Replacement rear shocks for '98 XJ - JeepForum.com
post #1 of 3 Old 07-17-2012, 02:41 PM Thread Starter
ttrevino
I bought this XJ, and the previous owner replaced the stock rear end with a '98 Ford Explorer rear end. The problem I've run into is now I don't know what type of shocks to buy to replace the ones on there. I've tried doing a cross reference on the part number of the existing shocks, and have taken one with me to the local auto parts, with no luck. The truck has a 4-1/2" lift on it, however, the PO told me I would need shocks for a 2" lift, due to the mounting spots on the Explorer rear end.
Any help would be appreciated! I'm tired of getting bounced all over.
ttrevino is offline
post #2 of 3 Old 07-17-2012, 03:12 PM
ahuf
Time to flex your ride and measure. Take your measurements in with you to your store. If you would rather go the online route call up your preferred retailer and give them the measurements and they will sell you the proper shocks.
You can do a google search for a more in depth guide for measuring shock length but I'll give you one up. let me google that for you
Good luck and I'm sure others will chime in as well.
1998 Jeep Grand Cherokee 5.9 Limited 4x4 :: 46RE, 249, MSD ignition, PO e-fan conversion to a different e-fan, 3.73 gears
ahuf is offline
post #3 of 3 Old 07-19-2012, 10:00 AM Thread Starter
ttrevino
Thanks for the advice, it's been tough finding the right rear shock, but I think I'm well on my way! Who would have thought buying shocks would be so difficult!
ttrevino is offline
shocks
Front YJ shocks and rear ZJ shocks?? bdhaley XJ Cherokee Technical Forum 7 01-07-2010 08:58 PM
Replacement Shocks miklars XJ/MJ Cherokee Non-Technical Forum 6 11-25-2008 08:09 PM
Need stock replacement shocks opdave XJ Cherokee Technical Forum 1 02-25-2008 12:32 PM
Replacement shocks for '99 XJ? 2drSport XJ Cherokee Technical Forum 6 07-25-2005 07:00 PM
Need advice on replacement shocks Ren XJ Cherokee Technical Forum 5 12-30-2003 12:26 PM
