Replaced water pump, now squealing noise - JeepForum.com
post #1 of 13 Old 12-25-2007, 09:43 PM Thread Starter
ar275103
1993 XJ Cherokee
Just replaced the water pump, hoses, thermostat etc. in my 93 4 cyl xj and seemed to be working great until I noticed a high pitch squeal coming from the engine that gets louder with acceleration. I am thinking the belt tension could be off, would that make a squealing noise that increases with rpms? how would i go about adjusting the tension and how much tension should be on the belt? anybody have similar problems with water pump replacement and squealing afterwards?
ar275103 is offline
post #2 of 13 Old 12-25-2007, 10:05 PM
Meltedmechanic
1993 XJ Cherokee
only thing i can think of that would get higher in pitch is a loose belt. I think about 1/4 inch of play i may be wrong i think i am wrong... but definitly sounds like a belt
Meltedmechanic is offline
post #3 of 13 Old 12-25-2007, 10:19 PM
taseal
1993 XJ Cherokee
I have the same problem, let me know if you find out what it is... we've played with tension, but nada...
'93 Cherokee "XJ" Sport - 4.0 HO - 4x4 - AX15 - Chrysler 8.25 - Fun Jeep
'08 Patriot "MK" Limited - 2.4 - 4x2 - CVT II -DD Jeep
taseal is offline
post #4 of 13 Old 12-25-2007, 10:22 PM
black2door
black2door's Avatar
1994 XJ Cherokee
Maybe just throw a new belt on it. Worth a try.
black2door is offline
post #5 of 13 Old 12-25-2007, 11:10 PM
TwistedXJ
Just tighten the serpentine belt as needed and it will go away, when I did my pump it was just that nothing else. it is common when you take it off .
TwistedXJ is offline
post #6 of 13 Old 12-25-2007, 11:37 PM
XJohnnyC
XJohnnyC's Avatar
As long as you had the old belt off, you should've put a new one on and saved the old one as a spare.
The belt has to be really tight. Tighter than most people think. I believe it's like 160 ft/lbs. for a new belt and 140 ft/lbs for a broken-in belt (I could be slightly off on the numbers).
A good tension gauge is the Krikit II from NAPA. It costs about $12.
XJohnnyC is offline
post #7 of 13 Old 12-26-2007, 04:55 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
XJohnnyC is correct, these belts have to be quite tight to prevent squealing.
Everytime I install a new belt, I end up tightening it usually twice before it stops barking at me.
IF you did not have squealing before you installed the water pump, then the problem is almost certainly belt tension. You should also inspect the belt for "glazing".
If your belt is pretty new, then tighten it a bit more. If the belt is older, I'd replace it with a new good quality belt. Don't shop low end stuff; you get what you pay for!
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #8 of 13 Old 12-26-2007, 10:17 AM Thread Starter
ar275103
1993 XJ Cherokee
thanks to all for the advice, looks like ive got a little more work to do before the job is completed. Im probably going to end up replacing the belt with a new one, anyone know anything about the gatorback belts??
ar275103 is offline
post #9 of 13 Old 12-26-2007, 11:55 AM
Cruzin Illusion
Round Eyed XJ
Cruzin Illusion's Avatar
1987 XJ Cherokee
If you have silicone spray lube or WD40 spray some on the belt with the motor run. If the noise goes away then the you need to replace the belt. More than likely that is your problem. If it does not go away, with the belt removed, turn the idler pulley and see if it feels like it is rough or grinding when turn it. The bearing in the idler pulley is known to go bad. Also look at you crank pulley/dampner. If it is older and the rubber portion is displaced it will cause a squeaking noise. This is the least likely out of the group.
CRUZIN ILLUSION
BUILT NOT BOUGHT
By Cruzin Illusion Customs
View the Cruzin Illusion Rig here:
(OlllllllllllllO)
Rock Frog
CIC's Build Threads:
Cruzin Illusion is offline
post #10 of 13 Old 12-26-2007, 05:27 PM
JMC-14
Don't over tight, because you may destroy your power steering pump, which is closest to the belt tensioner. Too much side loading on the bearing will eventually cause it to fail.
JMC-14 is offline
post #11 of 13 Old 12-26-2007, 06:37 PM
MBJR9
Tighten the belt, should go away after that.
The XJ
1996 XJ Sport, 4.0L HO I6, AX15 5 Speed, NP231, Dana 30/35, Flareless
The Daily Driver
2004 Ram 1500, 5.7L Hemi V8, 545RFE 5 Speed Auto, NP241, Chrysler 8.0/Chrysler 9.25, 10mpg
MBJR9 is offline
post #12 of 13 Old 12-26-2007, 08:00 PM Thread Starter
ar275103
1993 XJ Cherokee
tightened the belt some after work today. still squeals a little bit, about the same as when i replaced the water pump, but the increased squealing with higher rpms is all gone, so im pretty satisfied with the way she sounds. thanks for all your advice forum members
ar275103 is offline
post #13 of 13 Old 12-26-2007, 08:03 PM
XJohnnyC
XJohnnyC's Avatar
Gatorbacks are probably the best belt to get.
And yes, overtightening is much worse than undertightening. Using ny Krikit II, I've found that the difference between overtightening and undertightening is just a couple of turns of the adjusting bolt. So there's not much margin for error. That's why I'd recommend a tensioning gauge.
XJohnnyC is offline
Leak located at water pump - replaced pump- still leaking natesxj XJ Cherokee Technical Forum 11 11-02-2009 07:06 PM
Replaced water pump, now antifreeze leaking again xjtechie XJ Cherokee Technical Forum 2 10-30-2009 08:51 PM
Water Pump Noise? bret4 XJ Cherokee Technical Forum 8 06-27-2009 06:38 PM
Replaced water pump, high idle RussoGuitar XJ Cherokee Technical Forum 1 07-03-2007 07:01 AM
How much have you guys paid to have a water pump replaced? BigBearXJ XJ Cherokee Technical Forum 29 02-08-2007 03:00 PM
