Replacing upper control arms on 95 Cherokee. Question about bolts. - JeepForum.com
post #1 of 3 Old 09-19-2017, 03:14 PM Thread Starter
wannarun
In the process of replacing the upper control arms and bushings. Jeep was in a fender bender couple of years back (not me!) and the bushings are bad. Got them out ok and getting ready to put the new ones in. Just need some advice on whether or not to use the original bolts that held the control arm in or replace them? If replacement is recommended, where do I get them from? Thanks!
wannarun is offline
post #2 of 3 Old 09-20-2017, 10:07 AM
bluejunior
bluejunior's Avatar
It's okay to re-use control arm bolts. As long as they're not rusted away or somehow warped you're fine.
Lifted, Locked, Stiffened
bluejunior is offline
post #3 of 3 Old 09-20-2017, 12:24 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
^^^ Agreed WD40; wire wheel clean up; anti-seize; reuse.....
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
