Replacing 1997 Jeep Cherokee XJ Battery Cables - JeepForum.com
post #1 of 15 Old 05-03-2011, 01:26 AM Thread Starter
gabejeep
1997 XJ Cherokee
Hello Everyone,
I am trying to replace my battery cables on my 97 Jeep Cherokee XJ. I removed the black negative ground wire no problem. However, I ran into a snag with the red wire. When removing the red wire from the starter I noticed there is a green wire that ties into the boot of the cable. I followed the green wire up to a wire connector that connects a variety of wires next to the fuse box.
Does anybody know what this green wire is and how to remove it so I can change my batter cables?
In addition, I went to Pep Boys to get new cables only to find they don't have any cables resembling the red cable I have.
Anyone have this problem? Do I need to get the battery cables from the dealer?
Any help would be greatly appreciated.
I posted a few photos of it below:
Thanks!
-Topianno
gabejeep is offline
post #2 of 15 Old 05-03-2011, 02:45 AM
tjjeepwrench978
1997 XJ Cherokee
Thats the started solenoid wire
tjjeepwrench978 is offline
post #3 of 15 Old 05-03-2011, 02:46 AM
tjjeepwrench978
1997 XJ Cherokee
Junkyard
post #4 of 15 Old 05-03-2011, 07:40 AM
justanotherjpr
You will need to buy a universal terminal and cut the wire off at the old terminal. Strip some of the jacket on the old wire and place it in with the new wire when you crimp down the terminal.
I am guessing your battery cables come with the the new terminal already built in. Your options are to cut this terminal off and use the universal, return it and buy one with an extra lead coming from the terminal that you can splice into your existing wire.
The other option is to cut the green wire off your existing terminal and crimp on a ring terminal. You can then bolt the ring terminal to the side of the new terminal with the clamp bolt.
Check the green wire for length before you do any cutting.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #5 of 15 Old 05-03-2011, 09:20 AM
1CVPaul
1994 XJ Cherokee
So on this subject of battery cables - Does anyone know of a source for side mount battery terminal cables ? I have converted all my older rigs to side mount and am really happy with the results. I switch out the little headed bolts with larger ones that don't strip. No corrosion and quick to remove/install.
1CVPaul is offline
post #6 of 15 Old 05-03-2011, 10:15 AM
justanotherjpr
Most auto parts stores sell them.
post #7 of 15 Old 05-03-2011, 10:20 AM Thread Starter
gabejeep
1997 XJ Cherokee
Dealer Battery Cables for 1997 Cherokee XJ | $195.00
I just checked with the dealer and apparently they recommend I buy the OEM battery cables which include the original connectors that come in a kind of harness. The cost is $195.00.
I don't think my cables have ever been changed and I was simply doing it for maintenance. The cables themselves don't actually look that bad. I've heard however that old cables can cause electrical problems and poor battery performance.
How important is this? What do you guys think?
Thanks for the advice.
-Topianno
gabejeep is offline
post #8 of 15 Old 05-03-2011, 10:53 AM
1CVPaul
1994 XJ Cherokee
The ones I've seen at parts stores are what I used on my older trucks. But they don't have the additional wire coming off the connectors.
1CVPaul is offline
post #9 of 15 Old 05-03-2011, 10:55 AM
justanotherjpr
Your choice. Use what you have for free, use the advice above for under $30, or use OEM cables for $200.
If it were mine and the cables were not brittle and were in good shape, I would clean both ends of each cable really well and put them back on.
post #10 of 15 Old 05-03-2011, 02:03 PM
Ben
-Topianno
$195, NO WAY.
I replaced all the main cables in my Jeep with 2/0 copper flexible welders cable, new terminals, soldered & heat shrink tubing for all of it, and it was around $40. That's 3 years ago copper prices, but still.
Ben is offline
post #11 of 15 Old 05-03-2011, 02:18 PM
mnoeltne
A user called 5-90 over on naxja.org sells replacement battery cables he makes up. Good quality and decent pricing. He should have something for this. Click here for his website.
Mark N
2001 Sport - almost stock
mnoeltne is offline
post #12 of 15 Old 10-31-2012, 10:12 PM
OnTheFence
gabejeep, what did you ever do about this?
This seems a lot more complicated than it first seems.
Did you find a harness that has this 2nd green wire?
It sounds like you need to stick with OEM b/c it's NOT just a simple "single" cable, but multi-cables.
Is 5-90 the only other option?
OnTheFence is offline
post #13 of 15 Old 10-31-2012, 11:34 PM
5-90
5-90's Avatar
1988 XJ Cherokee
The same user goes by the same handle here - that's me!
If you want, PM me with your email addy and I'll send you an instruction sheet on how to handle that little nuisance. ChryCo calls them "convenience blocks" - they don't trust techs to sort out wiring on their own, apparently.
There are no electronics in there, it's a moulded elastomer block that merely serves to maintain the relative location of the terminals.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #14 of 15 Old 11-02-2012, 11:47 PM
zimsy
1993 XJ Cherokee
Hahaha! On my 93 everyone was saying the ignition wire was yellow or brown/yellow but it ended up being brown. Spend the money on heavy gauge wire like everyone is saying and DIY. Took me forever to figure what I was doing but research pays off.
zimsy is offline
post #15 of 15 Old 11-03-2012, 05:17 PM
cpttuna
Most people replace the battery cables so they can upgrade to heavier cables.(at least 4 guage). You can buy cables that will work at O'reillys for about $40.00. I would not go the $195.00 route. Remember the cable does not have to be the exact length or guage of the wire you take off.
cpttuna is offline
battery cable , green , xj
length of battery cables on 98 cherokee insurrection151 XJ Cherokee Technical Forum 2 06-25-2009 01:03 PM
Replacing Battery Cables patchouli XJ Cherokee Technical Forum 3 11-29-2006 06:44 AM
Replacing battery terminals and cables ki1022 XJ Cherokee Technical Forum 5 11-06-2006 05:23 PM
95 Cherokee battery cables zerobounds XJ Cherokee Technical Forum 4 07-28-2006 09:05 PM
Replacing battery cables: how to do it? adreed24 XJ Cherokee Technical Forum 8 09-26-2005 05:25 AM
