Replacing front & rear differential fluid? - JeepForum.com
post #1 of 39 Old 03-16-2008, 07:17 PM Thread Starter
Mee_Too
Hello!
I was wondering if anyone replaced the fluid in the front and rear differentials as part of routine maintenance.
The owner's manual for my '99 does not call for it anywhere in the maintenance schedule, only mentions that the fluid should be 1/2" below the fill hole, and that SAE 75W-90 API-GL5 grade gear oil should be used (models with Class III hitch should use SAE 75W-140 Synthetic Gear Lubricant in the rear axle).
Just wondered if this lubricant is expected to hold up for the lifetime of the vehicle. I don't see any type of drain plug on either axle, so guess that only way to change would be to somehow pump out through fill hole.
Any ideas?
'99 XJ -- "BIG GOLD"
Mee_Too is offline
post #2 of 39 Old 03-16-2008, 07:22 PM
murrayman23
1987 XJ Cherokee
to drain the axle you have to take off the axle cover. You should take the cover off and clean out the inside with brake kleen or something.
"Rusty" 1987 Jeep Cherokee XJ. 4.0L. 4X4. NP242. 3.5" RE superflex kit. RE Twin Tube Shocks. Rancho RS5000 Steering Stabilizer. Cragar soft 8's. 31" BFGoodrich A/T KO. Warrior Products Rock Crawler Bumper. Cobra CB. Firestik Firefly antenna. KC Daylighters.Half Herculined Half Navy blue
murrayman23 is offline
post #3 of 39 Old 03-16-2008, 07:26 PM Thread Starter
Mee_Too
Thanks! I'll have to set aside a chunk of time to do that one of these days.
Mee_Too is offline
post #4 of 39 Old 03-16-2008, 07:55 PM
XJK
The Guru of Nothing
XJK's Avatar
It doesnt take that long, nothing to worry about at all.
-Kyle
It's Not Just a Jeep, It's a Lifestyle
XJK is offline
post #5 of 39 Old 03-16-2008, 08:06 PM Thread Starter
Mee_Too
-Kyle
Okay, thanks for the words of encouragement!
It seems strange that changing the fluid is never mentioned at all in the maintenance schedule (of course, come to think of it, I've never seen it mentioned in maintenance schedule of ANY vehicle).
I wonder why...seems like it would eventually break down or deteriorate at some point.
Mee_Too is offline
post #6 of 39 Old 03-16-2008, 08:15 PM
sbxj
sbxj's Avatar
From The FSM
60,000 Miles (96 000 km)
Change engine oil.
Replace engine oil filter.
Replace engine air cleaner element.
Replace ignition cables.
Replace spark plugs.
Inspect drive belt, adjust tension as necessary.
Lubricate steering linkage.
Drain and refill automatic transmission fluid.
Drain and refill transfer case fluid.
Drain and refill front and rear axles.‡
Inspect brake linings.
Lubricate steering and suspension ball joints.
should be done every 60k and you want to change it every time your axles have been exposed to water crossings
If you use a synthetic you could extend it to 120k
'01 XJ 2DR Sport
'99 WJ Laredo, 4.0L with HID Retrofit
sbxj is offline
post #7 of 39 Old 03-16-2008, 08:18 PM
XJ4oh
1997 XJ Cherokee
Also, you do not have to pull the differential covers off to change it.
You can buy a cheap pump from Walmart or an auto parts store and suck the old stuff out, and pour the new stuff in.
When I changed mine it was probaly around 130k or so. It was most likely the origional fluid. It was grey (water/moisture) and smelled horrific.
Its cheap enough and easy preventative matinence.
'97 XJ... 4.0 4x4 AW4. 2" budget boost w/t-case drop.
31x10.5 Cooper Discoverer ST's on 15x7 Cragar Soft 8's.
Intake, Ported TB, TB spacer, Super 40 Flowmaster.
Baja Aux. Lighting.
Green Jeep Club #185, Nowhere to Wheel Jeep Club member #1
'04 WJ - Columbia Edition - 4.7HO 2WD
XJ4oh is offline
post #8 of 39 Old 03-16-2008, 08:36 PM
BigDamnNose
I did mine around 70K miles when I first bought my XJ. The fluid was still clean, no metal shavings, didn't smell burned or anything. I took the covers off so I could replace the RTV around covers to make sure it wouldn't leak.
I decided to replace it with synthetic fluid as I was in the process of changing everything to synthetic. - got a good deal on myoilshop.com . They had quick shipping too.
1998 XJ Classic, Rusty's 2" Rear AAL & 2" Front Springs
ZJ & Comanche Monroe SensaTracs, 30x9.50x15 Kumho ATs
Pioneer Head Unit, Midland CB/FireStik II
JCR Stage One Bumper, Hella 500's
BigDamnNose is offline
post #9 of 39 Old 03-16-2008, 08:58 PM Thread Starter
Mee_Too
OK, that's another thing I wondered about...so RTV sealant is used, rather than a gasket.
Mee_Too is offline
post #10 of 39 Old 03-16-2008, 09:02 PM
XJK
The Guru of Nothing
XJK's Avatar
I use RTV but here is another option.
http://www.jeepinoutfitters.com/scri...?idCategory=98
-Kyle
XJK is offline
post #11 of 39 Old 03-16-2008, 09:05 PM
BigDamnNose
-Kyle
That's a good idea...beats scraping the RTV off the next time.
post #12 of 39 Old 03-16-2008, 09:13 PM
XJK
The Guru of Nothing
XJK's Avatar
To my knowledge they are re-usable which is also a pretty nice benefit.
-Kyle
XJK is offline
post #13 of 39 Old 03-16-2008, 09:14 PM Thread Starter
Mee_Too
-Kyle
Thanks for the link!
Mee_Too is offline
post #14 of 39 Old 03-16-2008, 09:28 PM
sbxj
sbxj's Avatar
-Kyle
I take it those are reusable?
$32 vs $6
if not I'll stick with the blue RTV
'01 XJ 2DR Sport
sbxj is offline
post #15 of 39 Old 03-16-2008, 09:51 PM
87pioneer
I did both mine including transfer case yesterday.A piece of cake... other than the upper two bolts on the front cover are a little hard to get to with a socket.....and the idiot who did it last time thinks everything needs to be torqued at 120ft. lbs. and loctited also...
I try to do it once a year unless a submerge a axle...
87pioneer is offline
Front and Rear Differential leaking fluid -99 Jeep Cherokee Sport Habib66 XJ Cherokee Technical Forum 3 07-20-2009 02:21 PM
Rear Differential Fluid insurrection151 XJ Cherokee Technical Forum 3 04-24-2009 05:17 PM
cost of replacing the rear differential nkjetman XJ Cherokee Technical Forum 3 11-30-2008 05:41 PM
Rear differential fluid change, oops? mtl4life XJ Cherokee Technical Forum 4 06-07-2007 10:03 PM
Front Differential Fluid. insurrection151 XJ Cherokee Technical Forum 20 07-19-2004 06:11 PM
