will jump in, most likely just "hand tight, don't use a ratchet" kind of answer...
TMCXJ is offline
post #7 of 11 Old 01-30-2007, 07:14 PM
sean87xj
Chilton's says 85in/lb, good luck!
sean87xj is offline
post #8 of 11 Old 01-30-2007, 10:58 PM Thread Starter
BassAngler
Cool, thx guys.
post #9 of 11 Old 01-30-2007, 11:33 PM
BrunoS
85 in lbs is around 5ft lbs.
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline
post #10 of 11 Old 01-30-2007, 11:58 PM
Rescue XJ
Easy as changing a diaper.
White 96 XJ Sport
Jeepforum Minister of Sarcasim
4L HO Command track Dana 30 front Chrysler 8.25 rear CarQuest XD shocks, Federal Signal emergency stuff, MCX 1000 DES-XL, TK-940, Astro Spectra W3 encrypted, Magnaflow 18" body, Medical supplies, MREs, Gatoraid, Shovel, MagLite, body armor, grappling hook, annoying squeeking sound from my door, otherwise stock for now.
White Jeep Club Member #911
Code 3 Jeep Club Member #1
Eagle Scout Jeep Club Member #2
Originally Posted by tx50cj3a
Vatozone.
Originally Posted by 92 Briarwood
I think "that look" is what they teach the chicks in 6th grade when they show them "that film" behind closed doors.
Rescue XJ is offline
post #11 of 11 Old 01-31-2007, 12:02 PM
XJLI
XJLI's Avatar
1993 XJ Cherokee
clean out the crank case vents and hoses with some shop air while the valve cover is off too
Factory Four Link
XJLI is offline
how hard to replace tranny oil pan gasket, valve cover gasket, and oil filter o-rings iwishihad1 XJ Cherokee Technical Forum 4 04-11-2007 07:30 PM
Valve cover gasket Rescue XJ XJ Cherokee Technical Forum 8 10-05-2006 05:39 PM
valve cover gasket MUjeeper XJ Cherokee Technical Forum 4 01-21-2006 06:46 PM
Thoughts on replacing a Valve Cover Gasket... NightWolf0829 XJ Cherokee Technical Forum 22 07-22-2005 11:15 AM
replacing valve cover gasket Bucket110 XJ Cherokee Technical Forum 3 03-09-2004 02:52 PM
