Replaced nearly entire cooling system... - JeepForum.com
post #1 of 11 Old 04-21-2010, 09:29 AM Thread Starter
Kasia
1994 XJ Cherokee
My jeep overheated- it's been needing a new radiator and t-stat for a while, and I already have a hi-flow water pump for it and rad hoses. replaced with hesco 180 hi-flow tstat & housing, upper and lower hoses, hi-flow pump, radiator & cap. electric fan hasnt been coming on so i replaced that. still overheating, and i found out it's not pumping anything; it just sits in the radiator and overflow tank. took out the thermostat... still not pumping anything through. so it has to be the water pump... however, it's impossible to install the water pump wrong. the gasket only goes on one way, the pump bolts in one way, and the belt has been re-installed properly. the pump is brand new.
any help on this would be appreciated.
and i don't think anything's wrong with the motor, it sounds like it's running a bit rough but there's no coolant in the oil and no white smoke coming from the exhaust.
Thanks.
Kasia is offline
post #2 of 11 Old 04-21-2010, 09:55 AM
XJH-007
XJH-007's Avatar
If you are 100% guranteed it's not pumping...it's the pump. Go back to a stock pump.
Or you have a massive air bubble. Have you parked on an incline (nose up) and bled the system?
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline
post #3 of 11 Old 04-21-2010, 11:16 AM
Willy36
1990 XJ Cherokee
Some aftermarket pumps don't turn the right direction...
Willy36 is offline
post #4 of 11 Old 04-21-2010, 11:30 AM
Chris_Walker
Chris_Walker's Avatar
1988 XJ Cherokee
Was there a lot of crud in your coolant when you drained it? You might have a blockage somewhere. Also make sure there's not excessive amounts of air trapped in it. Open the radiator cap and try squeezing the hoses to see if any air bubbles come up.
Chris_Walker is offline
post #5 of 11 Old 04-21-2010, 11:46 AM
Tex96
Is water pump pulley turning? In the correct direction?
Bad lower rad hose?
Run water into top of radiator- Flows out lower hose?
As mentioned above post #3 - is Pump Itself the 'Wrong' Way Rotation type? (There are 2 kinds.)
Year/Motor?etc.?
Tex96 is offline
post #6 of 11 Old 04-21-2010, 11:52 AM
XJH-007
XJH-007's Avatar
You could also test by removing the top hose from the radiator, and stick a garden hose in there....does it push through the system? (this will only work if the T-stat is open or removed)
***02 WJ Overland
XJH-007 is offline
post #7 of 11 Old 04-21-2010, 11:55 PM
mickc9129
As mentioned above there are 2 type water pumps made. My '91 for instance uses a reverse rotation pump. There is a "R" stamped on the pump for reference. Also, you should have a coil spring inside your lower hose as it might collapse if it doesn't.
mickc9129 is offline
post #8 of 11 Old 04-22-2010, 12:16 AM
nbleak21
Yep, my guess would be HUGE air bubble or reverse flow pump.
2004 Jeep Wrangler X - 2" BB, 15x10" MT CLII's, 32" BFG A/T K/O's
2000 Jeep Cherokee Sport- Bone Stock
nbleak21 is offline
post #9 of 11 Old 04-22-2010, 08:01 AM Thread Starter
Kasia
1994 XJ Cherokee
Yup, air bubble simpler than I thought... now I just gotta figure out why the electric fan isn't coming on.
Kasia is offline
post #10 of 11 Old 04-22-2010, 10:23 AM
Willy36
1990 XJ Cherokee
With the ignition on, unplug the switch and jump a wire between the two sides of the plug. If your fan comes on then, the problem is in your switch. If not, it may be the relay went bad.
Willy36 is offline
post #11 of 11 Old 04-22-2010, 04:22 PM
filluptrk
If the jeep overheats but doesn't show on gauge then because of the air blocking fluid flow the temp sender in the housing isn't getting enough hot coolant around it to work. An engine can overheat with trapped air and not show hot on gauge.
Try pulling jeep up so drivers side is up to the left, and the pass side is down. On my 00 I have a lever vent cap so I just raised the vent and as the air in the rad moved toward the high side it blew out into the overflow. I raised and lowered the vent while it was running and after a while it cleared the air out. Phil
filluptrk is offline
Is the AC system and the engine cooling system connected firedogut XJ Cherokee Technical Forum 8 07-17-2009 10:47 AM
How to set up the cooling fan with a 92+ Cooling System stewmac XJ Cherokee Technical Forum 0 11-17-2008 06:19 PM
Replaced almost all cooling parts- Still Overheats..???? jeepjunky22 XJ Cherokee Technical Forum 32 06-25-2008 12:59 PM
Closed cooling system to Open system? motu1983 XJ Cherokee Technical Forum 7 08-02-2007 09:39 AM
ac compressor cooling fan is cracked, anyone has replaced the blade ?? mike_99l XJ Cherokee Technical Forum 5 06-06-2005 09:32 AM
