Replacing Grease Boots - JeepForum.com
post #1 of 4 Old 04-10-2006, 01:14 PM Thread Starter
gregmondro
gregmondro's Avatar
I'm gonna be replacing the grease boots on the XJ this weekend.
Both tie rod ends (pass and drivers side)
and the boot between the draglink and the pitman arm.
any pointers on getting this done? Also, what tool is easiest to get the job done? Last time we did them on the ZJ I had before this Jeep I just used a pickle fork since the boots were toast already. Should I go the same route this time?
one more question - are the boots the same for the tre and the draglink/pitman arm?
I picked up a set of the energy suspension boots a few weekends ago and it looks like it shouldn't be a problem for the TRE's, but i'm not positive about the other
- NP231, SYE, 4.56's, Rear D44 w/ Detroit SoftLocker and a RockCrusher Diff Cover, 35x12.5 BFG A/Ts, RE 5.5" XD Lift, Skidrow TC Skid, ORT Rear Bumper + Carrier, Rigidco Front Winch Bumper + Steering Box Plate, Milemarker 8000 Winch, Rock Sliders, HD Currie Steering, Control Arm Skids, Goferit Tie Rod Flip Insert, Optima Red Top and a few other goodies...
gregmondro is offline
post #2 of 4 Old 04-10-2006, 01:48 PM
ayoung
i usually take the castle nuts off, flip them around, and put them back on till the bolt is flush with the end of it, then take a small piece of wood, put it over the nut, and hit with a nice big hammer....works everytime and doesnt mess up the boots or the nuts
the one up there on the pitman arm can be a real pain, might need a pickle fork for that one, depends on if you anti-siezed it last time you took it out
'94 4.0 XJ 4X4, 4.5" Rustys coils with .75" spacer, rustys 3.5" packs w/ RE 1.25" shackle
Redneck Custom Longarms
33X12.5X15 TSL's on black steelies, PORC SYE with Cherokee front shaft
AJ's Superrails, Diff guards, d30 lockright, d44 rear axle w/ spool, 4.88 gears in both
Flowmaster Super40, Banks Headers, cone intake
ayoung is offline
post #3 of 4 Old 04-10-2006, 02:50 PM Thread Starter
gregmondro
gregmondro's Avatar
Yep, i know exactly what you mean about the pitman arm one. On the ZJ that took a good 10 minutes to get off of there.
No clue on this XJ if it was anti-siezed before though. This Jeep is new to me more or less (only had it about a month now)
post #4 of 4 Old 04-10-2006, 07:23 PM
ChewyXJ
nom nom nom
ChewyXJ's Avatar
If you plan on reusing the joints I'd recommend against using a pickle fork. A tie-rod puller is reasonably priced. Make sure you get full boots. I hate those half sized boots that are all too easy to find. They don't hold as much grease as a greasy guy like me needs.
'93 Cherokee Sport 4.0 man. 4.5" Black Diamond/ O.M.E., JKS control arms, discos, track bar, rear D44/detroit, 35x12.5 BFGmt's,33x13.5 LTBs,AlloyUSA shafts, oba, Warn M8000 multi-mount
'97 Cherokee Sport 5spd,231, white, stock
'90 Cherokee Pioneer 4.0 auto, 6" homebrew long arm lift, 33x10.5 BFG MT's, etc.
'87 XJ 2" lift
'96 XJ stock
"Personally, I've learned so much from my mistakes, I'm thinking of making some more."
"Don't believe everything you think..."
ChewyXJ is offline
Boots or no Boots... shouston75 XJ Cherokee Technical Forum 6 10-02-2008 11:04 PM
new tre boots? bikedude189 XJ Cherokee Technical Forum 1 08-30-2008 06:26 PM
boots or no boots ? romperXJstomper XJ Cherokee Technical Forum 16 03-29-2006 12:45 PM
Tie Rod End Dust/Grease Boots gregmondro XJ Cherokee Technical Forum 5 03-24-2006 05:44 PM
HELP with grease boots spencer411 XJ Cherokee Technical Forum 4 10-24-2005 06:19 PM
