Replacing the flex plate? - JeepForum.com
post #1 of 3 Old 12-23-2004, 10:16 PM Thread Starter
NevadaXJ
NevadaXJ's Avatar
Angry Replacing the flex plate?
Last wheeling trip my Jeep started making a horrible knocking noise. I drove it home (80 miles or so) and of course the knocking is louder, however, the engine runs fine, and has not lost any power. Also no check engine light has come on.
In talking to friends and searching the web, I am convinced it is the flex plate. The noise is coming from where the tranny meets up with the engine. I have heard of an "inspection cover" that I can remove to see the flexplate/fly wheel, but I am not sure where this is. Also I do not know what I need to do to replace this plate, should I try it on my own.
Are there any "How-To's" out there that you know of? Google gave me no results. Have any of you done this, and how hard would it be for someone with limited mechanical skill and tools.
It's a 96, 4.0, AW4.
Thanks.
-John
1996 Jeep Cherokee
4.0 HO
Coming soon to a mountain near you!
NevadaXJ is offline
post #2 of 3 Old 12-24-2004, 01:12 AM
hormel26c
It's not likely that you have to replace the Flex Plate, but there is a good chance that the bolts to the torque converter are loose. You probably need to tighten them up.
Take a look here:
http://www.jeepforum.com/forum/showt...flywheel+bolts
86 XJ Wagoneer Limited. V6 3.4L HT
hormel26c is offline
post #3 of 3 Old 12-24-2004, 01:18 AM
JustinGJ
JustinGJ's Avatar
1990
Check the bellhousing bolts. There are 4 that hold the trans to the motor. The top 2 are inverted torx, but the 2 main ones are just a six point, maybe a 5/8".
1990 Wagoneer XJ
4.5" Rough Country full spring pack lift
Rubicon Express trackbar
Custom grille guard
JustinGJ is offline
crack in flex plate swells XJ Cherokee Technical Forum 1 10-27-2009 06:20 PM
Flex Plate...Where to buy? crem XJ/MJ Cherokee Non-Technical Forum 1 05-08-2009 08:17 PM
Transmission Flex Plate Will Not Come Off XJAl XJ Cherokee Technical Forum 35 04-15-2009 11:59 PM
flex plate Beeker356 XJ Cherokee Technical Forum 1 12-06-2006 08:22 PM
flex plate? Beeker356 XJ Cherokee Technical Forum 2 12-04-2006 08:43 PM
