Replacing floors on an XJ with pics + build thread - Page 4 - JeepForum.com
 2Likes
post #46 of 1123 Old 11-19-2010, 07:47 PM
Hussler
1992 XJ Cherokee
Did you ever fix the hole in the frame?
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #47 of 1123 Old 11-19-2010, 08:10 PM
thakoolaidkid
So you removed the flooring which included the rear leaf mounts, correct? I think I'll need to replace my rear mounts after this winter and I just wanted to hear how you set up the leafs since they aren't connected.
'96 ZJ: Sold.
'94 XJ: Sold for scrap.
'01 TJ: Back in a Jeep after 3 years!
thakoolaidkid is offline
post #48 of 1123 Old 11-19-2010, 10:57 PM Thread Starter
The_Blacksmith
1993 XJ Cherokee
I'll get some pics of this soon, i plated way past it forward and all the way to the channel on the back where the bumper mounts on the bottom.
I'm doing the same thing on both sides, but wanted some more floor to be in before I start putting those in, as its all underneath work.
I jacked everything and squared it before I welded on the bottom plate.
no, the leaf mounts dont connect to the floor, the floor is over them, but they dont really tie into it, its a pretty poor design.
The metal you see across the back is 3/16th plate, it ties both leaf mounts, back to the unibody main channel and the whole back of the rig, making it atleast 100 times stronger than the original design.
Plus its completely welded in every place i could get the welder to the 3/16th plate from the bottom up.
Anything I replace I tend to upgrade, to save a pain in my *** down the road
The_Blacksmith is offline
post #49 of 1123 Old 11-20-2010, 08:23 AM
delkancott
Very nice. Keeping my eye on this thread as without looking under the carpet I already know of one circular rust spot felt/seen through the drivers side foot well.
delkancott is offline
post #50 of 1123 Old 11-20-2010, 10:21 AM
Riley/MN
When I look up at the bottom of my DD Jeep while it is on the lift, almost all I see is the back of carpet, but with 419K I don't think I will bother.....
I do have a '93 sitting in the yard though, low miles but a bad case of cancer...
~Riley
TMA MN State Rep
http://www.traditionalmuzzleloadingassociation.com
Riley/MN is offline
post #51 of 1123 Old 11-20-2010, 06:40 PM Thread Starter
The_Blacksmith
1993 XJ Cherokee
419k dosent mean much to metal, just to the running gear. pick the best shell and fix it.
got alot of welding done today. I dont care about it being pretty, im going to be grinding them down a little and hercing over it all anyways.
(pic at bottom)
the only welding left from the top side in the back is the wheel tubs, and trying to figure out what im going to do for the corners of the floor. Everything else in the cargo area is from the bottom up.
I've been using all 14 gauge in the cargo area, except for the 3/16th across the back.
tomorrow night i should be getting some primer in some places, it just makes it hard to weld things.
post #52 of 1123 Old 11-21-2010, 03:35 PM
gonejeepin04220
1995 XJ Cherokee
wow this is awesome!
95 xj,5 speed,
5" lift, 33 12.5 dessert dogs
chrysler 8.25,
"my xj is so horny, sometimes im scared itll came right up in a wheelie"
gonejeepin04220 is offline
post #53 of 1123 Old 11-21-2010, 04:46 PM
maxwedge
It looks good but you have to spot weld it to the unibody or it will be totally worthless as far as having any amout of strength.You can put all sorts of heavy steel together but if you dont have it connected to a foundation it will be worthless.Name:  icon_welder.gif
Size:  16.6 KBName:  manny.gif
Size:  528 BytesName:  sad6.gif
The GENERATION OF TODAY seem to be Lacking PRIDE ,and COMMON SENSE.
maxwedge is offline
post #54 of 1123 Old 11-21-2010, 04:58 PM
gonejeepin04220
1995 XJ Cherokee
Originally Posted by maxwedge View Post
It looks good but you have to spot weld it to the unibody or it will be totally worthless as far as having any amout of strength.You can put all sorts of heavy steel together but if you dont have it connected to a foundation it will be worthless.Attachment 165336Attachment 165337Attachment 165335
im sure he plans to weld it to the unibody.. durr
95 xj,5 speed,
chrysler 8.25,
post #55 of 1123 Old 11-21-2010, 06:01 PM
maxwedge
Gonna be quite hard to see it when its all coverd up . Maybe he does but won't it be easier to do it from the top so the heat from the welder wont just burn up the old metal,a bit more work but he doesnt seem he mind ,cause it's a fine job begin done.--------But you seem to have some sort of speech problem gonejeepin04220(DURRRR) I can understand your problem now with the 420 refurance.So please stay out of a question that isn't asked to you,and you have no knowledge of.-------- This just a question for you alice cullen thats all Sorry it was interupted by gone jeepin he'can help himself.I think it looks great.
maxwedge is offline
post #56 of 1123 Old 11-21-2010, 06:47 PM Thread Starter
The_Blacksmith
1993 XJ Cherokee
spot welds are garbage and half the reason the floors rot out so badly.
Ive completely tached the floor to every piece of unibody underneath
heres a few fast, **** pics to show that, I'll probabaly go back thru and turn those all into full beads.
(pics a the bottom rehosted via jeepforum)
and now I have one coat of rusty metal primer on everything.
Tomorrow I'm going down there to clean dirt out of areas dirt shouldnt have ever been, so i can finish up the back area, and move forward.
post #57 of 1123 Old 11-21-2010, 06:58 PM
USAFRecon
Crawled
USAFRecon is offline
post #58 of 1123 Old 11-21-2010, 07:16 PM
KINGJB
I like metal
Build Thread:
KINGJB is offline
post #59 of 1123 Old 11-21-2010, 07:24 PM
silbotta
looking good blood sucker
94 YJ
06 Cummins
silbotta is offline
post #60 of 1123 Old 11-21-2010, 07:42 PM Thread Starter
The_Blacksmith
1993 XJ Cherokee
next on the agenda is going to home depot and buying a face shield, and some goggles so i can crawl under this thing and wire wheel everything that exists.
The entire bottom of the jeep is getting painted with chassis saver + monstaliner
Replacing floors on a Cherokee mynameismyles65 XJ Cherokee Technical Forum 7 09-09-2011 11:48 PM
My 01 classic build thread/Collection of pics 01ClassicXJ XJ/MJ Cherokee Non-Technical Forum 244 06-08-2011 11:34 AM
Exo cage build thread... .with pics! X2elite XJ Cherokee Technical Forum 28 12-17-2009 04:06 PM
My build thread, LOTS of pics 01LimitedXJ XJ Cherokee Technical Forum 65 02-26-2009 12:56 PM
Jeep build- up thread (pics) Timo_90xj XJ Cherokee Technical Forum 42 07-06-2006 11:57 AM
