Replacing floors on an XJ with pics + build thread - JeepForum.com
 2Likes
post #1 of 1123 Old 10-31-2010, 09:23 PM Thread Starter
The_Blacksmith
1993 XJ Cherokee
okay, so before I get flamed. the jeep is very solid on the outside, rockers and pinch seams solid. Floors were shot, so I decided to replace them.
I dont have alot of pics at the moment, because I wasnt going to do this thread.
Basically, remove your stock carpet and padding, because its a sponge, and throw it away forever.
To do this, you remove the seats, and center consoul.
Next grab a big shop vacuum, and start sucking up all the loose crap.
this isnt the jeep i started with, but this is how ALOT of xjs look without the carpet, when they have rust.
Again THIS IS NOT THE JEEP IM WORKING ON, its an old one i had. the one im working on has better floors, and body in general, i just didnt take progress pics, and happened to have these FOR REFERENCE.
basically what your rear floor probabaly looks like.
front floor wells
so start cutting that rust out,
now, you have to clean all that out, get a welding hammer/pick and knock all the loose rust off the channels, get all the old floor off the top of the unibody rails, there are also spot welds you will have to grind down flush.
all this was done with cut off wheels on a grinder, a grinder, and a hammer / shop vacuum.
Again that wasnt the jeep im working on.
Now, onto the jeep im working on, once everything was cut outt, fully cleaned and wire wheeled. i decided to paint the u channels from the inside out. I'm using rustoleum red primer, I will be going over this all with a second coat, and then with rustoleum paint before the new floors go.
Now to all the nay sayers, who are like "oh go buy another jeep blah blah.
pre 96 xjs are high mile junk everywhere, and id rather not spend all my money replacing driveline parts, when floors are cheap and easy.
I'm going to take the time to use 3/16th plate over where the leafs mount front and back, and by tieing that all in, making the mounts straonger than they ever were.
I'll post more pics, and hopefully when im done this will serve as a very nice how too for people.
Its not as bad as it looks, its not that much work if you can weld, and cut metal.
For reference, all the metal i bought for the floor
8 sq ft of 18 guage steel - 60$
i also bought 15' of 3/16th x 5'' plate for 45$ (im building recovery bumpers aswell)
so if you figure in 100$ worth of materials + time, not counting paint. You'll realize this is worth it on a budget.
The_Blacksmith is offline
post #2 of 1123 Old 10-31-2010, 09:30 PM
4.0H.O.XJ
I agree, do this right and it will be stronger than it ever was from factory.
Good lord, please let me see a welder in your next installment. I dont think I can handle watching another floorpan "repair" thread utilizing old coffee cans, pop rivets, bondo and herculiner ever again.
Subscribed. Looking like a proffessional repair job thus far. May I suggest frame stiffeners while your at it? Looks like a good time to get at that too, and youll never have more easy access to everything again once you button it all up.
4.0H.O.XJ is offline
post #3 of 1123 Old 10-31-2010, 09:31 PM
Raven_Rage
1995 XJ Cherokee
definitely worth it
great post
Raven_Rage is offline
post #4 of 1123 Old 10-31-2010, 09:31 PM
mattman8706
mattman8706's Avatar
2009 JK Wrangler
wow that is a lot of rust.
looks like a fun project.
-Matt
mattman8706 is offline
post #5 of 1123 Old 10-31-2010, 09:34 PM Thread Starter
The_Blacksmith
1993 XJ Cherokee
i have cofee cans, but wont be using them haha
Its been fun so far. im going to fully weld the panels to the unibody channels from the bottom up. I'm going to seam weld down the unibody rails to the floorpans instead of crappy spotwelds.
Whatever jeep used for seam sealer is tough stuff, but it dosent do crap for rust prevention
post #6 of 1123 Old 10-31-2010, 09:36 PM
4.0H.O.XJ
Thats not much rust at all. Thats BABY rust. You should see what the northeast guys repair and wheel........ And those pics were not of his current XJ they were of another one like it for reference. The last few were of his current XJ.
And yeah, fixing rust IS fun, because you can right the factory wrongs and make it stronger and more watertight than original. Looks like ArchAngel is gonna set the bar high as far as rust repair is concerned.
post #7 of 1123 Old 10-31-2010, 09:40 PM
4.0H.O.XJ
FOX BODIES and a Miller! Come tub and cage my 70 Torino.
J/K
That seam sealer comes out with a torch, a paint scraper and a prayer. If there is a better way, damned if Ive found it..
post #8 of 1123 Old 10-31-2010, 09:49 PM
FairlanePhil
FairlanePhil's Avatar
J/K
Did someone say Torino?
Had me a 93 notch but I sold it. 2.3 turbo swapped. Fun cars
sorry for the hijack
Current: 99XJ 6.5 lift-Bought 2015
Sold: Patriot Blue 00 XJ.
'sploded: 01 stock-0331 head victim
FairlanePhil is offline
post #9 of 1123 Old 10-31-2010, 09:53 PM
4.0H.O.XJ
LOL Phil
post #10 of 1123 Old 10-31-2010, 10:01 PM
Rob K
1995 XJ Cherokee
The problem must be the tan interior. Mines in the same condition
Thanks for the inspiration. Maybe I can do this. What's the easiest way to go about this repair for someone without a welder and little experience welding. If I get a welder is this a project I'm going to want to cut my teeth on, so to speak? Would spot welding and seam sealing be the best way to go for me?
Rob K is offline
post #11 of 1123 Old 10-31-2010, 10:09 PM Thread Starter
The_Blacksmith
1993 XJ Cherokee
Deffinatly weld it, or hire a friend with a welder. by surpassing the factorys design and turning the unibody into a true unibody instead of some crappy u channel panel bonded to some stamped tin. You are making your rig that much tougher
edit, and wayyyyy offtopic, its an 81 mustang, powerglide,4000 stall, high compression 355 all home built.
post #12 of 1123 Old 10-31-2010, 10:14 PM
4.0H.O.XJ
Looking at the way this thread started, I'd say just pay attention. Looks like he's gonna cover all the bases and do it right.
As far as not having a welder or experience? Bro we live in wonderful times. 200-300 dollars can buy you an el-cheepo 110V MIG welder that will weld sheetmetal all day long. harbor freight, sales at sears, used on the net...Turn your heat and feed down low and practice on scrap sheetmetal until you can hold a bead for an inch or so without blowing holes and maintaining penetration, then practice your spots. Those are the 2 basic skills you need for floorpanel repair, but I'm already stealing this fine man's thread. You can do this. Go for it.
post #13 of 1123 Old 10-31-2010, 10:31 PM
KINGJB
I hate rust.
Build Thread:
KINGJB is offline
post #14 of 1123 Old 10-31-2010, 11:00 PM
KF4SQB
1994 XJ Cherokee
I've got some rust repair to do in my '94, but nothing even close to what the OP has. I've got a small spot (about the size of a half-dollar) in the front, inside corner, and several small spots covering a fair amount of area in the rear of the right floor. There's a small spot in about the center of the cargo area, but its just surface rust, nothing that a good clean-up and some primer won't fix. I'm not going to go nearly as far as the OP is, I'm only going to repair the actual bad spots with some patches cut from the floor of another XJ. I guess I'm lucky to live in the Deep South, where we don't have to salt the roads. I'll post pics of the minor damage I have in a few days, if I get the time.
To the OP, as has already been said, looks like you're well on the way to a "proper" repair. Best of luck!
4-wheeling: because football, basketball, baseball, and golf only require one ball!
Confidence: The feeling you get just before you fully understand the situation!
KF4SQB is offline
post #15 of 1123 Old 11-01-2010, 12:07 AM
7urtle
2008 KK Liberty
fun job.mine not that bad
hit it with a hammer
-1UMF a really slow build. bruised and never left the street
WTB: rear bumper/tire carrier,31" tires,armor
7urtle is offline
Replacing floors on a Cherokee mynameismyles65 XJ Cherokee Technical Forum 7 09-10-2011 12:48 AM
My 01 classic build thread/Collection of pics 01ClassicXJ XJ/MJ Cherokee Non-Technical Forum 244 06-08-2011 12:34 PM
Exo cage build thread... .with pics! X2elite XJ Cherokee Technical Forum 28 12-17-2009 05:06 PM
My build thread, LOTS of pics 01LimitedXJ XJ Cherokee Technical Forum 65 02-26-2009 01:56 PM
Jeep build- up thread (pics) Timo_90xj XJ Cherokee Technical Forum 42 07-06-2006 12:57 PM
