Replacing floors on an XJ with pics + build thread - Page 56 - JeepForum.com
 2Likes
post #826 of 1123 Old 12-20-2011, 06:26 AM
Azzy
Originally Posted by The_Blacksmith View Post
I pity the girl who hasnt had sex in my jeep yet.
As for the temps, did you end up going with a high flow rad? Looking at gojeep's page I wonder if those end up not letting the coolant sit against the right surfaces too long and lead to higher temps without a restrictor.
Just something to ponder, Im having the same issue as well.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #827 of 1123 Old 12-20-2011, 06:34 AM
Howard92XJ
1992 XJ Cherokee
Things you dont notice, that it dosent have sway bars front or rear, I REALLLLLY dont know what all these people are whineing about, there was little to no body roll. It must be all these people with ****ty stock suspension who are like, dont do it you'll die. You wont.
Agreed! I'm running no sway bars because my Jeep is not my daily driver, although I do drive it on the road quite a bit. When I had factory control arms, the bushings were junk and the jeep had some body roll. I now have new control arms and it is now tighter than ever. Drives great with no sway bars.
92 XJ 3.5" lift, trimmed fenders, cut & folded lower quarters, 34x10.50 Swampers, JCR Stage 1 front bumper, Stage 2 rear bumper, lots of Herculiner
For Sale:v8 zj draglink, leather rear seats from 95 zj
Howard92XJ is offline
post #828 of 1123 Old 12-20-2011, 01:56 PM Thread Starter
The_Blacksmith
1993 XJ Cherokee
Originally Posted by Danette View Post
I need to replace the floor in my 85 xj would it be easier and stronger to buy the whole rear floor from quadratec then I could just weld it in with a mig welder?
easier yes, stronger, no, not at all. its just the same as factory sheet metal. I went heavier on everything, and just above and beyond anything chryco could have dreamed of.
Thanks Chris!
The_Blacksmith is offline
post #829 of 1123 Old 12-20-2011, 03:10 PM Thread Starter
The_Blacksmith
1993 XJ Cherokee
its all stock replacement stuff. I'm not worried about the temp it stays consistant, but still. I bet when I upgrade to a better water pump itll be lower. its probabaly also the gauge. even tho its a new temp sending unit the stock gauges suck lol
Thanks Chris!
post #830 of 1123 Old 12-20-2011, 04:28 PM
SFRautomotive
#WannaBeRockBouncer
SFRautomotive's Avatar
1992 XJ Cherokee
Originally Posted by El Blacksmith
Things you dont notice, that it dosent have sway bars front or rear, I REALLLLLY dont know what all these people are whineing about, there was little to no body roll. It must be all these people with ****ty stock suspension who are like, dont do it you'll die. You wont..
the body roll has to do with spring rate and shock type/length.
a jeep with stiffer higher rate springs will have less body roll than a jeep with a softer more flexy spring rate.
as in a jeep with 7" RC coils is going to have a TON less body roll than say a jeep running airshocks all the way around.
00XJ limited.....Tons, ORI's, Caged
92xj....Linked, Locked, Caged, Armored...RIP
what are leaf springs?
"You're what's wrong with America. You don't drink enough PBR and you probably run sway bars on the street. Fawking communist."-ibjeepin95
2013 COTY
SFRautomotive is offline
post #831 of 1123 Old 12-20-2011, 04:37 PM
Howard92XJ
1992 XJ Cherokee
It has a lot to do with control arms as well. As I stated above, my jeep had horrible body roll until I installed new LCA's about a month ago. Did not change anything but the LCA's, same springs and shocks. It now has very little/unoticeable body roll.
post #832 of 1123 Old 12-20-2011, 04:46 PM
SFRautomotive
#WannaBeRockBouncer
1992 XJ Cherokee
well sure, if your stuff is very worn then yea.
but actual body roll with a non-worn suspension is caused by the springs and shocks
2013 COTY
post #833 of 1123 Old 12-20-2011, 08:53 PM
Azzy
With all the accounts I have seen, it could be just as bad or worse. I remember some of this from my days building watercooled computers for overclocking... its a matter of keeping the water in contact with hot metal just long enough to pull as much heat from it, and usually too good of a flow means you actually dont pull much heat at all, or get rid of that heat in the radiator.
Unless you start adding sprayers and turbulence to create surface area and such, but I doubt you are cracking the block open for that sort of thing
Azzy is offline
post #834 of 1123 Old 12-20-2011, 10:47 PM Thread Starter
The_Blacksmith
1993 XJ Cherokee
but it goes both ways, if you slow the coolant down you are trapping it in the block longer so one hand washes the other.
Thanks Chris!
post #835 of 1123 Old 12-21-2011, 01:24 AM Thread Starter
The_Blacksmith
1993 XJ Cherokee
got the horn on a button tonight, to the right of the cluster on that useless plastic panel, where I intend on putting some toggles for something. pics tomorrow. I also will be picking up some door locks tomorrow since mine dont work, Gotta figure out what to do about the hatch lock tho, because it wont turn, ****er.
Thanks Chris!
post #836 of 1123 Old 12-21-2011, 01:53 AM Thread Starter
The_Blacksmith
1993 XJ Cherokee
oh and I'm really surprised no one was like OMFG YOU DROVE IT 15 + MILES lol. Seems under whelming.
Thanks Chris!
post #837 of 1123 Old 12-21-2011, 10:27 AM
Azzy
Freakout officially begins at 17.3 miles...
Azzy is offline
post #838 of 1123 Old 12-21-2011, 11:18 AM
Cassafrass
Cassafrass is offline
post #839 of 1123 Old 12-21-2011, 12:18 PM Thread Starter
The_Blacksmith
1993 XJ Cherokee
its pouring so I guess I'm washing it right now, oh and checking for leaks! loll
the roof really needed to be rinsed off, so this helps.
Thanks Chris!
post #840 of 1123 Old 12-21-2011, 06:03 PM
theshaolin
Looking good!!
1996 Cherokee Sport - 4x4 4.0L - Wheeling Project
1986 Mazda RX-7 Turbo - 400RWP project - 2000 Saturn SC1 - Turbo RWD project
1996 Suzuki Bandit 600 - Frame up restore project - Too Many Projects!!
1991 Chevrolet K1500 - 4x4 5.7L 5spd - For Sale (Cheap!)
theshaolin is offline
Replacing floors on a Cherokee mynameismyles65 XJ Cherokee Technical Forum 7 09-09-2011 11:48 PM
My 01 classic build thread/Collection of pics 01ClassicXJ XJ/MJ Cherokee Non-Technical Forum 244 06-08-2011 11:34 AM
Exo cage build thread... .with pics! X2elite XJ Cherokee Technical Forum 28 12-17-2009 04:06 PM
My build thread, LOTS of pics 01LimitedXJ XJ Cherokee Technical Forum 65 02-26-2009 12:56 PM
Jeep build- up thread (pics) Timo_90xj XJ Cherokee Technical Forum 42 07-06-2006 11:57 AM
