Replacing front & rear differential fluid? - Page 3 - JeepForum.com
post #31 of 39 Old 08-29-2008, 07:16 AM
norsky
Originally Posted by sbxj View Post
[LEFT]
should be done every 60k and you want to change it every time your axles have been exposed to water crossings
Do water crosssings include launching a boat? I have been in some deep launches where my rear axle has been under water. Just curious.
Thanks.
~norsky
White 99 XJ Sport
norsky is offline
post #32 of 39 Old 08-29-2008, 07:44 AM
kadetklapp
1997 XJ Cherokee
Yes. If you submerge the axle then the fluid should be changed shortly thereafter, such as at the end of boating season at the longest.
**1997 Jeep Cherokee SE**
Former Police Car assigned to 54-26, RIP.
kadetklapp is offline
post #33 of 39 Old 09-01-2012, 08:40 AM
roblaza
Again, I'm going to bump a thread that's a few years old...
I want to change the diff fluids. My jeep xj has the class III hitch on it. NoW it says that if it comes with the hitch to use 75w140 inthe rear...But in the rear only? Am I okay to put 75w140 in both front and rear diffs, or should I run 75w140 in just the rear and 75w90 in the front?
I appologize for my new guy questions, I searched and found this thread.
Thanks in advance.
roblaza is offline
post #34 of 39 Old 09-01-2012, 11:50 AM
sbxj
sbxj's Avatar
It has nothing to do with the hitch and it may have been added by a PO.. You can check your build sheet.
You should use 75w140 if you're towing.
It can't hurt to use it in both and I would use Mobil1.
'01 XJ 2DR Sport
'99 WJ Laredo, 4.0L with HID Retrofit
sbxj is offline
post #35 of 39 Old 09-01-2012, 12:58 PM
Kalali
Could someone post how much fluid is needed for the diff drain and fill? Same for front and rear?
Thanks.
Kalali is offline
post #36 of 39 Old 09-01-2012, 01:58 PM
roblaza
I've read it takes 2.5 PTs in the d30 and 3.5 PTs in the d35....so just over 1100 mls in the d30... Correct me if I'm wrong.
roblaza is offline
post #37 of 39 Old 09-01-2012, 03:14 PM
sbxj
sbxj's Avatar
corrected my post to 75w-140w
Fuel Tank
Standard - 15 Gallons (56.8L)
Optional - 19 Gallons (71.9L)
Engine Oil
2.5L (4cyl) - 4.0 Qts (3.8L)
4.0L (6cyl) - 6.0 Qts (5.7L)
Cooling System
2.5L (4cyl) - 9.0 Qts (8.5L)
4.0L (6cyl) - 10.5 Qts (9.9L)
Automatic Transmission
32RH - 17.1 Pts (8.1L)
30RH - 14 Pts (6.6 L)
Manual Transmission
AX5 - 3.3 Qts (3.2L)
AX15 - 3.32 Qts (3.15 L)
Transfer Case
NV231 (Command-Trac) - 2.2 Pts (1.0L)
Front Axle
181-FBI (Dana 30) - 2.5 Pts (1.2L)
Rear Axle
194-RBI (Dana 35) - 3.5 Pts (1.66L)
216-RBI (Dana 44) - 4.0 Pts (1.89L)
'01 XJ 2DR Sport
sbxj is offline
post #38 of 39 Old 09-02-2012, 09:35 AM
roblaza
Much thanks for the info. I had a friend try to tell me that each diff will take at least 4 quarts of fluid....or approximately 6.6pints. I just shook my head in disbelief.
In the d30 and d35 do you have to put in any additives like they Reccomend you do with the d60?
roblaza is offline
post #39 of 39 Old 02-12-2013, 06:08 PM
reeson47
You want to replace the fluid about once a year, but check to see you don't have to replace the differentials, but Eaton is a great brand if you do. http://www.99truckparts.com
reeson47 is offline
Front and Rear Differential leaking fluid -99 Jeep Cherokee Sport Habib66 XJ Cherokee Technical Forum 3 07-20-2009 02:21 PM
Rear Differential Fluid insurrection151 XJ Cherokee Technical Forum 3 04-24-2009 05:17 PM
cost of replacing the rear differential nkjetman XJ Cherokee Technical Forum 3 11-30-2008 05:41 PM
Rear differential fluid change, oops? mtl4life XJ Cherokee Technical Forum 4 06-07-2007 10:03 PM
Front Differential Fluid. insurrection151 XJ Cherokee Technical Forum 20 07-19-2004 06:11 PM
