Replacing floors on an XJ with pics + build thread - Page 6 - JeepForum.com
 2Likes
post #76 of 1123 Old 11-23-2010, 04:29 PM
gonejeepin04220
1995 XJ Cherokee
what do you suggest for a cheap welder? ya know good enough for exhaust and sheet metal. ive heard flux core is kinda junk.
95 xj,5 speed,
5" lift, 33 12.5 dessert dogs
chrysler 8.25,
"my xj is so horny, sometimes im scared itll came right up in a wheelie"
gonejeepin04220 is offline
post #77 of 1123 Old 11-23-2010, 05:01 PM Thread Starter
The_Blacksmith
1993 XJ Cherokee
the hobart handlers are decent for light duty stuff, or look for a used millermatic
The_Blacksmith is offline
post #78 of 1123 Old 11-23-2010, 09:39 PM
96xjmyjoy
That's why I was thinking tying in some of the different points as you've shown with thick rigid pieces. I'm not going to NEED the strength that you are going for either. As long as I maintaibn stock (hopefully I'll be able to gain more) I'd be fine.
If You wouldn't mind can I send you a pm of what I'M working with??
Your project is great though. And if my jeep wasn't a dd I'd be following your lead step by step lol
96xjmyjoy is offline
post #79 of 1123 Old 11-23-2010, 11:04 PM
daurwid
1991 XJ Cherokee
Awesome thread. Subscribed. I need to learn how to use a mig welder...
daurwid is offline
post #80 of 1123 Old 11-24-2010, 12:53 AM Thread Starter
The_Blacksmith
1993 XJ Cherokee
my jeep is my daily, haha im on borowed stuff since i sold my zj.
send the pm for sure. what i was getting at, the first time the unibody flexs, fiberglass will crack and start to fall apart, so it would be all for nothing eventually.
your better action would be a **** load of pop rivets, and sealer,
post #81 of 1123 Old 11-24-2010, 01:02 AM
Climbit
following this on both forums
going to use it as a guide for when I want to tuck my gastank in the rear and rebuild my front floors for a psuedo tummy tuck and front 3 link.
Climbit is offline
post #82 of 1123 Old 11-26-2010, 12:21 AM
96xjmyjoy
For sure with the flexing, I got that. lol what I was getting at is that if I can't dive it I have nothing else to drive lol. Yeah, will send PM more than likely tomorrow.
post #83 of 1123 Old 11-26-2010, 05:35 PM
black954
1978 CJ7
Your progress looks GREAT! I'm doing the exact same thing with my sister's 95' XJ. I only bought the front replacement floor pans, but when I pulled the carpet, there was much much more rot than I had imagined. The entire passenger side was COMPLETELY GONE! Also, the passenger side unibody rail is pretty badly rusted so I have to rebuild that as well. I finished the complete driver side today, about 5 hours total. I used cold galvanize compound inside the unibody rail. I will start on the passenger side tomorrow, but I only have a few hours in the morning free, so it will be a 2 day process. I'm also going to fab up an exhaust heat shield out of some diamond plate aluminum I have to keep the heat off the new floor.
Good luck! It's looking good.
My Jeep build
black954 is offline
post #84 of 1123 Old 11-26-2010, 06:00 PM
little_Jeep
Photos pleeeeeeeeease.......
little_Jeep is offline
post #85 of 1123 Old 11-27-2010, 05:27 PM Thread Starter
The_Blacksmith
1993 XJ Cherokee
lets keep the outside fotos to pm's, i would also like to see this feel free to message me.
did some more work today, got the drivers side rear floor in from the topside, al that seam sealer is really a *****.
its all tached in from the topside, the plate is also cut for the passenger side in the same area. More tomorrow.
post #86 of 1123 Old 11-27-2010, 06:02 PM
black954
1978 CJ7
yep, that seam sealer is a PITA! I used a 7" wire wheel on an electric grinder and it got it off pretty easily. There were little white balls of seam sealer EVERYWHERE though!
How are you attaching the floor to the unibody? I drilled holes every 3" on each side of the rail and plug welded it to the rail flanges. This is about what they were stock.
My Jeep build
black954 is offline
post #87 of 1123 Old 11-27-2010, 06:21 PM Thread Starter
The_Blacksmith
1993 XJ Cherokee
spot welds suck, im welding it all from the bottom up to the rails, much stronger than stock.
post #88 of 1123 Old 11-27-2010, 06:26 PM
gonejeepin04220
1995 XJ Cherokee
man this thrread is gonna be such a huge help. the rail that my driver seat bols on in the front is rottin threw yikes. and the meat whistle that owned if before me welded where they front of the driver seat was bolted.
95 xj,5 speed,
chrysler 8.25,
post #89 of 1123 Old 11-27-2010, 06:35 PM
black954
1978 CJ7
I didn't say spot weld, I said plug weld like factory. The body is supposed to have some flex in it or the sheet metal it's made of would just tear.
My Jeep build
black954 is offline
post #90 of 1123 Old 11-27-2010, 06:44 PM Thread Starter
The_Blacksmith
1993 XJ Cherokee
im much happier with tons of tach welds on the bottom side than plug welds.
the factory design was very, very, very poor.
Replacing floors on a Cherokee mynameismyles65 XJ Cherokee Technical Forum 7 09-10-2011 12:48 AM
My 01 classic build thread/Collection of pics 01ClassicXJ XJ/MJ Cherokee Non-Technical Forum 244 06-08-2011 12:34 PM
Exo cage build thread... .with pics! X2elite XJ Cherokee Technical Forum 28 12-17-2009 05:06 PM
My build thread, LOTS of pics 01LimitedXJ XJ Cherokee Technical Forum 65 02-26-2009 01:56 PM
Jeep build- up thread (pics) Timo_90xj XJ Cherokee Technical Forum 42 07-06-2006 12:57 PM
