Replacing floors on an XJ with pics + build thread - Page 10 - JeepForum.com
 2Likes
post #136 of 1123 Old 12-12-2010, 11:47 AM Thread Starter
The_Blacksmith
1993 XJ Cherokee
Originally Posted by thakoolaidkid View Post
So you just chopped off the rear lower quarters? Any pics of that?
not yet, i will have pics of it soon. yes, and isntead of going at the seam where people fold, i went above it. the floor will stay more level in that area if you cut at the seam instead of above it, it will probabaly be a little easier that way aswell.
Thanks Chris!
The_Blacksmith is offline
post #137 of 1123 Old 12-12-2010, 12:25 PM
thakoolaidkid
Cool, looking forward to seeing that. Was the insulation inside the XJ attached to the body panels? My rear lower quarters were shot so I went to cutting them completely out and replacing with riveted new metal (no welder) and I looked inside and it was straight in to insulation. So was just wondering if that was attached or a separate piece to disassemble.
'96 ZJ: Sold.
'94 XJ: Sold for scrap.
'01 TJ: Back in a Jeep after 3 years!
thakoolaidkid is offline
post #138 of 1123 Old 12-12-2010, 02:02 PM
Millermagic
Originally Posted by Alice_Cullen View Post
annndddd my holy grail. screw folding the rear corners, and dealing with pop rivets, sealer, and other amatuer methods. do it right, do it once.. profit.
One of the XJs I was looking at had a few holes in the floor. I was going to fix them with a coffee can, caulking and pop rivets.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #139 of 1123 Old 12-12-2010, 04:35 PM
Rob K
1995 XJ Cherokee
Millermagic. If you have the time and means, fix it right. Clean and paint what floor you have left, inside and out. It won't long before your dealing with a major problem.
When I bought mine it had a little rust on the passenger floor pan. Within a years time a hole had developed in it. Within 4-5 years all the floor pans were completely rusted and mostly gone. I had screwed sheet metal to the bottom to patch the holes and seal the seams to no avail. The floor just kept on rusting between the carpet and sheet metal I installed over the rusty floor. When they start they go real fast. A lot of the rusting goes on from the inside out. Pull that carpet and see what it looks like.
Wish I would have done something more permanent sooner. Now I'm looking at nearly an entire floor replacement like the one in this thread.
I just typed all that and realized you said you were looking at one that holes in the floor. Oh well, someone will learn a lesson from my mistake.
Rob K is offline
post #140 of 1123 Old 12-12-2010, 07:14 PM Thread Starter
The_Blacksmith
1993 XJ Cherokee
some jeeps have that some dont, this one didnt, the 97 i pulled parts from did.
did some more work today in the rain.
hard to tell but everything around the shackle mount is all boxed and tied to that 3/16th plate that goes from shackle mount to shackle mount across the back
Also this is one side of the frame rail patch, theres a plate welded on the bottom, the bottom edge of this side plate is rolled under and welded (needs to be ground badly, but its in there, i was able to get both shackle bolts loose, they are IN THERE. pipe and short turns.
the hole was done with 4 drill holes and a cut off wheel. im happy with it.
Thanks Chris!
post #141 of 1123 Old 12-13-2010, 09:53 PM
Raven_Rage
1995 XJ Cherokee
They look awesome. Jeep is ironman strong
Raven_Rage is offline
post #142 of 1123 Old 12-14-2010, 08:35 AM
Ahren
I tought my self to weld 6 years ago. welding is the handiest skill to have ever and if your any bit creative you can biuld some great stuff
jeep lookin great
SPARK ON
cannibals wont eat clowns
they taste funny
Ahren is offline
post #143 of 1123 Old 12-14-2010, 01:41 PM Thread Starter
The_Blacksmith
1993 XJ Cherokee
its so depressing, we've gotten a bunch of snow the last 2 days, and my jeep, is sitting outside, unfinished, probabaly full of snow.
my wife got me all this cool jeep **** for xmas, and it dosent even look like I'll be able to use the thing.
Thanks Chris!
post #144 of 1123 Old 12-14-2010, 06:55 PM
GregB_00XJ
Looking more gooder man...nice job. I cant imagine that getting those bolts inside there was much fun. lol
- 2005 Jeep Grand Cherokee LTD 5.7L WK -
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline
post #145 of 1123 Old 12-14-2010, 08:42 PM
XJcruiser
Just a thought here, but you are installing the same life I have and I think you will eventually want to do a shackle relocation because the 4.5" leafs are pretty short. Rather than adding a bracket later, maybe you should rebuild the shackle box right now while you have easy access. Then you will have corrected the shackle angle possibly without having to add height.
XJcruiser is offline
post #146 of 1123 Old 12-14-2010, 10:39 PM
Rob K
1995 XJ Cherokee
I think relocation brackets would be a good idea for anyone installing new springs. You'd be able to adjust your shackle angle. I just installed some Crown heavy duties and they were shorter than the originals. Ended up with a near vertical shackle angle.
I agree, if one had the time and means it would be a good idea to beef up the hangers. He's working outside in the winter though. I done a lot of that. It's no picnic.
Rob K is offline
post #147 of 1123 Old 12-14-2010, 11:54 PM
Climbit
x2 on relocation.
you can make your own or get the HD offroad engineering ones. Brian over on NAXJA sells them.
Climbit is offline
post #148 of 1123 Old 12-15-2010, 01:04 AM Thread Starter
The_Blacksmith
1993 XJ Cherokee
i saw the HD ones. like 200$ is insane, but i guess if you have the market cornered.
After the work i did to re enforce that shackle box, i doubt ill be redoing it again.
Thanks Chris!
post #149 of 1123 Old 12-15-2010, 05:03 PM
Rob K
1995 XJ Cherokee
Big$ Exactly why I am living with my shackle angle. I'd invest in a welder before I bought those.
Rob K is offline
post #150 of 1123 Old 12-15-2010, 05:09 PM Thread Starter
The_Blacksmith
1993 XJ Cherokee
were way off topic, but whatevers, this shackle angle thing has got me thinking, after spending 6 hrs with brush/ rollers and rattle can rustoleum on an unrelated project, without doors open. (maybe im high?) i didnt take any breaks haha.
What if i made like boomarange shackles? is it possible to correct the angle, without gaining much if any height from a boomarang?
Thanks Chris!
Replacing floors on a Cherokee mynameismyles65 XJ Cherokee Technical Forum 7 09-09-2011 11:48 PM
My 01 classic build thread/Collection of pics 01ClassicXJ XJ/MJ Cherokee Non-Technical Forum 244 06-08-2011 11:34 AM
Exo cage build thread... .with pics! X2elite XJ Cherokee Technical Forum 28 12-17-2009 04:06 PM
My build thread, LOTS of pics 01LimitedXJ XJ Cherokee Technical Forum 65 02-26-2009 12:56 PM
Jeep build- up thread (pics) Timo_90xj XJ Cherokee Technical Forum 42 07-06-2006 11:57 AM
