Replaced CPS...still no start - JeepForum.com
post #1 of 9 Old 08-12-2005, 11:12 PM Thread Starter
90xj4x4
Hey guys. Ok I searched but couldnt find what I needed. My XJ died a few weeks ago. Had been driving it all day and shut it down...then it wouldnt start. I parked it and the next day I tried to start it. Same situation, cranks like normal but wont catch, not even a sputter. Today I dove into it. I figured it was the CPS so I replaced it. Still nothing. Have spark, fuel, and compression. I repaced the spark plugs b/c they were wet with fuel. Still nothing. Is there a fuse that could be bad somewhere?? Cap rotor and wires are 15k miles old.
PLEASE HELP!!!!
ITS A JEEP THING...YOU WOULD'T UNDERSTAND!
'90 Cherokee Limited, 4.0,
New AW4 with a Freshly swapped in NP231, (no more 242)
Dana 30/35 with rear Trak Loc
Tow Pkg.
RE 2" BB,
Cheap Wal-Mart CB Radio,
Converted to open cooling system,
Optima Red Top,
Dents and Scratchs from rocks
New 31" BFG All-Terrains
New Tow Rig - 1998 Chevy 2500 HD 4x4 EC LB 6.5 Turbo Diesel
THE 21 AND UNDER XJ OWNERS CLUB #1 (20)
90xj4x4 is offline
post #2 of 9 Old 08-12-2005, 11:18 PM
88XJSport
88XJSport's Avatar
1988 XJ Cherokee
Did you try the ignition coil pack?? Took mine off and put it back on and fired right uo for me when i was in your situation. Try that, probably a bad contact. Worked for me! Good Luck!
88XJSport is offline
post #3 of 9 Old 08-13-2005, 12:10 AM Thread Starter
90xj4x4
I thought about that but I have a good spark at the coil wire and the spark plug wire...so wouldnt that cancel out the coil pack?
Tow Pkg.
RE 2" BB,
Optima Red Top,
90xj4x4 is offline
post #4 of 9 Old 08-13-2005, 12:19 AM
firefighter1c57
SPACE FOR RENT
firefighter1c57's Avatar
Have you tried to start it while holding the gas pedel to the floor. You said the plugs were wet with fuel. It may be overfueling and flooding out. If not, you have fuel, you have fire, the only thing that could be left is timing. Check the cap for cracks, arcing, ect. It is possible to get a weak spark with a plug pulled, however have the same plug not fire in the cylinder. The pressure in the cylinder makes it harder for the electricty to jump the air gap. Something about 180 psi in a cylinder, molecules closer to gether, resistance incress yada yada yada.
I bring NOTHING to the table.
firefighter1c57 is offline
post #5 of 9 Old 08-13-2005, 12:55 AM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Just barely put some pressure on the gas pedal or have someone crack open the throttle while you try to start it.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #6 of 9 Old 08-13-2005, 01:09 AM Thread Starter
90xj4x4
Tried the throttle at wide open, partial, barely, none, everything possible and no difference. Could the new CPS be too far away from the flywheel?
Tow Pkg.
RE 2" BB,
Optima Red Top,
90xj4x4 is offline
post #7 of 9 Old 08-13-2005, 09:34 AM
Rock Kustoms
Rock Kustoms's Avatar
if you have spark its not the cps
im going w/ someting in the cap....
Rock Kustoms is offline
post #8 of 9 Old 08-13-2005, 10:28 AM
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
Pull the cap off and make sure the rotor is still working and that its not misaligned or bad.
- Chopped / Locked
- Daily Driver
2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust
Rule #1 - No talking about the weather!
BeachinXJ is offline
post #9 of 9 Old 08-13-2005, 12:22 PM Thread Starter
90xj4x4
How can I check for spark intensity?
Tow Pkg.
RE 2" BB,
Optima Red Top,
90xj4x4 is offline
4.0 battery on, starter replaced no start orangekid XJ Cherokee Technical Forum 15 12-22-2009 07:05 PM
Replaced Plugs, now turns but won't start HELP!!! etjoyride XJ Cherokee Technical Forum 11 02-18-2009 11:40 PM
Just replaced some stuff, now it wont start, HELP! ki1022 XJ Cherokee Technical Forum 13 07-25-2006 11:31 PM
car wont start just replaced head need help!! Everlastinboost XJ Cherokee Technical Forum 17 06-29-2005 10:02 AM
